GhostRider 49 Posted February 10, 2018 Posted February 10, 2018 (edited) My preference is to use PowerDVD as an extermal player but this fails when I enable Cinema mode to play CODEC intros. I tried MadVR and IQ is pretty good but I get a very odd problem with CODEC intros. The first film plays the intro and then the film fine, if I go back and select a second movie it starts the CODEC intro I see the OSD but that's it, the screen then goes blank. Is it possible to just use the external player for the main feature or is there a fix to make MadVR work all the time with Intros? Edited February 10, 2018 by GhostRider
GhostRider 49 Posted February 10, 2018 Author Posted February 10, 2018 With Cinema mode turned on and using PowerDVD as an external player causes PowerDVD to start up in file browser mode. I guess something is not right with the way {path} and the PowerDVD command line. PowerDVD only supports one file name on the command line. Using MadVR it plays the intro the first time but for any other attempts to play a second movie MadVR starts, displays the OSD but then stops and the screen goes blank.
Luke 42243 Posted February 13, 2018 Posted February 13, 2018 @@GhostRider have you tried using the default internal player for comparison?
GhostRider 49 Posted February 13, 2018 Author Posted February 13, 2018 (edited) @@Luke, just done some testing with the default internal player. This works fine as expected. Cinema mode enabled, audio CODEC plays before movie, movie starts, stop movie, go back select another one, audio CODEC plays OK and new movie starts. I don't use the internal player, it doesn't do any upscaling that I can see of SD movies. My prefered external player: PowerDVD does not work when Cinema mode is enabled. Is this something that can be fixed e.g. play Cinema mode with internal player and only pass main feature to the external player? Edited February 13, 2018 by GhostRider
