bflagg 2 Posted February 16, 2018 Author Posted February 16, 2018 (edited) It says access denied...But I have to ask... how can that be? The windows account can access the shares and read/write to them with no problem using standard windows explorer network browsing. The Emby service is set to use the windows domain account on start up.( just set and made no difference) .. Only Emby can no longer access shares. Any suggestions? Edited February 16, 2018 by bflagg
bflagg 2 Posted February 16, 2018 Author Posted February 16, 2018 ok.. this is weird. I just restarted the service again, and now it can read the shares....and it's populating now.I have no idea why it would fail like this then start up again. I'm open to any idea to check into... now I wait to see if the defenders will populate....
Luke 42205 Posted February 16, 2018 Posted February 16, 2018 I can't answer about what is happening in your personal environment but what i can suggest is simplifying and running without the windows service first to ensure successful operation, and then go from there.
Happy2Play 9802 Posted February 16, 2018 Posted February 16, 2018 Possibly Windows updates as pending updates/restart have been reported to cause problem.
Luke 42205 Posted February 16, 2018 Posted February 16, 2018 Windows updates have caused network issues in recent months so that could be it.
bflagg 2 Posted February 17, 2018 Author Posted February 17, 2018 Thank you all for you help. I'm updating you all that it's now reading all files as it should..The only thing I have actually done is set the Emby service to start with the domain credentials that I login with on this dedicated pc. I have a few other questions of which I will post as a new thread. Again, Thank you all very much. Brett
Happy2Play 9802 Posted February 17, 2018 Posted February 17, 2018 So that would point to permissions, and you should have seen that in you log file.
