neodago 3 Posted February 9, 2018 Posted February 9, 2018 Good morning all! I have another strange problem vith the Trakt plugin: in my emby library I have the show "My Boss, My Hero (2006)", a Japan Drama, that is corecty detected by the server (IMDb Id: tt0880249, TheTVDB Id: 85091), but when I go in the Trakt history I see that the show is not correct, Trakt shows another show, the korean version of the same drama, but the Id is different (obviously). I searched in the log, but I didn't found the error, can someone help me? This is the log: 2018-02-09 11:01:24.249 Info Main: Application path: C:\Users\neoda\AppData\Roaming\Emby-Server\system\EmbyServer.dll 2018-02-09 11:01:24.260 Info Main: Emby Command line: C:\Users\neoda\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\neoda\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: C:\Users\neoda\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\neoda\AppData\Roaming\Emby-Server\system 2018-02-09 11:01:24.713 Info Main: Tray icon path: C:\Users\neoda\AppData\Roaming\Emby-Server\system\electron\embytray 2018-02-09 11:01:25.227 Info App: Application version: 3.2.70.0 2018-02-09 11:01:25.230 Info App: Loading assemblies 2018-02-09 11:01:25.966 Info App: Loading Trakt, Version=3.1.4.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading MediaBrowser.Api, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading MediaBrowser.WebDashboard, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading MediaBrowser.Model, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading MediaBrowser.Common, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading MediaBrowser.Controller, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading MediaBrowser.Providers, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading Emby.Photos, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading Emby.Server.Implementations, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading Emby.Server.MediaEncoding, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.966 Info App: Loading Emby.Dlna, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.967 Info App: Loading MediaBrowser.LocalMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.967 Info App: Loading MediaBrowser.XbmcMetadata, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.967 Info App: Loading Emby.Server.CinemaMode, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.967 Info App: Loading Emby.Server.Connect, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:25.967 Info App: Loading Emby.Server.Sync, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2018-02-09 11:01:26.698 Info SqliteUserRepository: Sqlite version: 3.21.0 2018-02-09 11:01:26.699 Info SqliteUserRepository: Sqlite compiler options: COMPILER=msvc-1500,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,MAX_TRIGGER_DEPTH=100,TEMP_STORE=1,THREADSAFE=1 2018-02-09 11:01:26.814 Info SqliteUserRepository: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\users.db is wal 2018-02-09 11:01:26.819 Info SqliteUserRepository: PRAGMA synchronous=1 2018-02-09 11:01:26.856 Info AuthenticationRepository: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\authentication.db is wal 2018-02-09 11:01:26.856 Info AuthenticationRepository: PRAGMA synchronous=1 2018-02-09 11:01:26.927 Info DeviceManager: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\devices.db is wal 2018-02-09 11:01:26.927 Info DeviceManager: PRAGMA synchronous=1 2018-02-09 11:01:26.962 Info ActivityRepository: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\activitylog.db is wal 2018-02-09 11:01:26.962 Info ActivityRepository: PRAGMA synchronous=1 2018-02-09 11:01:26.967 Info SqliteDisplayPreferencesRepository: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\displaypreferences.db is wal 2018-02-09 11:01:26.967 Info SqliteDisplayPreferencesRepository: PRAGMA synchronous=1 2018-02-09 11:01:26.978 Info SqliteItemRepository: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\library.db is wal 2018-02-09 11:01:26.978 Info SqliteItemRepository: PRAGMA synchronous=1 2018-02-09 11:01:27.011 Info SqliteNotificationsRepository: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\notifications.db is wal 2018-02-09 11:01:27.011 Info SqliteNotificationsRepository: PRAGMA synchronous=1 2018-02-09 11:01:27.158 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\users\954ceb50a54a4ffab610dd4ed30c04ac\policy.xml 2018-02-09 11:01:27.378 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\encoding.xml 2018-02-09 11:01:27.544 Info HttpServer: Calling ServiceStack AppHost.Init 2018-02-09 11:01:28.534 Info ServerManager: Loading Http Server 2018-02-09 11:01:28.544 Info HttpServer: Adding HttpListener prefix http://+:8096/ 2018-02-09 11:01:28.546 Info HttpServer: Adding HttpListener prefix https://+:8920/ 2018-02-09 11:01:28.840 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:28.878 Info HttpServer: HTTP Response 503 to 127.0.0.1. Time: 48ms. http://localhost:8096/emby/System/Info 2018-02-09 11:01:29.112 Info Skia: SkiaSharp version: 1.58.0.0 2018-02-09 11:01:29.148 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\5e47e7d3-542a-ce9c-3676-91a65cb31e86.js 2018-02-09 11:01:29.194 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\5e47e7d3-542a-ce9c-3676-91a65cb31e86.js 2018-02-09 11:01:29.213 Info TaskManager: Daily trigger for Import playstates from Trakt.tv set to fire at 10/02/2018 00:00:00, which is 778.513116183333 minutes from now. 2018-02-09 11:01:29.213 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\b1a52e63-d5fb-0933-5557-d4f1e6402299.js 2018-02-09 11:01:29.219 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\b1a52e63-d5fb-0933-5557-d4f1e6402299.js 2018-02-09 11:01:29.219 Info TaskManager: Daily trigger for Sync library to trakt.tv set to fire at 10/02/2018 00:30:00, which is 808.513006736667 minutes from now. 2018-02-09 11:01:29.219 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\2c66a88b-ca43-e565-d7f8-099f825478f1.js 2018-02-09 11:01:29.223 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\2c66a88b-ca43-e565-d7f8-099f825478f1.js 2018-02-09 11:01:29.234 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\13e82435-eb8f-2cdc-78c9-e106fb7edd05.js 2018-02-09 11:01:29.235 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\13e82435-eb8f-2cdc-78c9-e106fb7edd05.js 2018-02-09 11:01:29.243 Info TaskManager: Daily trigger for Chapter image extraction set to fire at 10/02/2018 02:00:00, which is 898.512600993333 minutes from now. 2018-02-09 11:01:29.244 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\c623dbe7-7c91-ebed-cb4c-80409cdb79ee.js 2018-02-09 11:01:29.244 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\c623dbe7-7c91-ebed-cb4c-80409cdb79ee.js 2018-02-09 11:01:29.253 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\c27fda37-dfb6-e39b-e141-191aaa1c3060.js 2018-02-09 11:01:29.255 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\c27fda37-dfb6-e39b-e141-191aaa1c3060.js 2018-02-09 11:01:29.270 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\6330ee8f-b4a9-57f3-3981-f89aa78b030f.js 2018-02-09 11:01:29.273 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\6330ee8f-b4a9-57f3-3981-f89aa78b030f.js 2018-02-09 11:01:29.278 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\1cc2f60a-05be-fec8-b153-2ac44630a00f.js 2018-02-09 11:01:29.279 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\1cc2f60a-05be-fec8-b153-2ac44630a00f.js 2018-02-09 11:01:29.285 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\241d4fcb-19a1-d557-ee62-428e411da609.js 2018-02-09 11:01:29.286 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\241d4fcb-19a1-d557-ee62-428e411da609.js 2018-02-09 11:01:29.295 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\1c8ede62-c521-bea0-bf85-1344f5b8ca40.js 2018-02-09 11:01:29.295 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\1c8ede62-c521-bea0-bf85-1344f5b8ca40.js 2018-02-09 11:01:29.301 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\c3f01167-5d86-8fcc-11e2-78b847523ef5.js 2018-02-09 11:01:29.302 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\c3f01167-5d86-8fcc-11e2-78b847523ef5.js 2018-02-09 11:01:29.311 Info TaskManager: Daily trigger for Start new log file set to fire at 10/02/2018 00:00:00, which is 778.511472093333 minutes from now. 2018-02-09 11:01:29.311 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\3145e441-d9ba-27fc-391e-7ee15face581.js 2018-02-09 11:01:29.312 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\3145e441-d9ba-27fc-391e-7ee15face581.js 2018-02-09 11:01:29.318 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\7a7448c2-61fa-47f3-46b4-c061a5d5c163.js 2018-02-09 11:01:29.319 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\7a7448c2-61fa-47f3-46b4-c061a5d5c163.js 2018-02-09 11:01:29.328 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\a27c5425-9520-b2e5-c509-def68c8f4c45.js 2018-02-09 11:01:29.329 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\a27c5425-9520-b2e5-c509-def68c8f4c45.js 2018-02-09 11:01:29.334 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\9be21c93-4ee4-4926-9f41-b7c2b4d4d1d7.js 2018-02-09 11:01:29.335 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\9c4589c7-1219-6c27-894f-665a58cc42e3.js 2018-02-09 11:01:29.336 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\9c4589c7-1219-6c27-894f-665a58cc42e3.js 2018-02-09 11:01:29.336 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\ScheduledTasks\8542b8a0-0478-ef9d-9a59-0e7f2e3b62da.js 2018-02-09 11:01:29.336 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\8542b8a0-0478-ef9d-9a59-0e7f2e3b62da.js 2018-02-09 11:01:29.369 