payboss 1 Posted March 3, 2018 Posted March 3, 2018 Hi All, Having the exact same issue. This is my first Emby server setup so was not sure whether this was something i was doing wrong. Like the primary post says I can retrieve a token request code but when running the script it will not communicate via the trakt API and add it to my authorised trakt app list. Any help is greatly appreciated. Kindest regards Rick
Deihmos 170 Posted March 3, 2018 Posted March 3, 2018 Same issue and same issue you with other media servers so not just emby.
Animosity022 6 Posted March 3, 2018 Posted March 3, 2018 Same issue and same issue you with other media servers so not just emby. I think you mean plex trakt scrobbler? That's down because the auth server they use as part of the plugin is offline. Try radarr or something else and it works fine. The emby plugin makes a direct call to to trakt passing an auth token and isn't working. They are looking at that, but not related to the plex trakt scrobbler.
lateparty 1 Posted March 4, 2018 Posted March 4, 2018 Cross-posting from another thread: FR: Trakt plugin - collection sync Eagerly awaiting update.
digger11 1 Posted March 4, 2018 Posted March 4, 2018 We're looking into this, thanks guys. Hi @@Luke, any progress? I'm assuming there's no problem reproducing this, but if there is I can provide additional logs or access to a server where it is failing.
Animosity022 6 Posted March 4, 2018 Posted March 4, 2018 Hmm. I'm not sure if something changed, I was able to authenticate a few minutes ago. I can see the app registered in trakt and syncing properly now. I believe in magic
Animosity022 6 Posted March 4, 2018 Posted March 4, 2018 I'm not sure why it would be related, but at the same time trakt for plex was just fixed: https://github.com/trakt/Plex-Trakt-Scrobbler/issues/484 So both are working now.
digger11 1 Posted March 4, 2018 Posted March 4, 2018 Seems to be working again! Since nothing appears to have changed on the Emby end, I'm assuming the issue was with Trakt's authentication server or authentication mechanism.
Animosity022 6 Posted March 4, 2018 Posted March 4, 2018 Seems to be working again! Since nothing appears to have changed on the Emby end, I'm assuming the issue was with Trakt's authentication server or authentication mechanism. Doesn't seem that way. I tried Radarr and that worked fine.
lateparty 1 Posted March 5, 2018 Posted March 5, 2018 Had to rebuild my config profile after reports in here said resolved, and that did the trick.
Luke 42253 Posted March 5, 2018 Posted March 5, 2018 Thanks for the feedback guys. And no, we didn't do anything to resolve this.
skuuup 24 Posted May 26, 2018 Posted May 26, 2018 Same thing happened to me. Trakt.xml was the culprit To fox the issue I needed to stop Emby server > delete Trakt.xml > start Emby > generate a new PIN > save Please fix this issue
Luke 42253 Posted May 26, 2018 Posted May 26, 2018 An update to the trakt plugin went out today so hopefully you won't need to do it again. 1
