griffindodd 18 Posted February 9, 2018 Author Posted February 9, 2018 (edited) This is needed for transcoding though. Direct playing to Kodi or ET this isn't really an issue. Playing HDR material in any situation where transcoding it is required. This string would only be applied when transcoding HDR material. Yep, or also be a trigger to start transcoding to an SDR display. But, if the end display is HDR, hopefully Emby can still pass HDR content even if it does have to transcode for other reasons (codecs, bandwidth etc) Edited February 9, 2018 by griffindodd 1
Guest asrequested Posted February 9, 2018 Posted February 9, 2018 But wouldn't it be better to not lose the HDR color? And negate the need for conversion? That's what I'd prefer.
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 But wouldn't it be better to not lose the HDR color? And negate the need for conversion? That's what I'd prefer.HDR is strictly dynamic range, don't confuse it with 10 or 12bit color which can technically also exist in SDR material too Sent from my SM-G955U1 using Tapatalk
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 (edited) HDR is strictly dynamic range, don't confuse it with 10 or 12bit color which can technically also exist in SDR material too Sent from my SM-G955U1 using Tapatalk We use an app with mpv that uses PQ for HDR. It isn't strict. The color representation is perfect. I actually prefer it to sending the metadata to my display. The picture quality is exactly the same without waiting for the display to switch. Mpv uses ffmpeg, so PQ can definitely be used. https://emby.media/community/index.php?/topic/53211-emby-theatre-support-for-evc/page-7&do=findComment&comment=521624 Edited February 10, 2018 by Doofus
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 We use an app with mpv that uses PQ for HDR. It isn't strict. The color representation is perfect. I actually prefer it to sending the metadata to my display. The picture quality is exactly the same without waiting for the display to switch. Mpv uses ffmpeg, so PQ can definitely be used. https://emby.media/community/index.php?/topic/53211-emby-theatre-support-for-evc/page-7&do=findComment&comment=521624 Sounds like the implementation of the conversion is well within the scope of FFMPEG it seems that the rules and flags to trigger are more involved though. Sent from my SM-G955U1 using Tapatalk 1
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 Sounds like the implementation of the conversion is well within the scope of FFMPEG it seems that the rules and flags to trigger are more involved though. Sent from my SM-G955U1 using Tapatalk Yeah, that's why I mentioned @@Waldonnis. I'm hoping he's got a viable solution.
Luke 42255 Posted February 10, 2018 Posted February 10, 2018 I guess the question would be does the standard transcoding we already employ not satisfy?
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 I guess the question would be does the standard transcoding we already employ not satisfy? It doesn't, if we want to allow transcoding of HDR content.
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 (edited) I guess the question would be does the standard transcoding we already employ not satisfy?Not for HDR. Even now if an HDR file has to be transcoded (even just for bandwidth or an audio code change) it strips the Metadata so then an HDR display will not recognize the content as HDR and switch to HDR mode, this results in the washed out look again. Add to that lack of tone mapping for SDR displays and it makes Emby all but useless for viewing HDR material unless it's simply direct playing only to an HDR display. Sent from my SM-G955U1 using Tapatalk Edited February 10, 2018 by griffindodd 2
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 These are technically two separate issues. 1. Transcoding needs to retain HDR Metadata so that HDR compatible displays know the content is HDR and switch to the correct display mode. 2. The Emby client checks to see if a display is HDR compatible, if not it tells the transcoder to engage tone mapping during the encode to output accurate colors in a traditional SDR format. Sent from my SM-G955U1 using Tapatalk
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 These are technically two separate issues. 1. Transcoding needs to retain HDR Metadata so that HDR compatible displays know the content is HDR and switch to the correct display mode. 2. The Emby client checks to see if a display is HDR compatible, if not it tells the transcoder to engage tone mapping during the encode to output accurate colors in a traditional SDR format. Sent from my SM-G955U1 using Tapatalk Again, I think it's better to use PQ, then those two things will be redundant. That would be my choice.
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 I have no idea what a perceptual quantizer is, I assume you can time travel with it though like a Flux capacitor Sent from my SM-G955U1 using Tapatalk
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 I have no idea what a perceptual quantizer is, I assume you can time travel with it though like a Flux capacitor Sent from my SM-G955U1 using Tapatalk I guess you didn't read the link that I posted.
Jdiesel 1439 Posted February 10, 2018 Posted February 10, 2018 OP is having issues with HDR material on Roku and Apple TV clients outside his network on non HDR TVs. This doesn't apply to direct playing files on ET or Kodi.