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:29.369 Info HttpServer: HTTP Response 503 to 127.0.0.1. Time: 0ms. http://localhost:8096/emby/System/Info 2018-02-09 11:01:29.473 Info MediaEncoder: FFMpeg: C:\Users\neoda\AppData\Roaming\Emby-Server\system\ffmpeg.exe 2018-02-09 11:01:29.473 Info MediaEncoder: FFProbe: C:\Users\neoda\AppData\Roaming\Emby-Server\system\ffprobe.exe 2018-02-09 11:01:29.474 Info MediaEncoder: Validating media encoder at C:\Users\neoda\AppData\Roaming\Emby-Server\system\ffmpeg.exe 2018-02-09 11:01:29.479 Info MediaEncoder: Running C:\Users\neoda\AppData\Roaming\Emby-Server\system\ffmpeg.exe -decoders 2018-02-09 11:01:29.829 Info MediaEncoder: Decoder available: mpeg2video 2018-02-09 11:01:29.829 Info MediaEncoder: Decoder available: h264_qsv 2018-02-09 11:01:29.829 Info MediaEncoder: Decoder available: hevc_qsv 2018-02-09 11:01:29.829 Info MediaEncoder: Decoder available: mpeg2_qsv 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: vc1_qsv 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: h264_cuvid 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: hevc_cuvid 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: mpeg2_cuvid 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: mpeg4_cuvid 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: vc1_cuvid 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: vp8_cuvid 2018-02-09 11:01:29.830 Info MediaEncoder: Decoder available: vp9_cuvid 2018-02-09 11:01:29.831 Info MediaEncoder: Decoder available: ac3 2018-02-09 11:01:29.831 Info MediaEncoder: Decoder available: aac 2018-02-09 11:01:29.831 Info MediaEncoder: Decoder available: mp3 2018-02-09 11:01:29.831 Info MediaEncoder: Decoder available: h264 2018-02-09 11:01:29.831 Info MediaEncoder: Decoder available: hevc 2018-02-09 11:01:29.834 Info MediaEncoder: Running C:\Users\neoda\AppData\Roaming\Emby-Server\system\ffmpeg.exe -encoders 2018-02-09 11:01:29.879 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:29.879 Info HttpServer: HTTP Response 503 to ::1. Time: 1ms. http://localhost:8096/emby/System/Info 2018-02-09 11:01:30.182 Info MediaEncoder: Encoder available: libx264 2018-02-09 11:01:30.182 Info MediaEncoder: Encoder available: libx265 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: mpeg4 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: msmpeg4 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: libvpx 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: libvpx-vp9 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: aac 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: libmp3lame 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: libopus 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: libvorbis 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: srt 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: h264_nvenc 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: hevc_nvenc 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: h264_qsv 2018-02-09 11:01:30.183 Info MediaEncoder: Encoder available: hevc_qsv 2018-02-09 11:01:30.184 Info MediaEncoder: Encoder available: libwebp 2018-02-09 11:01:30.184 Info MediaEncoder: Encoder available: ac3 2018-02-09 11:01:30.184 Info MediaEncoder: Encoder validation complete 2018-02-09 11:01:30.199 Info App: ServerId: 2ab59232ff3f4b2fb1a05efd6c9a77b6 2018-02-09 11:01:30.199 Info App: Core startup complete 2018-02-09 11:01:30.199 Info App: Post-init migrations complete 2018-02-09 11:01:30.258 Info App: Starting entry point Trakt.ServerMediator 2018-02-09 11:01:30.260 Info App: Entry point completed: Trakt.ServerMediator. Duration: 0.0025058 seconds 2018-02-09 11:01:30.260 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2018-02-09 11:01:30.260 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 7.15E-05 seconds 2018-02-09 11:01:30.260 Info App: Starting entry point MediaBrowser.WebDashboard.ServerEntryPoint 2018-02-09 11:01:30.261 Info App: Entry point completed: MediaBrowser.WebDashboard.ServerEntryPoint. Duration: 0.0010709 seconds 2018-02-09 11:01:30.261 Info App: Starting entry point Emby.Server.Implementations.Notifications.Notifications 2018-02-09 11:01:30.269 Info App: Entry point completed: Emby.Server.Implementations.Notifications.Notifications. Duration: 0.0078842 seconds 2018-02-09 11:01:30.269 Info App: Starting entry point Emby.Server.Implementations.Notifications.WebSocketNotifier 2018-02-09 11:01:30.276 Info App: Entry point completed: Emby.Server.Implementations.Notifications.WebSocketNotifier. Duration: 0.0064307 seconds 2018-02-09 11:01:30.276 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2018-02-09 11:01:30.278 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0019496 seconds 2018-02-09 11:01:30.278 Info App: Starting entry point Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint 2018-02-09 11:01:30.282 Info App: Loading live tv data from C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\livetv\timers 2018-02-09 11:01:30.283 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\livetv\timers.json 2018-02-09 11:01:30.293 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\livetv.xml 2018-02-09 11:01:30.391 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:30.635 Info App: App Activity: app: Emby Mobile, version: 3.2.70.0, deviceId: e08c044230279216d40c241b9f161fef4de305ed, deviceName: Chrome 2018-02-09 11:01:30.797 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\root\default\Anime\options.xml 2018-02-09 11:01:30.864 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\root\default\Drama\options.xml 2018-02-09 11:01:30.872 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\root\default\Film\options.xml 2018-02-09 11:01:30.896 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\root\default\Film Giapponesi\options.xml 2018-02-09 11:01:30.909 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\root\default\Serie Tv\options.xml 2018-02-09 11:01:30.933 Info App: Entry point completed: Emby.Server.Implementations.LiveTv.EmbyTV.EntryPoint. Duration: 0.6550938 seconds 2018-02-09 11:01:30.933 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2018-02-09 11:01:31.032 Info HttpClient: GET: http://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2018-02-09 11:01:31.055 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 0.1213065 seconds 2018-02-09 11:01:31.055 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2018-02-09 11:01:31.056 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0008437 seconds 2018-02-09 11:01:31.056 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ExternalPortForwarding 2018-02-09 11:01:31.095 Info LibraryMonitor: Watching directory \\nas4free\xbmc\Video\Anime HD 2018-02-09 11:01:31.103 Debug PortMapper: Starting NAT discovery 2018-02-09 11:01:31.111 Info LibraryMonitor: Watching directory \\NAS4FREE\xbmc\Video\Film HD 2018-02-09 11:01:31.111 Info LibraryMonitor: Watching directory I:\Video\Fansub\Dorama e LiveAction 2018-02-09 11:01:31.111 Info LibraryMonitor: Watching directory I:\Video\Fansub\Film 2018-02-09 11:01:31.126 Info LibraryMonitor: Watching directory \\NAS4FREE\xbmc\Video\Serie TV 2018-02-09 11:01:31.157 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ExternalPortForwarding. Duration: 0.1008595 seconds 2018-02-09 11:01:31.157 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake 2018-02-09 11:01:31.157 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.KeepServerAwake. Duration: 0.0003552 seconds 2018-02-09 11:01:31.157 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier 2018-02-09 11:01:31.160 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LibraryChangedNotifier. Duration: 0.0029052 seconds 2018-02-09 11:01:31.160 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.LoadRegistrations 2018-02-09 11:01:31.161 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.LoadRegistrations. Duration: 0.0011133 seconds 2018-02-09 11:01:31.161 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.RecordingNotifier 2018-02-09 11:01:31.166 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.RecordingNotifier. Duration: 0.0045926 seconds 2018-02-09 11:01:31.166 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.ServerEventNotifier 2018-02-09 11:01:31.173 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.ServerEventNotifier. Duration: 0.0075693 seconds 2018-02-09 11:01:31.175 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.StartupWizard 2018-02-09 11:01:31.177 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.StartupWizard. Duration: 0.002073 seconds 2018-02-09 11:01:31.177 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.SystemEvents 2018-02-09 11:01:31.178 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.SystemEvents. Duration: 0.0006735 seconds 2018-02-09 11:01:31.178 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint 2018-02-09 11:01:31.184 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UdpServerEntryPoint. Duration: 0.0058142 seconds 2018-02-09 11:01:31.184 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UsageEntryPoint 2018-02-09 11:01:31.189 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UsageEntryPoint. Duration: 0.0052423 seconds 2018-02-09 11:01:31.189 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier 2018-02-09 11:01:31.190 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.UserDataChangeNotifier. Duration: 0.000401 seconds 2018-02-09 11:01:31.190 Info App: Starting entry point Emby.Server.Implementations.Channels.ChannelsEntryPoint 2018-02-09 11:01:31.194 Info App: Entry point completed: Emby.Server.Implementations.Channels.ChannelsEntryPoint. Duration: 0.0042059 seconds 