kribby 0 Posted February 24, 2021 Posted February 24, 2021 (edited) 1 hour ago, softworkz said: There is no forcing of software tone mapping. To be honest, I'm not sure whether the dropdown selection is a good choice. The original concept is what you can see in the Diagnostics Plugin. There are two checkboxes, one for enabling software tone mapping and another one for enabling hardware tone mapping: ...which translates to: "use sw tone mapping when sw transcoding" and "use hw tone mapping when hw transcoding" But those options have no influence on whether sw or hw transcoding is used. Would the two-checkbox variant be more clear? When "Enable hardware acceleration when available" is set to no, is there any point in showing the HW tone mapping option to users? Also, would there be any scenario where users would want software tone mapping only, even when hardware tone mapping was available to them? Edited February 24, 2021 by kribby
Luke 42255 Posted February 24, 2021 Posted February 24, 2021 29 minutes ago, kribby said: When "Enable hardware acceleration when available" is set to no, is there any point in showing the HW tone mapping option to users? Also, would there be any scenario where users would want software tone mapping only, even when hardware tone mapping was available to them? As of today, enabling tone mapping with cpu only is probably only for those who want to try it out of curiosity. I'm not sure many will want to actually do that on a regular basis. Over time of course, with newer machines and improvements to the algorithms, that could change.
cryzis 7 Posted February 24, 2021 Posted February 24, 2021 29 minutes ago, kribby said: When "Enable hardware acceleration when available" is set to no, is there any point in showing the HW tone mapping option to users? Also, would there be any scenario where users would want software tone mapping only, even when hardware tone mapping was available to them? Kribby, I prefer when options are explicit in what they do. What you are describing sounds like emby should be making these decisions for the user. In an ideal world emby would install and have no options, it would do its job with the least amount of configuration as possible. To do that the software would need way more information than it has access to. In this instance it can not possibly know what is the best situation for a users given use case + hardware configuration. with that I I appreciate the very explicit configuration attempt. The only bit that is unclear is priority order. If both are enabled I want a way to order which is used first and I would expect the other to work as a fallback. If the other is never used as a fallback then I would expect to only be able to select one of these options at a time.
softworkz 5133 Posted February 24, 2021 Posted February 24, 2021 40 minutes ago, kribby said: When "Enable hardware acceleration when available" is set to no, is there any point in showing the HW tone mapping option to users? In case of the combo box selection yes! Imagine the following situation: User has hwa enabled User has set tone mapping to hw Now, user sets hwa to disabled What should the drop down show now, when you say it should hide the hw tone mapping option? An empty entry? The software entry? The None entry? When the user saves next time, he would save that change to the server Now, he re-enables hwa But hw tone mapping is no longer enabled => which is unexpected, the user has just disabled and re-enabled hwa, but that shouldn't modify other options! 40 minutes ago, kribby said: Also, would there be any scenario where users would want software tone mapping only, even when hardware tone mapping was available to them? Yes, in many cases: HW cannot do tone mapping HW doesn't support a certain transcoding setup (e.g. codec, pixel format, profile, level, etc.) Processing is forced to happen in software (e.g. due to subtitle burn-in) A user's CPU is faster than the GPU (hw tone mapping is not always so much in advance as you might think, as long as you don't have an Nvidia card) Our CPU tone mapping is pretty fast, have you even tried?
softworkz 5133 Posted February 24, 2021 Posted February 24, 2021 (edited) 26 minutes ago, Luke said: As of today, enabling tone mapping with cpu only is probably only for those who want to try it out of curiosity. I'm not sure many will want to actually do that on a regular basis. You seem to have missed Rigg's feedback.. 26 minutes ago, Luke said: Over time of course, with newer machines and improvements to the algorithms, that could change. The implementation is already pretty much at the edge of what's possible, using a lot of tricks. Parallelism is the key for getting even faster. Our implementation is using up to SSE2 features. A separate optimized implementation for AVX or AVX2 would be possible, but limited to newer CPU models. Edited February 24, 2021 by softworkz
softworkz 5133 Posted February 24, 2021 Posted February 24, 2021 32 minutes ago, cryzis said: with that I I appreciate the very explicit configuration attempt. The only bit that is unclear is priority order. If both are enabled I want a way to order which is used first and I would expect the other to work as a fallback. You actually CAN order the codecs. The topmost has the highest priority. 32 minutes ago, cryzis said: If the other is never used as a fallback then I would expect to only be able to select one of these options at a time. It works like this: For each transcoding, Emby tries to find a matching hw codec setup First, It will look for a suitable encoder It starts with the first one in the list (according to the order you have conrfigured) Each encoder is checked whether it's suitable by checking max resolution and framerate, supported codec profiles and levels, supported color formats and one or two other things It does that until it finds one, otherwise, software encoding is used If a hw encoder is found, a similar process starts for decoders, only that now it also checks whether the decoder can be combined with the encoder (same hw context) So, your order DOES really matter. It's just that when you have a very recent CPU+iGPU and a recent discrete GPU, you might rarely see that the second in the list is chosen because both GPUs can do the same. (unless you try an 8k video for example..