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 (edited) OP is having issues with HDR material on Roku and Apple TV clients outside his network on non HDR TVs. This doesn't apply to direct playing files on ET or Kodi.All Emby clients attached to any SDR display Sent from my SM-G955U1 using Tapatalk Edited February 10, 2018 by griffindodd
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 Ok, so all I'm suggesting is, rather than having to augment every app to monitor every device and display, then report to the server, and have the server transcode HDR to SDR if the device and/or display doesn't support HDR, or pass the HDR metadata to the display, if it supports HDR. Employing PQ at the server transcode level, will provide HDR coloring to everything, without complication. It's a lot less work and maintenance for the devs, and provides a better user experience. What is Perceptual Quantization (EOTF? More detail on PQ
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 (edited) Ok, so all I'm suggesting is, rather than having to augment every app to monitor every device and display, then report to the server, and have the server transcode HDR to SDR if the device and/or display doesn't support HDR, or pass the HDR metadata to the display, if it supports HDR. Employing PQ at the server transcode level, will provide HDR coloring to everything, without complication. It's a lot less work and maintenance for the devs, and provides a better user experience. What is Perceptual Quantization (EOTF? More detail on PQ Sounds like a reasonable approach as the content is being transcoded anyway. Of course if the display DOES support HDR but a transcode is needed for bandwidth or codec reasons then the transcode should try and keep everything in tact yes? Sent from my SM-G955U1 using Tapatalk Edited February 10, 2018 by griffindodd
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 (edited) Sounds like a reasonable approach as the content is being transcoded anyway. Of course if the display DOES support HDR then the transcode should try and keep everything in tact yes? Sent from my SM-G955U1 using Tapatalk That would be good if it could be achieved, I'm just trying to limit how much work the devs have to do, but still offer a happy medium that most people can appreciate. How easy it is for them to implement is not something I can really speculate, on. Edited February 10, 2018 by Doofus
griffindodd 18 Posted February 10, 2018 Author Posted February 10, 2018 (edited) That would be good if it could be achieved, I'm just trying to limit how much work the devs have to do, but still offer a happy medium that most people can appreciate. How easy it is for them to implement is not something I really speculate, on.Yep I'm also in the same place, just trying to bring attention to the problem but unfortunately not able to create a fix/plug in myself due to lack of brains lol. I'm seeing this issue come up a lot in the different media communities, getting out ahead of this could certainly grab a lot of market share for Emby away from the likes of Plex if the solution is built in. HDR isn't going away so having a core solution is going to be needed by all streaming platforms Sent from my SM-G955U1 using Tapatalk Edited February 10, 2018 by griffindodd 1
Guest asrequested Posted February 10, 2018 Posted February 10, 2018 I'm sure it'll be addressed at some point.
vick1982 15 Posted July 7, 2018 Posted July 7, 2018 maybe im confused ..... but is doofus saying that having a hdr display is just a bullshit gimmick and any regular display can look exactly the same using PQ ? 1
Guest asrequested Posted July 7, 2018 Posted July 7, 2018 (edited) maybe im confused ..... but is doofus saying that having a hdr display is just a bullshit gimmick and any regular display can look exactly the same using PQ ? No. There is a color gamut. 10 bit has a larger gamut than 8 bit. You can't use a 10 bit gamut on an 8 bit display. But as HDR is metadata, and can only be directly applied in displays that can use the metadata, perceptual quantization can render the color gamut to the picture, in place of the HDR metadata application. The quandary then becomes, what do you do with the extra colors that an 8 bit display doesn't have the color gamut to display. MPV has the ability to render the metadata and tone map to an 8 bit gamut. The thought I had was that maybe a similar process could be used in transcoding. Right now, when an HDR movie is transcoded, the metadata is simply lost, and the color is 'washed out'. Edited July 7, 2018 by Doofus
Waldonnis 148 Posted July 8, 2018 Posted July 8, 2018 The thought I had was that maybe a similar process could be used in transcoding. It can be. You can actually tonemap with ffmpeg, but it's not as easy as one would think (there's a tonemap filter, but it requires some handholding for this type of task). It's something I've been looking into on and off, but haven't really had time to dig into it. I did find a blog entry about it a while ago (clicky) that was interesting and outlines some of the steps required...and the basic reasoning is sound. I haven't bothered with doing any analysis of the output from his command lines yet to see if additional filters may be useful, though. I also really want to see how some of the players implemented tonemapping and run some histogram comparisons (takes time, so it's a bit low on the list at the moment).
Guest asrequested Posted July 8, 2018 Posted July 8, 2018 It can be. You can actually tonemap with ffmpeg, but it's not as easy as one would think (there's a tonemap filter, but it requires some handholding for this type of task). It's something I've been looking into on and off, but haven't really had time to dig into it. I did find a blog entry about it a while ago (clicky) that was interesting and outlines some of the steps required...and the basic reasoning is sound. I haven't bothered with doing any analysis of the output from his command lines yet to see if additional filters may be useful, though. I also really want to see how some of the players implemented tonemapping and run some histogram comparisons (takes time, so it's a bit low on the list at the moment). Interesting. I've bookmarked that for later reference. That maybe too labor intensive to add to the server...at least not without a warning. But maybe using h264, it might be ok.
Waldonnis 148 Posted July 8, 2018 Posted July 8, 2018 Interesting. I've bookmarked that for later reference. That maybe too labor intensive to add to the server...at least not without a warning. But maybe using h264, it might be ok. It may not be that much more intensive, actually, but I've never measured it. It's getting it worked into the existing filterchain that requires some thought. I also don't know what impact it would have on hardware encoding or what may need to be changed that way. Ultimately, it's all math and is probably a lot less intensive than encoding is, so it shouldn't be all that bad. I just haven't run benchmarks or any other analysis yet to see how much more of a burden it would be quite yet. I'd also like to check for issues when downscaling, since I'd expect most non-HDR monitors are 1080p (and most HDR sources are 2160p). I'd hate to introduce aberrations or unnecessary banding because the order of filterchain operations wasn't well thought out. Of course, 10->8 bit tonemapping would be handy for h.264 Hi10p as well (mostly anime), so you'd see benefits with those types of 1080p sources.