2018-02-09 11:01:31.194 Info App: Starting entry point Emby.Server.Implementations.Activity.ActivityLogEntryPoint 2018-02-09 11:01:31.201 Info App: Entry point completed: Emby.Server.Implementations.Activity.ActivityLogEntryPoint. Duration: 0.0071128 seconds 2018-02-09 11:01:31.201 Info App: Starting entry point Emby.Server.MediaEncoding.Api.ApiEntryPoint 2018-02-09 11:01:31.207 Info App: Entry point completed: Emby.Server.MediaEncoding.Api.ApiEntryPoint. Duration: 0.0058196 seconds 2018-02-09 11:01:31.207 Info App: Starting entry point Emby.Dlna.DlnaProfileEntryPoint 2018-02-09 11:01:31.207 Info App: Entry point completed: Emby.Dlna.DlnaProfileEntryPoint. Duration: 0.0001165 seconds 2018-02-09 11:01:31.208 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2018-02-09 11:01:31.228 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Default.xml 2018-02-09 11:01:31.370 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\users\954ceb50a54a4ffab610dd4ed30c04ac\config.xml 2018-02-09 11:01:31.468 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Denon AVR.xml 2018-02-09 11:01:31.489 Error HttpServer: Error processing request *** Error Report *** Version: 3.2.70.0 Command line: C:\Users\neoda\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\neoda\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 2 Program data path: C:\Users\neoda\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\neoda\AppData\Roaming\Emby-Server\system System.NullReferenceException: Object reference not set to an instance of an object. at Emby.Server.Connect.ConnectManager.IsAuthorizationTokenValid(String token) at Emby.Server.Implementations.HttpServer.Security.AuthService.ValidateUser(IRequest request, IAuthenticationAttributes authAttribtues) at Emby.Server.Implementations.HttpServer.HttpListenerHost.ApplyRequestFilters(IRequest req, IResponse res, Object requestDto) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__73.MoveNext() System.NullReferenceException at Emby.Server.Connect.ConnectManager.IsAuthorizationTokenValid(String token) at Emby.Server.Implementations.HttpServer.Security.AuthService.ValidateUser(IRequest request, IAuthenticationAttributes authAttribtues) at Emby.Server.Implementations.HttpServer.HttpListenerHost.ApplyRequestFilters(IRequest req, IResponse res, Object requestDto) at Emby.Server.Implementations.Services.ServiceHandler.<ProcessRequestAsync>d__15.MoveNext() --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task) at Emby.Server.Implementations.HttpServer.HttpListenerHost.<RequestHandler>d__73.MoveNext() 2018-02-09 11:01:31.490 Info HttpServer: HTTP Response 500 to ::1. Time: 1099ms (slow). http://localhost:8096/emby/System/Info 2018-02-09 11:01:31.498 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\DirecTV HD-DVR.xml 2018-02-09 11:01:31.521 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Dish Hopper-Joey.xml 2018-02-09 11:01:31.540 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\foobar2000.xml 2018-02-09 11:01:31.550 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\LG Smart TV.xml 2018-02-09 11:01:31.572 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Linksys DMA2100.xml 2018-02-09 11:01:31.579 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Marantz.xml 2018-02-09 11:01:31.586 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\MediaMonkey.xml 2018-02-09 11:01:31.595 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Panasonic Viera.xml 2018-02-09 11:01:31.606 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Popcorn Hour.xml 2018-02-09 11:01:31.614 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Samsung Smart TV.xml 2018-02-09 11:01:31.622 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sharp Smart TV.xml 2018-02-09 11:01:31.630 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Blu-ray Player 2013.xml 2018-02-09 11:01:31.636 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Blu-ray Player 2014.xml 2018-02-09 11:01:31.645 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Blu-ray Player 2015.xml 2018-02-09 11:01:31.652 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Blu-ray Player 2016.xml 2018-02-09 11:01:31.660 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Blu-ray Player.xml 2018-02-09 11:01:31.667 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Bravia (2010).xml 2018-02-09 11:01:31.677 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Bravia (2011).xml 2018-02-09 11:01:31.684 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Bravia (2012).xml 2018-02-09 11:01:31.696 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Bravia (2013).xml 2018-02-09 11:01:31.703 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony Bravia (2014).xml 2018-02-09 11:01:31.712 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony PlayStation 3.xml 2018-02-09 11:01:31.726 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Sony PlayStation 4.xml 2018-02-09 11:01:31.734 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\WDTV Live.xml 2018-02-09 11:01:31.745 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna\system\Xbox One.xml 2018-02-09 11:01:31.758 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\dlna.xml 2018-02-09 11:01:31.926 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.718525 seconds 2018-02-09 11:01:31.926 Info App: Starting entry point MediaBrowser.XbmcMetadata.EntryPoint 2018-02-09 11:01:31.927 Info App: Entry point completed: MediaBrowser.XbmcMetadata.EntryPoint. Duration: 0.0005505 seconds 2018-02-09 11:01:31.927 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-02-09 11:01:31.927 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 7.88E-05 seconds 2018-02-09 11:01:31.927 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2018-02-09 11:01:31.927 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0002768 seconds 2018-02-09 11:01:31.931 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2018-02-09 11:01:31.933 Info App: Loading data from C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\connect.txt 2018-02-09 11:01:31.949 Info App: Loading data from C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\wan.dat 2018-02-09 11:01:31.985 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.0537292 seconds 2018-02-09 11:01:31.985 Info App: Starting entry point Emby.Security.PluginSecurityManager 2018-02-09 11:01:31.985 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 9.49E-05 seconds 2018-02-09 11:01:31.985 Info App: Starting entry point Emby.Server.Sync.SyncManagerEntryPoint 2018-02-09 11:01:32.001 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:32.028 Info App: Sqlite version: 3.21.0 2018-02-09 11:01:32.029 Info App: Sqlite compiler options: COMPILER=msvc-1500,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_RTREE,MAX_TRIGGER_DEPTH=100,TEMP_STORE=1,THREADSAFE=1 2018-02-09 11:01:32.057 Debug App: Ping test result to http://192.168.0.20:8096/system/ping. Success: True 2018-02-09 11:01:32.068 Debug App: Ping test result to http://192.168.0.20:8096/system/ping. Success: True 2018-02-09 11:01:32.080 Info App: Default journal_mode for C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\sync14.db is wal 2018-02-09 11:01:32.083 Info App: PRAGMA synchronous=1 2018-02-09 11:01:32.086 Info App: Entry point completed: Emby.Server.Sync.SyncManagerEntryPoint. Duration: 0.100996 seconds 2018-02-09 11:01:32.086 Info App: Starting entry point Emby.Server.Sync.SyncNotificationEntryPoint 2018-02-09 11:01:32.088 Debug App: Ping test result to http://192.168.0.20:8096/system/ping. Success: True 2018-02-09 11:01:32.092 Info App: Entry point completed: Emby.Server.Sync.SyncNotificationEntryPoint. Duration: 0.0064934 seconds 2018-02-09 11:01:32.092 Info App: All entry points have started 2018-02-09 11:01:32.094 Debug App: Ping test result to http://[fe80::e0c6:9493:31a7:6279%2]:8096/system/ping. Success: True 2018-02-09 11:01:32.101 Debug App: Ping test result to http://[2001:0:9d38:6abd:24b6:2fa5:b0e6:c3be]:8096/system/ping. Success: True 2018-02-09 11:01:32.113 Debug App: Ping test result to http://[fe80::24b6:2fa5:b0e6:c3be%4]:8096/system/ping. Success: True 2018-02-09 11:01:32.114 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 192.168.0.20 2018-02-09 11:01:32.134 Debug Dlna: Device Added MediaServer - 2ab59232ff3f4b2fb1a05efd6c9a77b6 - http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.136 Debug Dlna: Rebroadcast Interval = 00:00:30, Next Broadcast At = 00:00:30 2018-02-09 11:01:32.177 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::e0c6:9493:31a7:6279%2 2018-02-09 11:01:32.177 Debug Dlna: Device Added MediaServer - 2ab59232ff3f4b2fb1a05efd6c9a77b6 - http://[fe80::e0c6:9493:31a7:6279]:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.177 Debug Dlna: Rebroadcast Interval = 00:00:30, Next Broadcast At = 00:00:30 2018-02-09 11:01:32.181 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on 2001:0:9d38:6abd:24b6:2fa5:b0e6:c3be 2018-02-09 11:01:32.181 Debug Dlna: Device Added MediaServer - 2ab59232ff3f4b2fb1a05efd6c9a77b6 - http://[2001:0:9d38:6abd:24b6:2fa5:b0e6:c3be]:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.181 Debug Dlna: Rebroadcast Interval = 00:00:30, Next Broadcast At = 00:00:30 2018-02-09 11:01:32.184 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 on fe80::24b6:2fa5:b0e6:c3be%4 2018-02-09 11:01:32.185 Debug Dlna: Device Added MediaServer - 2ab59232ff3f4b2fb1a05efd6c9a77b6 - http://[fe80::24b6:2fa5:b0e6:c3be]:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.185 Debug Dlna: Rebroadcast Interval = 00:00:30, Next Broadcast At = 00:00:30 2018-02-09 11:01:32.216 Info HttpServer: HTTP Response 200 to ::1. Time: 216ms. http://localhost:8096/emby/System/Info 2018-02-09 11:01:32.334 Info TaskManager: StartupTrigger fired for task: Check for application updates 2018-02-09 11:01:32.336 Info TaskManager: Queueing task SystemUpdateTask 2018-02-09 11:01:32.349 Info TaskManager: Executing Check for application updates 2018-02-09 11:01:32.351 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2018-02-09 11:01:32.351 Info TaskManager: Queueing task PluginUpdateTask 2018-02-09 11:01:32.351 Info TaskManager: Executing Check for plugin updates 2018-02-09 11:01:32.381 Info InstallationManager: Opening C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\cache\serverpackages.json 2018-02-09 11:01:32.529 Debug App: No application update available. 