kribby 0 Posted February 24, 2021 Posted February 24, 2021 48 minutes ago, softworkz said: In case of the combo box selection yes! Imagine the following situation: User has hwa enabled User has set tone mapping to hw Now, user sets hwa to disabled What should the drop down show now, when you say it should hide the hw tone mapping option? An empty entry? The software entry? The None entry? When the user saves next time, he would save that change to the server Now, he re-enables hwa But hw tone mapping is no longer enabled => which is unexpected, the user has just disabled and re-enabled hwa, but that shouldn't modify other options! Yes, in many cases: HW cannot do tone mapping HW doesn't support a certain transcoding setup (e.g. codec, pixel format, profile, level, etc.) Processing is forced to happen in software (e.g. due to subtitle burn-in) A user's CPU is faster than the GPU (hw tone mapping is not always so much in advance as you might think, as long as you don't have an Nvidia card) Our CPU tone mapping is pretty fast, have you even tried? I apologize for asking questions before, because it appears I still don't have a solid grasp on how all this works yet. Is it technically possible to have a hardware accelerated transcode using software tone mapping?
softworkz 5133 Posted February 24, 2021 Posted February 24, 2021 2 minutes ago, kribby said: I apologize for asking questions before, because it appears I still don't have a solid grasp on how all this works yet. Is it technically possible to have a hardware accelerated transcode using software tone mapping? Technically, yes - but we don't do that right now. We do mixed processing pipelines, though, where one side is hw and the other sw or vice-versa, and for subtitle overlay also hw on both sides (encoding and decoding). But when one side is hw, we also try to setup hw tone mapping. It's a complex logic and as of now, I'm sure to say that nobody can do this better than us
kribby 0 Posted February 24, 2021 Posted February 24, 2021 8 minutes ago, softworkz said: Technically, yes - but we don't do that right now. We do mixed processing pipelines, though, where one side is hw and the other sw or vice-versa, and for subtitle overlay also hw on both sides (encoding and decoding). But when one side is hw, we also try to setup hw tone mapping. It's a complex logic and as of now, I'm sure to say that nobody can do this better than us Oh, okay. That would explain why the same scenario didn't work for me the other day. If tonemap_vaapi doesn't have any option to change the algorithm, then I could see the importance of mixing HW transcoding with SW tonemapping
softworkz 5133 Posted February 24, 2021 Posted February 24, 2021 20 minutes ago, kribby said: Oh, okay. That would explain why the same scenario didn't work for me the other day. If tonemap_vaapi doesn't have any option to change the algorithm, then I could see the importance of mixing HW transcoding with SW tonemapping In the next (or subsequent) beta, you'll be able to use OpenCL tone mapping with VAAPI as an alternative, and there you can change the algorithm as well.
PontusN 12 Posted March 4, 2021 Posted March 4, 2021 (edited) @softworkzFollow up question to a previous post I made. Transcoding stopped working for me with intel-VAAPI for some reason*** (Ubuntu). So I installed intels media sdk to get quicksync instead. This works, but tonemapping does not for some reason. According to the logs everything seems to work just fine (by my eyes), but the colors are still washed out. ***This was the reason, it tried using HW VAAPI but fails and falls back to SW: 14:51:19.855 Metadata: 14:51:19.855 encoder : Lavf58.35.100 14:51:19.855 Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 6616 kb/s, Level 31, 23.98 fps, 90k tbn, 23.98 tbc (default) 14:51:19.855 Metadata: 14:51:19.855 encoder : Lavc58.62.100 h264_vaapi 14:51:19.855 Stream #0:1(eng): Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (default) 14:51:19.855 Metadata: 14:51:19.855 encoder : Lavc58.62.100 libmp3lame 14:51:19.904 [tonemap_vaapi@f2 @ 0x15a5180] No mastering display data from input 14:51:19.904 Error while filtering: Invalid argument 14:51:19.904 Failed to inject frame into filter network: Invalid argument 14:51:19.904 Error while processing the decoded data for stream #0:0 14:51:19.914 [libmp3lame @ 0x10dbe00] 3 frames left in the queue on closing 14:51:19.950 Conversion failed! ffmpeg-transcode-7a153df8-ba9a-4024-97de-0be6c33e8090_1.txt Edited March 4, 2021 by PontusN
niallobr 9 Posted March 9, 2021 Posted March 9, 2021 I convert all my files using sickbeard_mp4_automator and have intel-VAAPI hardware transcoding on my server. In the two files below the tracks are very similar since they've been converted using the same process, however one file gets transcoded using tone mapping with hardware acceleration while the other gets a software transcode for the tone mapping. Any idea what would cause this would happen when the files are so similar?
