weble 19 Posted January 4, 2022 Posted January 4, 2022 (edited) Anyone using an i5 11400 UHD730 for tone-mapping on docker emby stable branch? hardware tonemapping is just solid green screen artifacting. just to be clear everything else is working super with hardware transcoding hardware_detection.txt ffmpeg-transcode-log.txt Edited January 4, 2022 by weble
softworkz 5133 Posted January 4, 2022 Posted January 4, 2022 Can you try to use the VAAPI decoder for H.265 instead?
weble 19 Posted January 4, 2022 Posted January 4, 2022 (edited) Thanks @softworkzthat worked. Guess QSV support is not fully ready yet? Or is intel going full VAAPI support instead of QSV on linux now? edit: it kinda works, some movies falling back to software mode. If i tell VAAPI to use openCL I get the same green artifact screen as before using QSV but transcodes do not fail to software. ffmpeg-transcode-vaapi-fail.txt Edited January 4, 2022 by weble
softworkz 5133 Posted January 4, 2022 Posted January 4, 2022 29 minutes ago, weble said: Guess QSV support is not fully ready yet? Or is intel going full VAAPI support instead of QSV on linux now? None of the above actually. Decoding a video involves multiple steps, the first one being "parsing" of the bitstream. In case of QSV, you give the full bitstream to QSV for decoding. In case of VAAPI, ffmpeg does the parsing and VAAPI is doing "just" the rest. There's some issue in QSV (MSDK) parsing of certain files. I think it's time to submit a sample to them for getting this fixed. Do you have a short snippet (20-30s) you could share publicly? It should not contain copyrighted content. What would be OK is some movie intro showing the studio logo animations or similar.
weble 19 Posted January 4, 2022 Posted January 4, 2022 Ah thanks for the info, glad your on top of it! Not sure what I could send in since every movie is copyrighted.
softworkz 5133 Posted January 4, 2022 Posted January 4, 2022 1 hour ago, weble said: Ah thanks for the info, glad your on top of it! Not sure what I could send in since every movie is copyrighted. 1 hour ago, softworkz said: What would be OK is some movie intro showing the studio logo animations or similar.
weble 19 Posted January 6, 2022 Posted January 6, 2022 @softworkzAh beauty I can do that. What program or commands should i use to get this done?
softworkz 5133 Posted January 6, 2022 Posted January 6, 2022 It depends on the container format. When it's *.ts, you can just truncate the file at a certain point. In case of mp4 or mkv, I could post an ffmpeg command.
softworkz 5133 Posted January 6, 2022 Posted January 6, 2022 ffmpeg.exe -i input.mkv -ss 30 -to 50 -c:v copy -c:a copy output.mkv This creates a 20s video starting from second 0:00:30 until 0:00:50 1
mattsteg 0 Posted January 18, 2022 Posted January 18, 2022 How do you enable tonemapping? I see no options for it in the web gui Emby Web 4.6.7.0.
Happy2Play 9814 Posted January 18, 2022 Posted January 18, 2022 1 minute ago, mattsteg said: How do you enable tonemapping? I see no options for it in the web gui Emby Web 4.6.7.0. Near the bottom of Settings-Transcoding.
mattsteg 0 Posted January 18, 2022 Posted January 18, 2022 (edited) Where? I don't see the feature listed at https://emby.media/premiere.html and I don't see it anywhere in the software without premiere. Edited January 18, 2022 by mattsteg
Happy2Play 9814 Posted January 19, 2022 Posted January 19, 2022 5 minutes ago, mattsteg said: Where? Should be just above subtitle extraction, as it is on every one of my systems. So would have to ask what client you are using.
mattsteg 0 Posted January 19, 2022 Posted January 19, 2022 Just now, Happy2Play said: Should be just above subtitle extraction, as it is on every one of my systems. So would have to ask what client you are using. The web client /web/index.html#!/transcoding
Happy2Play 9814 Posted January 19, 2022 Posted January 19, 2022 3 minutes ago, mattsteg said: The web client /web/index.html#!/transcoding Minus your browser throwing console errors I am not sure as all my 4.6.7.0+ systems have the option. At the same time HWA and Tone-mapping require Premiere, but you should still see the option.
softworkz 5133 Posted January 19, 2022 Posted January 19, 2022 He could install the Diagnostic plugin and look at the page with the detailed tone mapping options.
mattsteg 0 Posted January 19, 2022 Posted January 19, 2022 3 minutes ago, Happy2Play said: Minus your browser throwing console errors I am not sure as all my 4.6.7.0+ systems have the option. At the same time HWA and Tone-mapping require Premiere, but you should still see the option. It occurs in both chrome and firefox. I have some restrictive security settings enabl4ed in firefox but nothing abnormal in chrome. I can see the hardware acceleration option (which I don't really, at least for non-tonemapping cases) but nothing about tonemapping. On a side-note, it can be very frustrating to attempt to figure out the value proposition offered by premiere and what features are locked-out.
softworkz 5133 Posted January 19, 2022 Posted January 19, 2022 4 minutes ago, mattsteg said: On a side-note, it can be very frustrating to attempt to figure out the value proposition offered by premiere and what features are locked-out. https://support.emby.media/support/solutions/articles/44001173099-emby-premiere-feature-matrix
mattsteg 0 Posted January 19, 2022 Posted January 19, 2022 8 minutes ago, softworkz said: He could install the Diagnostic plugin and look at the page with the detailed tone mapping options. I get this:
softworkz 5133 Posted January 19, 2022 Posted January 19, 2022 Could you please post the server log and hw detection log? What hw and OS are you running Emby server on?
Happy2Play 9814 Posted January 19, 2022 Posted January 19, 2022 1 minute ago, mattsteg said: I get this: Can you post a server log, but there would appear to be something wrong with your install? Do you have the same issue if you logged in with the online client, app.emby.media.
mattsteg 0 Posted January 19, 2022 Posted January 19, 2022 8 minutes ago, softworkz said: https://support.emby.media/support/solutions/articles/44001173099-emby-premiere-feature-matrix That doesn't list tonemapping, and also lists some features which *appear* to be available to me without premiere (i.e. webhooks) Not quite being satisfied with the playback in the native app on shield (in particular, transcoding media that I'd been able to direct-play with SPMC/Kodi was a complete showstopper on my older server - less of an issue but still a bummer at times now) and not really caring about the bulk of the premiere options has kept me from buying in, but I really should support the project and appreciate the heck out of your responsiveness here.
mattsteg 0 Posted January 19, 2022 Posted January 19, 2022 (edited) 12 minutes ago, softworkz said: Could you please post the server log and hw detection log? What hw and OS are you running Emby server on? I'm running on Truenas core, and did install via the plugin they have which I know can get weird at times. hardware is a dell 720xd server with 2x E5-2690 v2. curious to what extent software tonemapping is usable. hardware_detection-63778127058.txt embyserver.txt Edited January 19, 2022 by mattsteg
softworkz 5133 Posted January 19, 2022 Posted January 19, 2022 OK thanks You're not seeing tone mapping because you're on BSD, where we have only a regular ffmpeg version available. Hence no tone mapping. But this is changing right now. Actually today(!) there has been an important milestone achieved, and when all things go well, the next beta (.21) might already include our own ffmpeg on BSD.