2018-02-09 11:01:32.531 Info TaskManager: Check for application updates Completed after 0 minute(s) and 0 seconds 2018-02-09 11:01:32.596 Info HttpClient: GetTempFileResponse url: https://www.mb3admin.com/admin/service/EmbyPackages.json 2018-02-09 11:01:32.614 Info TaskManager: Check for plugin updates Completed after 0 minute(s) and 0 seconds 2018-02-09 11:01:32.619 Info TaskManager: ExecuteQueuedTasks 2018-02-09 11:01:32.672 Info TaskManager: ExecuteQueuedTasks 2018-02-09 11:01:32.706 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?IsEnabled=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:32.743 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\data\ScheduledTasks\9be21c93-4ee4-4926-9f41-b7c2b4d4d1d7.js 2018-02-09 11:01:32.785 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml. UserAgent: Android/5.1.1 UPnP/1.0 Cling/2.0 2018-02-09 11:01:32.806 Debug Dlna: No matching device profile found. Host=192.168.0.20:8096, Connection=Keep-Alive, User-Agent=Android/5.1.1 UPnP/1.0 Cling/2.0 2018-02-09 11:01:32.830 Info HttpServer: HTTP Response 200 to ::1. Time: 169ms. http://localhost:8096/emby/ScheduledTasks?IsEnabled=true 2018-02-09 11:01:32.845 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 60ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.857 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:32.858 Debug Dlna: No matching device profile found. User-Agent=UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13, Host=192.168.0.20:8096 2018-02-09 11:01:32.858 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 1ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.858 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:32.858 Debug Dlna: No matching device profile found. User-Agent=UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13, Host=192.168.0.20:8096 2018-02-09 11:01:32.858 Info HttpServer: HTTP Response 200 to 192.168.0.20. Time: 0ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/description.xml 2018-02-09 11:01:32.877 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/contentdirectory.xml. UserAgent: Android/5.1.1 UPnP/1.0 Cling/2.0 2018-02-09 11:01:33.012 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 134ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/contentdirectory.xml 2018-02-09 11:01:33.027 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:33.028 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 1ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/contentdirectory.xml 2018-02-09 11:01:33.060 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:33.077 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 17ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/connectionmanager.xml 2018-02-09 11:01:33.078 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/contentdirectory.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:33.079 Info HttpServer: HTTP Response 200 to 192.168.0.20. Time: 2ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/contentdirectory.xml 2018-02-09 11:01:33.111 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/connectionmanager.xml. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:33.113 Info HttpServer: HTTP Response 200 to 192.168.0.20. Time: 2ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/connectionmanager.xml 2018-02-09 11:01:33.113 Info HttpServer: HTTP SUBSCRIBE http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/events. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:33.133 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 20ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/contentdirectory/events 2018-02-09 11:01:33.134 Info HttpServer: HTTP SUBSCRIBE http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/events. UserAgent: UPnP/1.0 DLNADOC/1.50 Platinum/1.0.5.13 2018-02-09 11:01:33.135 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 2ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/events 2018-02-09 11:01:33.241 Info HttpServer: HTTP GET http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/connectionmanager.xml. UserAgent: Android/5.1.1 UPnP/1.0 Cling/2.0 2018-02-09 11:01:33.242 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 1ms. http://192.168.0.20:8096/dlna/2ab59232ff3f4b2fb1a05efd6c9a77b6/connectionmanager/connectionmanager.xml 2018-02-09 11:01:33.729 Info HttpServer: HTTP GET http://localhost:8096/web/strings/it.json?v=1518170493690. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:33.735 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/strings/it.json?v=1518170493690. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:33.740 Info HttpResultFactory: Transmit file C:\Users\neoda\AppData\Roaming\Emby-Server\system\dashboard-ui\bower_components\emby-webcomponents\strings\it.json 2018-02-09 11:01:33.742 Info HttpResultFactory: Transmit file C:\Users\neoda\AppData\Roaming\Emby-Server\system\dashboard-ui\strings\it.json 2018-02-09 11:01:33.747 Info HttpServer: HTTP Response 200 to ::1. Time: 19ms. http://localhost:8096/web/strings/it.json?v=1518170493690 2018-02-09 11:01:33.791 Info HttpServer: HTTP Response 200 to ::1. Time: 56ms. http://localhost:8096/web/bower_components/emby-webcomponents/strings/it.json?v=1518170493690 2018-02-09 11:01:34.314 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\config\branding.xml 2018-02-09 11:01:34.411 Info HttpServer: HTTP GET http://localhost:8096/emby/system/info/public. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.429 Info HttpServer: HTTP Response 200 to ::1. Time: 18ms. http://localhost:8096/emby/system/info/public 2018-02-09 11:01:34.499 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.581 Info HttpServer: HTTP Response 200 to ::1. Time: 83ms. http://localhost:8096/emby/System/Info 2018-02-09 11:01:34.592 Info HttpServer: HTTP GET http://localhost:8096/emby/users/954ceb50a54a4ffab610dd4ed30c04ac. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.674 Info HttpServer: HTTP Response 200 to ::1. Time: 82ms. http://localhost:8096/emby/users/954ceb50a54a4ffab610dd4ed30c04ac 2018-02-09 11:01:34.707 Info HttpServer: HTTP GET http://localhost:8096/emby/DisplayPreferences/usersettings?userId=954ceb50a54a4ffab610dd4ed30c04ac&client=emby. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.755 Info HttpServer: HTTP POST http://localhost:8096/emby/Sessions/Capabilities/Full. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.757 Info HttpServer: WS ws://localhost:8096/embywebsocket?api_key=dd50b027247946b4820020cbd7275c1e&deviceId=e08c044230279216d40c241b9f161fef4de305ed. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.760 Debug HttpServer: Web socket connection allowed 2018-02-09 11:01:34.793 Info HttpServer: HTTP GET http://localhost:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:34.796 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac 2018-02-09 11:01:34.873 Info HttpServer: HTTP Response 200 to ::1. Time: 167ms. http://localhost:8096/emby/DisplayPreferences/usersettings?userId=954ceb50a54a4ffab610dd4ed30c04ac&client=emby 2018-02-09 11:01:34.874 Info HttpServer: HTTP Response 204 to ::1. Time: 119ms. http://localhost:8096/emby/Sessions/Capabilities/Full 2018-02-09 11:01:35.164 Info HttpServer: HTTP GET http://localhost:8096/emby/Notifications/954ceb50a54a4ffab610dd4ed30c04ac/Summary. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.190 Info HttpServer: HTTP Response 200 to ::1. Time: 25ms. http://localhost:8096/emby/Notifications/954ceb50a54a4ffab610dd4ed30c04ac/Summary 2018-02-09 11:01:35.223 Info HttpServer: HTTP GET http://localhost:8096/emby/Sessions. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.227 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.234 Info HttpServer: HTTP Response 200 to ::1. Time: 7ms. http://localhost:8096/emby/ScheduledTasks 2018-02-09 11:01:35.315 Debug App: SessionInfoWebSocketListener Begin transmitting over websocket to [::1]:61273 2018-02-09 11:01:35.316 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.339 Info HttpClient: POST: https://mb3admin.com/admin/service/registration/validate 2018-02-09 11:01:35.341 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Info. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.344 Info HttpServer: HTTP GET http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.349 Debug JsonSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\cache\news.json 2018-02-09 11:01:35.356 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to [::1]:61273 2018-02-09 11:01:35.357 Debug App: ActivityLogWebSocketListener Begin transmitting over websocket to [::1]:61273 2018-02-09 11:01:35.359 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-02-08T10%3A01%3A35.256Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.361 Info HttpServer: HTTP Response 200 to ::1. Time: 17ms. http://localhost:8096/emby/News/Product?StartIndex=0&Limit=4 2018-02-09 11:01:35.361 Info HttpServer: HTTP GET http://localhost:8096/emby/LiveTv/Recordings?UserId=954ceb50a54a4ffab610dd4ed30c04ac&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.377 Info HttpServer: HTTP GET http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.496 Info HttpServer: HTTP Response 200 to ::1. Time: 139ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-02-08T10%3A01%3A35.256Z 2018-02-09 11:01:35.507 Info HttpServer: HTTP Response 200 to ::1. Time: 130ms. http://localhost:8096/emby/web/configurationpages?pageType=PluginConfiguration&EnableInMainMenu=true 2018-02-09 11:01:35.649 Info HttpServer: HTTP GET http://localhost:8096/web/css/images/logoblack.png. