HjanecksD03 3 Posted June 23 Posted June 23 Have you checked whether the FLAC files themselves play correctly in other browsers/devices? I've seen a few cases where unusual metadata or embedded tags caused odd playback behavior. It might be worth testing one of the affected files after cleaning up the tags. I used editmp3tags.com a while back to inspect audio metadata and it helped identify a couple of problematic files.
brothom 224 Posted June 23 Posted June 23 24 minutes ago, HjanecksD03 said: Have you checked whether the FLAC files themselves play correctly in other browsers/devices? I've seen a few cases where unusual metadata or embedded tags caused odd playback behavior. It might be worth testing one of the affected files after cleaning up the tags. I used editmp3tags.com a while back to inspect audio metadata and it helped identify a couple of problematic files. Please don't necro two year old threads.