softworkz 5133 Posted March 9, 2021 Posted March 9, 2021 On 3/4/2021 at 3:41 PM, PontusN said: @softworkzFollow up question to a previous post I made. Transcoding stopped working for me with intel-VAAPI for some reason*** (Ubuntu). So I installed intels media sdk to get quicksync instead. This works, but tonemapping does not for some reason. According to the logs everything seems to work just fine (by my eyes), but the colors are still washed out. ***This was the reason, it tried using HW VAAPI but fails and falls back to SW: 14:51:19.855 Metadata: 14:51:19.855 encoder : Lavf58.35.100 14:51:19.855 Stream #0:0: Video: h264 (h264_vaapi) (High), vaapi_vld, 1280x720 [SAR 1:1 DAR 16:9], q=-1--1, 6616 kb/s, Level 31, 23.98 fps, 90k tbn, 23.98 tbc (default) 14:51:19.855 Metadata: 14:51:19.855 encoder : Lavc58.62.100 h264_vaapi 14:51:19.855 Stream #0:1(eng): Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (default) 14:51:19.855 Metadata: 14:51:19.855 encoder : Lavc58.62.100 libmp3lame 14:51:19.904 [tonemap_vaapi@f2 @ 0x15a5180] No mastering display data from input 14:51:19.904 Error while filtering: Invalid argument 14:51:19.904 Failed to inject frame into filter network: Invalid argument 14:51:19.904 Error while processing the decoded data for stream #0:0 14:51:19.914 [libmp3lame @ 0x10dbe00] 3 frames left in the queue on closing 14:51:19.950 Conversion failed! ffmpeg-transcode-7a153df8-ba9a-4024-97de-0be6c33e8090_1.txt 400.85 kB · 1 download @PontusN - Tone mapping (especially with VAAPI) does not work when a video doesn't include the required metadata
vick1982 15 Posted March 14, 2021 Posted March 14, 2021 (edited) not sure if should ask here but i am doing this for tone mapping anyway and its just related.... so i installed a gtx 1050 to use for hardware transcoding etc.. I have done the patch to make unlimited from the 2 limit.. but its still only letting me do 2 on emby and the 3rd is just software transcoding... is there something I have to do or is the patch just not working ? Edited March 14, 2021 by vick1982
Carlo 4561 Posted March 14, 2021 Posted March 14, 2021 Did you test it outside Emby to make sure you got the patch done correctly?
vick1982 15 Posted March 14, 2021 Posted March 14, 2021 Just now, cayars said: Did you test it outside Emby to make sure you got the patch done correctly? how do i do that ? sorry if thats a dumb question
Carlo 4561 Posted March 14, 2021 Posted March 14, 2021 Try this and set it to 4 encodes https://sourceforge.net/projects/ffmpeg-batch/
vick1982 15 Posted March 15, 2021 Posted March 15, 2021 Got the unlock patch working now... Just a question... How will it know to tone map on direct play with a device that doesn't have HDR ? Or it won't tone map for direct play ?
ebr 16346 Posted March 15, 2021 Posted March 15, 2021 18 minutes ago, vick1982 said: Or it won't tone map for direct play ? If the item is direct playing then the only opportunity for tone-mapping will be on the end device. The server is just feeding the file. What we still need to build in is a way for apps to tell the server that it needs to transcode in order to do the tone-map.
Carlo 4561 Posted March 15, 2021 Posted March 15, 2021 So for right now with tone mapping "smarts" only in the server and not added to apps yet you would have to force a transcode if it was direct playing and you're device can't tone map.
vick1982 15 Posted March 20, 2021 Posted March 20, 2021 not a big deal.. but would be nice if it also showed it was tone-mapping in the dashboard / active devices screen 1
softworkz 5133 Posted March 20, 2021 Posted March 20, 2021 12 minutes ago, vick1982 said: not a big deal.. but would be nice if it also showed it was tone-mapping in the dashboard / active devices screen Until it will be added to the main UI: 3
vick1982 15 Posted March 20, 2021 Posted March 20, 2021 (edited) 41 minutes ago, softworkz said: Until it will be added to the main UI: thanks for the reply... that's great Edited March 20, 2021 by softworkz Moved reply text out of quote region 1
Mkilbride 86 Posted April 11, 2021 Posted April 11, 2021 So I just downloaded the Server Beta and tried this out. I am wondering if there's an option for devices that support native playback without trasncoding, but don't have HDR? For example - I have a 4K HDR Remux of a movie. On my phone, it defaults to "Direct Play". My phone however - does not support HDR. So I was getting no tonemapping. Forcing it to transcode causes it to be tonemapped and displays as expected.