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.661 Info HttpServer: HTTP Response 304 to ::1. Time: 12ms. http://localhost:8096/web/css/images/logoblack.png 2018-02-09 11:01:35.745 Info HttpServer: HTTP Response 200 to ::1. Time: 404ms. http://localhost:8096/emby/System/Info 2018-02-09 11:01:35.791 Info HttpServer: HTTP Response 200 to ::1. Time: 430ms. http://localhost:8096/emby/LiveTv/Recordings?UserId=954ceb50a54a4ffab610dd4ed30c04ac&IsInProgress=true&Fields=CanDelete%2CPrimaryImageAspectRatio&EnableTotalRecordCount=false&EnableImageTypes=Primary%2CThumb%2CBackdrop 2018-02-09 11:01:35.826 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=System. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.869 Info HttpServer: HTTP Response 200 to ::1. Time: 645ms. http://localhost:8096/emby/Sessions 2018-02-09 11:01:35.885 Info HttpServer: HTTP GET http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:35.896 Info InstallationManager: Opening C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\cache\serverpackages.json 2018-02-09 11:01:35.901 Info HttpServer: HTTP Response 200 to ::1. Time: 75ms. http://localhost:8096/emby/Packages/Updates?PackageType=System 2018-02-09 11:01:35.966 Info HttpServer: HTTP Response 200 to ::1. Time: 82ms. http://localhost:8096/emby/Packages/Updates?PackageType=UserInstalled 2018-02-09 11:01:36.650 Info SecurityManager: Not registered for feature MBSupporter 2018-02-09 11:01:36.665 Info HttpServer: HTTP Response 200 to ::1. Time: 1349ms (slow). http://localhost:8096/emby/Plugins/SecurityInfo 2018-02-09 11:01:36.666 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:36.682 Info HttpServer: HTTP Response 200 to ::1. Time: 16ms. http://localhost:8096/emby/Plugins/SecurityInfo 2018-02-09 11:01:36.902 Debug PortMapper: Found NAT device: uuid:824ff22b-8c7d-41c5-a131-2c30332fd0f8::urn:schemas-upnp-org:service:WANIPConnection:1 2018-02-09 11:01:36.903 Debug PortMapper: Calling Nat.Handle on uuid:824ff22b-8c7d-41c5-a131-2c30332fd0f8::urn:schemas-upnp-org:service:WANIPConnection:1 2018-02-09 11:01:36.908 Debug PortMapper: Found device at: http://192.168.0.1:56688/rootDesc.xml 2018-02-09 11:01:36.908 Debug PortMapper: Parsed device as: 192.168.0.1:56688 2018-02-09 11:01:36.908 Debug PortMapper: Fetching service list: 192.168.0.1:56688 2018-02-09 11:01:36.911 Debug HttpClient: GET: http://192.168.0.1:56688/rootDesc.xml 2018-02-09 11:01:36.913 Debug PortMapper: Found NAT device: uuid:824ff22b-8c7d-41c5-a131-2c30332fd0f8::urn:schemas-upnp-org:service:WANPPPConnection:1 2018-02-09 11:01:36.913 Debug PortMapper: Calling Nat.Handle on uuid:824ff22b-8c7d-41c5-a131-2c30332fd0f8::urn:schemas-upnp-org:service:WANPPPConnection:1 2018-02-09 11:01:36.913 Debug PortMapper: Found device at: http://192.168.0.1:56688/rootDesc.xml 2018-02-09 11:01:36.913 Debug PortMapper: Parsed device as: 192.168.0.1:56688 2018-02-09 11:01:36.913 Debug PortMapper: Fetching service list: 192.168.0.1:56688 2018-02-09 11:01:36.914 Debug HttpClient: GET: http://192.168.0.1:56688/rootDesc.xml 2018-02-09 11:01:36.931 Debug PortMapper: 192.168.0.1:56688: Couldn't parse services list 2018-02-09 11:01:36.931 Debug PortMapper: 192.168.0.1:56688: Couldn't parse services list 2018-02-09 11:01:36.942 Debug PortMapper: 192.168.0.1:56688: Parsed services list 2018-02-09 11:01:36.942 Debug PortMapper: 192.168.0.1:56688: Parsed services list 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:Layer3Forwarding:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:Layer3Forwarding:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:WANEthernetLinkConfig:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:WANIPConnection:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found upnp service at: /ctl/IPConn 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:WANCommonInterfaceConfig:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:WANEthernetLinkConfig:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found service: urn:schemas-upnp-org:service:WANIPConnection:1 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Found upnp service at: /ctl/IPConn 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Assuming control Uri is relative: /ctl/IPConn 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Assuming control Uri is relative: /ctl/IPConn 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Handshake Complete 2018-02-09 11:01:36.946 Debug PortMapper: 192.168.0.1:56688: Handshake Complete 2018-02-09 11:01:36.947 Debug PortMapper: NAT device found: 192.168.0.20 2018-02-09 11:01:36.947 Debug PortMapper: NAT device found: 192.168.0.20 2018-02-09 11:01:36.955 Debug PortMapper: Creating port map on port 8096 2018-02-09 11:01:36.963 Debug HttpClient: POST: http://192.168.0.1:56688/ctl/IPConn 2018-02-09 11:01:36.975 Error PortMapper: Error creating port map: InternalServerError 2018-02-09 11:01:40.688 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Endpoint. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:01:40.699 Info HttpServer: HTTP Response 200 to ::1. Time: 11ms. http://localhost:8096/emby/System/Endpoint 2018-02-09 11:02:05.726 Info HttpServer: HTTP GET http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json. UserAgent: 2018-02-09 11:02:05.751 Info App: App Activity: app: Kodi EmbyCon, version: 1.4.43, deviceId: E408D59B7E84447189DF93DDF306FEA0, deviceName: EmbyCon 2018-02-09 11:02:05.784 Info HttpServer: HTTP GET http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-02-08T10%3A02%3A05.769Z. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:02:05.788 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/System/ActivityLog/Entries?startIndex=0&limit=7&minDate=2018-02-08T10%3A02%3A05.769Z 2018-02-09 11:02:06.102 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 376ms. http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json 2018-02-09 11:02:06.157 Info HttpServer: HTTP GET http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json. UserAgent: 2018-02-09 11:02:06.205 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 48ms. http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json 2018-02-09 11:02:55.890 Debug App: ScheduledTasksWebSocketListener Begin transmitting over websocket to [::1]:61273 2018-02-09 11:02:55.890 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:02:55.892 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to [::1]:61273 2018-02-09 11:02:55.893 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/ScheduledTasks?isHidden=false 2018-02-09 11:02:55.893 Debug App: SessionInfoWebSocketListener stop transmitting over websocket to [::1]:61273 2018-02-09 11:02:55.893 Debug App: ActivityLogWebSocketListener stop transmitting over websocket to [::1]:61273 2018-02-09 11:02:55.920 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:02:55.925 Info HttpServer: HTTP Response 200 to ::1. Time: 5ms. http://localhost:8096/emby/Plugins/SecurityInfo 2018-02-09 11:03:05.043 Info HttpServer: HTTP POST http://localhost:8096/emby/ScheduledTasks/Running/b1a52e63d5fb09335557d4f1e6402299. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:03:05.050 Info HttpServer: HTTP Response 204 to ::1. Time: 7ms. http://localhost:8096/emby/ScheduledTasks/Running/b1a52e63d5fb09335557d4f1e6402299 2018-02-09 11:03:05.050 Info TaskManager: Executing Sync library to trakt.tv 2018-02-09 11:03:05.063 Debug XmlSerializer: Deserializing file C:\Users\neoda\AppData\Roaming\Emby-Server\programdata\plugins\configurations\Trakt.xml 2018-02-09 11:03:05.071 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:03:05.075 Info HttpServer: HTTP Response 200 to ::1. Time: 4ms. http://localhost:8096/emby/ScheduledTasks?isHidden=false 2018-02-09 11:03:05.163 Info HttpClient: GET: https://api.trakt.tv/sync/watched/movies 2018-02-09 11:03:06.171 Info HttpClient: GET: https://api.trakt.tv/sync/collection/movies?extended=metadata 2018-02-09 11:03:06.265 Info HttpServer: HTTP GET http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json. UserAgent: 2018-02-09 11:03:06.306 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 41ms. http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json 2018-02-09 11:03:06.358 Info HttpServer: HTTP GET http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json. UserAgent: 2018-02-09 11:03:06.395 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 37ms. http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json 2018-02-09 11:03:07.425 Info Trakt: Movies to add to Collection: 0 2018-02-09 11:03:07.429 Info Trakt: Movies to set watched: 0 2018-02-09 11:03:07.429 Info Trakt: Movies to set unwatched: 0 2018-02-09 11:03:07.443 Info HttpClient: GET: https://api.trakt.tv/sync/watched/shows 2018-02-09 11:03:08.155 Info HttpClient: GET: https://api.trakt.tv/sync/collection/shows?extended=metadata 2018-02-09 11:03:11.089 Info Trakt: Episodes to add to Collection: 120 2018-02-09 11:03:11.164 Debug Trakt: {"shows":[{"seasons":[{"number":1,"episodes":[{"collected_at":"2010-11-17T18:37:18Z","number":11,"ids":{}},{"collected_at":"2010-11-17T17:37:08Z","number":7,"ids":{}},{"collected_at":"2010-11-17T15:10:34Z","number":10,"ids":{}},{"collected_at":"2010-11-17T15:26:14Z","number":5,"ids":{}},{"collected_at":"2010-11-16T14:26:22Z","number":1,"ids":{}},{"collected_at":"2010-11-17T14:12:50Z","number":2,"ids":{}},{"collected_at":"2010-11-17T18:24:22Z","number":8,"ids":{}},{"collected_at":"2010-11-22T11:19:20Z","number":4,"ids":{}},{"collected_at":"2010-11-17T13:42:26Z","number":9,"ids":{}},{"collected_at":"2010-11-22T09:25:08Z","number":3,"ids":{}},{"collected_at":"2010-11-27T14:12:22Z","number":6,"ids":{}}]}],"ids":{"tvdb":96101}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-01-06T11:19:18Z","number":2,"ids":{}}]}],"ids":{"imdb":"tt3512088","tvdb":278345}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-01-08T08:02:21Z","number":3,"ids":{}},{"collected_at":"2018-01-08T08:05:22Z","number":6,"ids":{}},{"collected_at":"2018-01-08T08:04:06Z","number":4,"ids":{}},{"collected_at":"2018-01-08T08:09:12Z","number":9,"ids":{}},{"collected_at":"2018-01-08T08:00:56Z","number":2,"ids":{}},{"collected_at":"2018-01-08T08:04:45Z","number":5,"ids":{}},{"collected_at":"2018-01-08T07:57:08Z","number":1,"ids":{}},{"collected_at":"2018-01-08T08:06:45Z","number":7,"ids":{}},{"collected_at":"2018-01-08T08:09:16Z","number":10,"ids":{}},{"collected_at":"2018-01-08T08:07:25Z","number":8,"ids":{}}]}],"ids":{"imdb":"tt6421916","tvdb":325193}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-04-27T14:39:21Z","number":1,"ids":{}},{"collected_at":"2017-04-27T14:59:02Z","number":10,"ids":{}},{"collected_at":"2017-04-27T14:48:06Z","number":5,"ids":{}},{"collected_at":"2017-04-27T14:45:36Z","number":4,"ids":{}},{"collected_at":"2017-04-27T14:53:35Z","number":8,"ids":{}},{"collected_at":"2017-04-27T14:52:13Z","number":7,"ids":{}},{"collected_at":"2017-04-27T14:42:56Z","number":3,"ids":{}},{"collected_at":"2017-04-27T14:55:02Z","number":9,"ids":{}},{"collected_at":"2017-04-27T14:40:57Z","number":2,"ids":{}},{"collected_at":"2017-04-27T14:50:02Z","number":6,"ids":{}}]}],"ids":{"imdb":"tt1165013","tvdb":111991}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-09-21T15:30:08Z","number":5,"ids":{}},{"collected_at":"2018-01-08T20:18:13Z","number":1,"ids":{}},{"collected_at":"2017-09-21T15:38:24Z","number":7,"ids":{}},{"collected_at":"2017-09-22T07:41:33Z","number":9,"ids":{}},{"collected_at":"2017-09-22T07:06:29Z","number":10,"ids":{}},{"collected_at":"2017-09-22T07:20:02Z","number":11,"ids":{}},{"collected_at":"2017-09-21T15:14:17Z","number":2,"ids":{}},{"collected_at":"2018-01-08T20:20:01Z","number":3,"ids":{}},{"collected_at":"2017-09-21T15:33:46Z","number":6,"ids":{}},{"collected_at":"2017-09-22T08:01:06Z","number":8,"ids":{}},{"collected_at":"2018-01-08T20:20:40Z","number":4,"ids":{}}]}],"ids":{"imdb":"tt0937345","tvdb":99701}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-09-05T09:29:58Z","number":6,"ids":{}},{"collected_at":"2017-09-05T09:29:26Z","number":9,"ids":{}},{"collected_at":"2017-09-05T09:29:51Z","number":7,"ids":{}},{"collected_at":"2017-09-05T09:29:16Z","number":8,"ids":{}},{"collected_at":"2017-09-05T09:29:45Z","number":11,"ids":{}},{"collected_at":"2017-09-05T09:30:03Z","number":2,"ids":{}},{"collected_at":"2017-09-05T09:30:27Z","number":1,"ids":{}},{"collected_at":"2017-09-05T09:30:16Z","number":4,"ids":{}},{"collected_at":"2017-09-05T09:30:07Z","number":3,"ids":{}},{"collected_at":"2017-09-05T09:29:39Z","number":10,"ids":{}},{"collected_at":"2017-09-05T09:30:22Z","number":5,"ids":{}}]}],"ids":{"imdb":"tt0873992","tvdb":81282}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-11-07T00:23:50Z","number":1,"ids":{}},{"collected_at":"2017-11-07T00:24:20Z","number":5,"ids":{}},{"collected_at":"2017-11-07T00:24:20Z","number":3,"ids":{}},{"collected_at":"2017-11-07T00:24:04Z","number":2,"ids":{}},{"collected_at":"2017-11-07T00:24:08Z","number":4,"ids":{}}]}],"ids":{"imdb":"tt6207198","tvdb":322760}},{"seasons":[{"number":3,"episodes":[{"collected_at":"2013-03-18T15:07:33Z","number":0,"ids":{}}]}],"ids":{"imdb":"tt0944947","tvdb":121361}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-12-17T13:58:17Z","number":11,"ids":{}},{"collected_at":"2017-09-05T07:04:44Z","number":9,"ids":{}},{"collected_at":"2017-12-17T20:06:08Z","number":7,"ids":{}},{"collected_at":"2017-09-04T21:40:15Z","number":8,"ids":{}},{"collected_at":"2017-09-05T07:05:15Z","number":10,"ids":{}},{"collected_at":"2017-09-04T12:34:50Z","number":6,"ids":{}},{"collected_at":"2017-09-04T06:53:31Z","number":3,"ids":{}},{"collected_at":"2017-09-04T09:46:23Z","number":5,"ids":{}},{"collected_at":"2017-11-30T10:33:28Z","number":1,"ids":{}},{"collected_at":"2017-09-04T11:40:45Z","number":4,"ids":{}},{"collected_at":"2017-09-03T20:59:35Z","number":2,"ids":{}}]}],"ids":{"imdb":"tt1200618","tvdb":83385}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-02-09T09:50:22Z","number":2,"ids":{}},{"collected_at":"2018-02-09T09:50:54Z","number":4,"ids":{}},{"collected_at":"2018-02-09T09:50:38Z","number":3,"ids":{}},{"collected_at":"2018-02-09T09:52:29Z","number":10,"ids":{}},{"collected_at":"2018-02-09T09:51:26Z","number":6,"ids":{}},{"collected_at":"2018-02-09T09:51:57Z","number":8,"ids":{}},{"collected_at":"2018-02-09T09:52:13Z","number":9,"ids":{}},{"collected_at":"2018-02-09T09:51:41Z","number":7,"ids":{}},{"collected_at":"2018-02-09T09:51:10Z","number":5,"ids":{}},{"collected_at":"2018-02-09T09:50:01Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt0880249","tvdb":85091}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-02-06T14:26:02Z","number":8,"ids":{}},{"collected_at":"2018-02-06T14:26:18Z","number":4,"ids":{}},{"collected_at":"2018-02-06T14:26:06Z","number":9,"ids":{}},{"collected_at":"2018-02-06T14:25:59Z","number":7,"ids":{}},{"collected_at":"2018-02-06T14:26:15Z","number":2,"ids":{}},{"collected_at":"2018-02-06T14:26:20Z","number":1,"ids":{}},{"collected_at":"2018-02-06T14:26:13Z","number":5,"ids":{}},{"collected_at":"2018-02-06T14:26:12Z","number":6,"ids":{}},{"collected_at":"2018-02-06T14:26:16Z","number":3,"ids":{}}]}],"ids":{"imdb":"tt1706186","tvdb":207001}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-10-02T08:49:20Z","number":2,"ids":{}},{"collected_at":"2017-10-02T13:39:56Z","number":7,"ids":{}},{"collected_at":"2017-10-12T08:44:31Z","number":10,"ids":{}},{"collected_at":"2017-10-02T15:10:52Z","number":8,"ids":{}},{"collected_at":"2017-10-02T09:53:10Z","number":4,"ids":{}},{"collected_at":"2017-10-02T12:05:36Z","number":5,"ids":{}},{"collected_at":"2017-10-02T09:12:16Z","number":3,"ids":{}},{"collected_at":"2017-10-12T07:28:10Z","number":9,"ids":{}},{"collected_at":"2017-10-02T12:43:37Z","number":6,"ids":{}},{"collected_at":"2017-10-02T07:39:49Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt2226946","tvdb":266009}}],"episodes":[]} 2018-02-09 11:03:11.164 Info HttpClient: POST: https://api.trakt.tv/sync/collection 2018-02-09 11:03:12.022 Debug Trakt: {"shows":[{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-10-05T17:00:47Z","number":2,"ids":{}},{"collected_at":"2017-10-05T16:45:38Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt6936468","tvdb":308953}},{"seasons":[{"number":4,"episodes":[{"collected_at":"2013-10-15T09:11:05Z","number":0,"ids":{}}]}],"ids":{"imdb":"tt1520211","tvdb":153021}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-09-05T15:11:38Z","number":6,"ids":{}},{"collected_at":"2017-09-05T15:00:34Z","number":2,"ids":{}},{"collected_at":"2017-09-05T15:14:07Z","number":7,"ids":{}},{"collected_at":"2017-09-05T15:06:28Z","number":4,"ids":{}},{"collected_at":"2017-09-05T15:03:55Z","number":3,"ids":{}},{"collected_at":"2017-09-05T15:08:46Z","number":5,"ids":{}},{"collected_at":"2017-09-05T14:56:48Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt0988936","tvdb":105901}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-12-07T09:59:59Z","number":1,"ids":{}},{"collected_at":"2017-12-11T14:14:24Z","number":5,"ids":{}},{"collected_at":"2017-12-07T10:15:22Z","number":6,"ids":{}},{"collected_at":"2017-12-11T08:02:24Z","number":4,"ids":{}},{"collected_at":"2017-12-12T07:35:33Z","number":9,"ids":{}},{"collected_at":"2017-12-11T12:14:00Z","number":3,"ids":{}},{"collected_at":"2017-12-07T10:05:09Z","number":2,"ids":{}},{"collected_at":"2017-12-12T07:42:46Z","number":10,"ids":{}},{"collected_at":"2017-12-07T10:16:27Z","number":7,"ids":{}},{"collected_at":"2017-12-11T16:17:04Z","number":8,"ids":{}}]}],"ids":{"imdb":"tt5074480","tvdb":304747}}],"episodes":[]} 2018-02-09 11:03:12.022 Info HttpClient: POST: https://api.trakt.tv/sync/collection 2018-02-09 11:03:12.571 Debug Trakt: TraktResponse Added Movies: 0 2018-02-09 11:03:12.571 Debug Trakt: TraktResponse Added Shows: 0 2018-02-09 11:03:12.571 Debug Trakt: TraktResponse Added Seasons: 0 2018-02-09 11:03:12.571 Debug Trakt: TraktResponse Added Episodes: 0 2018-02-09 11:03:12.574 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0944947","tvdb":121361}} 2018-02-09 11:03:12.574 Debug Trakt: TraktResponse Added Movies: 0 2018-02-09 11:03:12.574 Debug Trakt: TraktResponse Added Shows: 0 2018-02-09 11:03:12.574 Debug Trakt: TraktResponse Added Seasons: 0 2018-02-09 11:03:12.574 Debug Trakt: TraktResponse Added Episodes: 0 2018-02-09 11:03:12.574 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt1520211","tvdb":153021}} 2018-02-09 11:03:12.578 Info Trakt: Episodes to set watched: 1 2018-02-09 11:03:12.621 Debug Trakt: {"shows":[{"seasons":[{"episodes":[{"watched_at":"2017-11-30T15:02:23Z","number":0}],"number":4}],"ids":{"imdb":"tt1520211","tvdb":153021}}],"episodes":[]} 2018-02-09 11:03:12.621 Info HttpClient: POST: https://api.trakt.tv/sync/history 2018-02-09 11:03:13.214 Debug Trakt: TraktResponse Added Movies: 0 2018-02-09 11:03:13.214 Debug Trakt: TraktResponse Added Shows: 0 2018-02-09 11:03:13.214 Debug Trakt: TraktResponse Added Seasons: 0 2018-02-09 11:03:13.214 Debug Trakt: TraktResponse Added Episodes: 0 2018-02-09 11:03:13.214 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt1520211","tvdb":153021}} 2018-02-09 11:03:13.214 Info Trakt: Episodes to set unwatched: 0 2018-02-09 11:03:13.214 Info TaskManager: Sync library to trakt.tv Completed after 0 minute(s) and 8 seconds 2018-02-09 11:03:13.222 Info ServerManager: Sending web socket message ScheduledTaskEnded 2018-02-09 11:03:13.229 Info TaskManager: ExecuteQueuedTasks 2018-02-09 11:03:45.883 Info HttpServer: HTTP POST http://localhost:8096/emby/ScheduledTasks/Running/b1a52e63d5fb09335557d4f1e6402299. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:03:45.888 Info HttpServer: HTTP Response 204 to ::1. Time: 5ms. http://localhost:8096/emby/ScheduledTasks/Running/b1a52e63d5fb09335557d4f1e6402299 2018-02-09 11:03:45.889 Info TaskManager: Executing Sync library to trakt.tv 2018-02-09 11:03:45.889 Info HttpClient: GET: https://api.trakt.tv/sync/watched/movies 2018-02-09 11:03:45.905 Info HttpServer: HTTP GET http://localhost:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:03:45.919 Info HttpServer: HTTP Response 200 to ::1. Time: 15ms. http://localhost:8096/emby/ScheduledTasks?isHidden=false 2018-02-09 11:03:46.632 Info HttpClient: GET: https://api.trakt.tv/sync/collection/movies?extended=metadata 2018-02-09 11:03:47.772 Info Trakt: Movies to add to Collection: 0 2018-02-09 11:03:47.772 Info Trakt: Movies to set watched: 0 2018-02-09 11:03:47.772 Info Trakt: Movies to set unwatched: 0 2018-02-09 11:03:47.772 Info HttpClient: GET: https://api.trakt.tv/sync/watched/shows 2018-02-09 11:03:48.538 Info HttpClient: GET: https://api.trakt.tv/sync/collection/shows?extended=metadata 2018-02-09 11:03:49.988 Info Trakt: Episodes to add to Collection: 120 2018-02-09 11:03:50.005 Debug Trakt: {"shows":[{"seasons":[{"number":1,"episodes":[{"collected_at":"2010-11-17T18:37:18Z","number":11,"ids":{}},{"collected_at":"2010-11-17T17:37:08Z","number":7,"ids":{}},{"collected_at":"2010-11-17T15:10:34Z","number":10,"ids":{}},{"collected_at":"2010-11-17T15:26:14Z","number":5,"ids":{}},{"collected_at":"2010-11-16T14:26:22Z","number":1,"ids":{}},{"collected_at":"2010-11-17T14:12:50Z","number":2,"ids":{}},{"collected_at":"2010-11-17T18:24:22Z","number":8,"ids":{}},{"collected_at":"2010-11-22T11:19:20Z","number":4,"ids":{}},{"collected_at":"2010-11-17T13:42:26Z","number":9,"ids":{}},{"collected_at":"2010-11-22T09:25:08Z","number":3,"ids":{}},{"collected_at":"2010-11-27T14:12:22Z","number":6,"ids":{}}]}],"ids":{"tvdb":96101}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-01-06T11:19:18Z","number":2,"ids":{}}]}],"ids":{"imdb":"tt3512088","tvdb":278345}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-01-08T08:02:21Z","number":3,"ids":{}},{"collected_at":"2018-01-08T08:05:22Z","number":6,"ids":{}},{"collected_at":"2018-01-08T08:04:06Z","number":4,"ids":{}},{"collected_at":"2018-01-08T08:09:12Z","number":9,"ids":{}},{"collected_at":"2018-01-08T08:00:56Z","number":2,"ids":{}},{"collected_at":"2018-01-08T08:04:45Z","number":5,"ids":{}},{"collected_at":"2018-01-08T07:57:08Z","number":1,"ids":{}},{"collected_at":"2018-01-08T08:06:45Z","number":7,"ids":{}},{"collected_at":"2018-01-08T08:09:16Z","number":10,"ids":{}},{"collected_at":"2018-01-08T08:07:25Z","number":8,"ids":{}}]}],"ids":{"imdb":"tt6421916","tvdb":325193}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-04-27T14:39:21Z","number":1,"ids":{}},{"collected_at":"2017-04-27T14:59:02Z","number":10,"ids":{}},{"collected_at":"2017-04-27T14:48:06Z","number":5,"ids":{}},{"collected_at":"2017-04-27T14:45:36Z","number":4,"ids":{}},{"collected_at":"2017-04-27T14:53:35Z","number":8,"ids":{}},{"collected_at":"2017-04-27T14:52:13Z","number":7,"ids":{}},{"collected_at":"2017-04-27T14:42:56Z","number":3,"ids":{}},{"collected_at":"2017-04-27T14:55:02Z","number":9,"ids":{}},{"collected_at":"2017-04-27T14:40:57Z","number":2,"ids":{}},{"collected_at":"2017-04-27T14:50:02Z","number":6,"ids":{}}]}],"ids":{"imdb":"tt1165013","tvdb":111991}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-09-21T15:30:08Z","number":5,"ids":{}},{"collected_at":"2018-01-08T20:18:13Z","number":1,"ids":{}},{"collected_at":"2017-09-21T15:38:24Z","number":7,"ids":{}},{"collected_at":"2017-09-22T07:41:33Z","number":9,"ids":{}},{"collected_at":"2017-09-22T07:06:29Z","number":10,"ids":{}},{"collected_at":"2017-09-22T07:20:02Z","number":11,"ids":{}},{"collected_at":"2017-09-21T15:14:17Z","number":2,"ids":{}},{"collected_at":"2018-01-08T20:20:01Z","number":3,"ids":{}},{"collected_at":"2017-09-21T15:33:46Z","number":6,"ids":{}},{"collected_at":"2017-09-22T08:01:06Z","number":8,"ids":{}},{"collected_at":"2018-01-08T20:20:40Z","number":4,"ids":{}}]}],"ids":{"imdb":"tt0937345","tvdb":99701}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-09-05T09:29:58Z","number":6,"ids":{}},{"collected_at":"2017-09-05T09:29:26Z","number":9,"ids":{}},{"collected_at":"2017-09-05T09:29:51Z","number":7,"ids":{}},{"collected_at":"2017-09-05T09:29:16Z","number":8,"ids":{}},{"collected_at":"2017-09-05T09:29:45Z","number":11,"ids":{}},{"collected_at":"2017-09-05T09:30:03Z","number":2,"ids":{}},{"collected_at":"2017-09-05T09:30:27Z","number":1,"ids":{}},{"collected_at":"2017-09-05T09:30:16Z","number":4,"ids":{}},{"collected_at":"2017-09-05T09:30:07Z","number":3,"ids":{}},{"collected_at":"2017-09-05T09:29:39Z","number":10,"ids":{}},{"collected_at":"2017-09-05T09:30:22Z","number":5,"ids":{}}]}],"ids":{"imdb":"tt0873992","tvdb":81282}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-11-07T00:23:50Z","number":1,"ids":{}},{"collected_at":"2017-11-07T00:24:20Z","number":5,"ids":{}},{"collected_at":"2017-11-07T00:24:20Z","number":3,"ids":{}},{"collected_at":"2017-11-07T00:24:04Z","number":2,"ids":{}},{"collected_at":"2017-11-07T00:24:08Z","number":4,"ids":{}}]}],"ids":{"imdb":"tt6207198","tvdb":322760}},{"seasons":[{"number":3,"episodes":[{"collected_at":"2013-03-18T15:07:33Z","number":0,"ids":{}}]}],"ids":{"imdb":"tt0944947","tvdb":121361}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-12-17T13:58:17Z","number":11,"ids":{}},{"collected_at":"2017-09-05T07:04:44Z","number":9,"ids":{}},{"collected_at":"2017-12-17T20:06:08Z","number":7,"ids":{}},{"collected_at":"2017-09-04T21:40:15Z","number":8,"ids":{}},{"collected_at":"2017-09-05T07:05:15Z","number":10,"ids":{}},{"collected_at":"2017-09-04T12:34:50Z","number":6,"ids":{}},{"collected_at":"2017-09-04T06:53:31Z","number":3,"ids":{}},{"collected_at":"2017-09-04T09:46:23Z","number":5,"ids":{}},{"collected_at":"2017-11-30T10:33:28Z","number":1,"ids":{}},{"collected_at":"2017-09-04T11:40:45Z","number":4,"ids":{}},{"collected_at":"2017-09-03T20:59:35Z","number":2,"ids":{}}]}],"ids":{"imdb":"tt1200618","tvdb":83385}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-02-09T09:50:22Z","number":2,"ids":{}},{"collected_at":"2018-02-09T09:50:54Z","number":4,"ids":{}},{"collected_at":"2018-02-09T09:50:38Z","number":3,"ids":{}},{"collected_at":"2018-02-09T09:52:29Z","number":10,"ids":{}},{"collected_at":"2018-02-09T09:51:26Z","number":6,"ids":{}},{"collected_at":"2018-02-09T09:51:57Z","number":8,"ids":{}},{"collected_at":"2018-02-09T09:52:13Z","number":9,"ids":{}},{"collected_at":"2018-02-09T09:51:41Z","number":7,"ids":{}},{"collected_at":"2018-02-09T09:51:10Z","number":5,"ids":{}},{"collected_at":"2018-02-09T09:50:01Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt0880249","tvdb":85091}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2018-02-06T14:26:02Z","number":8,"ids":{}},{"collected_at":"2018-02-06T14:26:18Z","number":4,"ids":{}},{"collected_at":"2018-02-06T14:26:06Z","number":9,"ids":{}},{"collected_at":"2018-02-06T14:25:59Z","number":7,"ids":{}},{"collected_at":"2018-02-06T14:26:15Z","number":2,"ids":{}},{"collected_at":"2018-02-06T14:26:20Z","number":1,"ids":{}},{"collected_at":"2018-02-06T14:26:13Z","number":5,"ids":{}},{"collected_at":"2018-02-06T14:26:12Z","number":6,"ids":{}},{"collected_at":"2018-02-06T14:26:16Z","number":3,"ids":{}}]}],"ids":{"imdb":"tt1706186","tvdb":207001}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-10-02T08:49:20Z","number":2,"ids":{}},{"collected_at":"2017-10-02T13:39:56Z","number":7,"ids":{}},{"collected_at":"2017-10-12T08:44:31Z","number":10,"ids":{}},{"collected_at":"2017-10-02T15:10:52Z","number":8,"ids":{}},{"collected_at":"2017-10-02T09:53:10Z","number":4,"ids":{}},{"collected_at":"2017-10-02T12:05:36Z","number":5,"ids":{}},{"collected_at":"2017-10-02T09:12:16Z","number":3,"ids":{}},{"collected_at":"2017-10-12T07:28:10Z","number":9,"ids":{}},{"collected_at":"2017-10-02T12:43:37Z","number":6,"ids":{}},{"collected_at":"2017-10-02T07:39:49Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt2226946","tvdb":266009}}],"episodes":[]} 2018-02-09 11:03:50.006 Info HttpClient: POST: https://api.trakt.tv/sync/collection 2018-02-09 11:03:50.794 Debug Trakt: {"shows":[{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-10-05T17:00:47Z","number":2,"ids":{}},{"collected_at":"2017-10-05T16:45:38Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt6936468","tvdb":308953}},{"seasons":[{"number":4,"episodes":[{"collected_at":"2013-10-15T09:11:05Z","number":0,"ids":{}}]}],"ids":{"imdb":"tt1520211","tvdb":153021}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-09-05T15:11:38Z","number":6,"ids":{}},{"collected_at":"2017-09-05T15:00:34Z","number":2,"ids":{}},{"collected_at":"2017-09-05T15:14:07Z","number":7,"ids":{}},{"collected_at":"2017-09-05T15:06:28Z","number":4,"ids":{}},{"collected_at":"2017-09-05T15:03:55Z","number":3,"ids":{}},{"collected_at":"2017-09-05T15:08:46Z","number":5,"ids":{}},{"collected_at":"2017-09-05T14:56:48Z","number":1,"ids":{}}]}],"ids":{"imdb":"tt0988936","tvdb":105901}},{"seasons":[{"number":1,"episodes":[{"collected_at":"2017-12-07T09:59:59Z","number":1,"ids":{}},{"collected_at":"2017-12-11T14:14:24Z","number":5,"ids":{}},{"collected_at":"2017-12-07T10:15:22Z","number":6,"ids":{}},{"collected_at":"2017-12-11T08:02:24Z","number":4,"ids":{}},{"collected_at":"2017-12-12T07:35:33Z","number":9,"ids":{}},{"collected_at":"2017-12-11T12:14:00Z","number":3,"ids":{}},{"collected_at":"2017-12-07T10:05:09Z","number":2,"ids":{}},{"collected_at":"2017-12-12T07:42:46Z","number":10,"ids":{}},{"collected_at":"2017-12-07T10:16:27Z","number":7,"ids":{}},{"collected_at":"2017-12-11T16:17:04Z","number":8,"ids":{}}]}],"ids":{"imdb":"tt5074480","tvdb":304747}}],"episodes":[]} 2018-02-09 11:03:50.794 Info HttpClient: POST: https://api.trakt.tv/sync/collection 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Movies: 0 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Shows: 0 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Seasons: 0 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Episodes: 0 2018-02-09 11:03:51.358 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt0944947","tvdb":121361}} 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Movies: 0 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Shows: 0 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Seasons: 0 2018-02-09 11:03:51.358 Debug Trakt: TraktResponse Added Episodes: 0 2018-02-09 11:03:51.358 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt1520211","tvdb":153021}} 2018-02-09 11:03:51.358 Info Trakt: Episodes to set watched: 4 2018-02-09 11:03:51.360 Debug Trakt: {"shows":[{"seasons":[{"episodes":[{"watched_at":"2018-02-08T22:49:19Z","number":2},{"watched_at":"2018-02-09T00:05:19Z","number":3},{"watched_at":"2018-02-08T21:47:24Z","number":1}],"number":1}],"ids":{"imdb":"tt0880249","tvdb":85091}},{"seasons":[{"episodes":[{"watched_at":"2017-11-30T15:02:23Z","number":0}],"number":4}],"ids":{"imdb":"tt1520211","tvdb":153021}}],"episodes":[]} 2018-02-09 11:03:51.360 Info HttpClient: POST: https://api.trakt.tv/sync/history 2018-02-09 11:03:52.169 Debug Trakt: TraktResponse Added Movies: 0 2018-02-09 11:03:52.169 Debug Trakt: TraktResponse Added Shows: 0 2018-02-09 11:03:52.169 Debug Trakt: TraktResponse Added Seasons: 0 2018-02-09 11:03:52.169 Debug Trakt: TraktResponse Added Episodes: 3 2018-02-09 11:03:52.169 Error Trakt: TraktResponse not Found:{"ids":{"imdb":"tt1520211","tvdb":153021}} 2018-02-09 11:03:52.169 Info Trakt: Episodes to set unwatched: 0 2018-02-09 11:03:52.169 Info TaskManager: Sync library to trakt.tv Completed after 0 minute(s) and 6 seconds 2018-02-09 11:03:52.183 Info ServerManager: Sending web socket message ScheduledTaskEnded 2018-02-09 11:03:52.183 Info TaskManager: ExecuteQueuedTasks 2018-02-09 11:04:06.463 Info HttpServer: HTTP GET http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json. UserAgent: 2018-02-09 11:04:06.493 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 30ms. http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DateCreated&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json 2018-02-09 11:04:06.546 Info HttpServer: HTTP GET http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json. UserAgent: 2018-02-09 11:04:06.576 Info HttpServer: HTTP Response 200 to 192.168.0.2. Time: 30ms. http://192.168.0.20:8096/emby/Users/954ceb50a54a4ffab610dd4ed30c04ac/Items?Recursive=true&limit=1&Fields=DateCreated,Etag&SortBy=DatePlayed&SortOrder=Descending&IncludeItemTypes=Movie,Episode&ImageTypeLimit=0&format=json 2018-02-09 11:04:20.928 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:04:20.929 Debug App: ScheduledTasksWebSocketListener stop transmitting over websocket to [::1]:61273 2018-02-09 11:04:20.929 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Configuration. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:04:20.946 Info HttpServer: HTTP Response 200 to ::1. Time: 22ms. http://localhost:8096/emby/System/Logs 2018-02-09 11:04:20.946 Info HttpServer: HTTP GET http://localhost:8096/emby/Plugins/SecurityInfo. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 2018-02-09 11:04:20.949 Info HttpServer: HTTP Response 200 to ::1. Time: 3ms. http://localhost:8096/emby/Plugins/SecurityInfo 2018-02-09 11:04:20.987 Info HttpServer: HTTP Response 200 to ::1. Time: 59ms. http://localhost:8096/emby/System/Configuration 2018-02-09 11:04:23.690 Info HttpServer: HTTP GET http://localhost:8096/emby/System/Logs/Log?name=server-63653770884.txt. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/64.0.3282.140 Safari/537.36 P.S. there is an error in another TV Series: The Walkind Dead...
Luke 42253 Posted February 9, 2018 Posted February 9, 2018 @@neodago, do you mean your trakt watch history? If so then it's too late to try and figure out what might have happened in the past. We need to instead try to get it to happen again so that we can monitor it. Thanks.
neodago 3 Posted February 12, 2018 Author Posted February 12, 2018 @@neodago, do you mean your trakt watch history? If so then it's too late to try and figure out what might have happened in the past. We need to instead try to get it to happen again so that we can monitor it. Thanks. Yes, exactly the Trakt watch history. In emby the show is correctly recognized, but Trakt thinks it'a another show, I can't understand this. I tried to delete the track history, identify again the show in emby and even delete the files in emby library and import them again. Nothing helped: everytime I execute the plugin trakt thinks I watched another show.
Angelblue05 4132 Posted February 12, 2018 Posted February 12, 2018 Sounds to me like your provider ids incorrect. Double verify them in the webclient > select the problematic title > 3 dots menu > edit info. Make sure they are all correct. You probably have a rogue one that's causing this issue.
neodago 3 Posted February 12, 2018 Author Posted February 12, 2018 Sounds to me like your provider ids incorrect. Double verify them in the webclient > select the problematic title > 3 dots menu > edit info. Make sure they are all correct. You probably have a rogue one that's causing this issue. Already checked and it seems ok:
paulsalter 84 Posted February 12, 2018 Posted February 12, 2018 Hi, Check out the TVDB id for the episode you have problems with (instead of show level) I believe this is what is used to sync to Trakt EG My Boss, My Hero on TVDB Show = 85091 as you have mentioned Season 1 = 40779 Episode 1 = 435517 - this is what i think it syncs against for episodes 1 1
neodago 3 Posted February 12, 2018 Author Posted February 12, 2018 Hi, Check out the TVDB id for the episode you have problems with (instead of show level) I believe this is what is used to sync to Trakt EG My Boss, My Hero on TVDB Show = 85091 as you have mentioned Season 1 = 40779 Episode 1 = 435517 - this is what i think it syncs against for episodes Hi, at episode level, there is no tvdb or imdb id set, only the episode number
paulsalter 84 Posted February 12, 2018 Posted February 12, 2018 Have you tried refreshing the metadata Just testing that show here Main show level similar to yours Under the episodes, i get this, which i believe is what is used for Trakt
neodago 3 Posted February 12, 2018 Author Posted February 12, 2018 I can't find this menu/visualization. Where do I have to go? Under the episodes, i get this, which i believe is what is used for Trakt
paulsalter 84 Posted February 12, 2018 Posted February 12, 2018 If you go into the server dashboard, then at the bottom click metadata manager Expand your tv library, then expand this show/season and highlight the episode Can provide a screenshot if you want
paulsalter 84 Posted February 12, 2018 Posted February 12, 2018 This is the screen you need to look on (i just highlighted my first show as an example)
neodago 3 Posted February 12, 2018 Author Posted February 12, 2018 If you go into the server dashboard, then at the bottom click metadata manager Expand your tv library, then expand this show/season and highlight the episode Can provide a screenshot if you want OK, found. This is my situation: The episodes have no name and no tags, no external id either
paulsalter 84 Posted February 12, 2018 Posted February 12, 2018 looks like its not detecting the Season correctly (line about where you have highlighted, NameSeasonUnknown) How are the files stored on the disc? TVShows\My Boss My Hero\Season 01\By Boss My Hero - S01E01.ext or similar
neodago 3 Posted February 12, 2018 Author Posted February 12, 2018 looks like its not detecting the Season correctly (line about where you have highlighted, NameSeasonUnknown) How are the files stored on the disc? TVShows\My Boss My Hero\Season 01\By Boss My Hero - S01E01.ext or similar OK, problem solved. I edited the filenames as follow: before --> My Boss My Hero ep01 (2006) [AW][720p].mkw after --> My Boss My Hero S01E01 (2006) [AW][720p].mkw Now the name of the season and the name of each episode are correctly detected. I edited the wrong id of TVDB and the Trakt plugin now works as expected. But it's strange that others shows that I watched time ago worked flawlessy even without the season iformation in the filename (like in this particular show, only one season is present) and the season information was also "NameSeasonUnknown"
paulsalter 84 Posted February 12, 2018 Posted February 12, 2018 Good to hear you have got it sorted out
