PaucS 0 Posted February 8, 2018 Posted February 8, 2018 Hello! I have two BIG problems with my Emby app on Android TV! 1.) The Sound in TV Shows (only TV shows, movies are all right) is bad. It is late, therfore it is not sync with picture and it is generaly not good. You can hear like little noise in the background. 2.) When I watch the movie, when I stopped it or put it on pause, the sound on the background is still going on!?!?! WTF? Like it is not stopped? Do you understand me? I press stop, picture goes in menu, but after 2,3 sec the sound goes on!? Please, please help me! I paid for the app and it must work! FYI, when I had app at my Samsung Smart TV it was perfect, but now with android tv I have such problems!!!
ebr 16337 Posted February 8, 2018 Posted February 8, 2018 Hi. These are very unusual problems. What device are you running the app on? I press stop... There is no "stop" button so what are you actually pressing? Thanks!
PaucS 0 Posted February 8, 2018 Author Posted February 8, 2018 Hi. These are very unusual problems. What device are you running the app on? There is no "stop" button so what are you actually pressing? Thanks! My device is new Phillips TV. Best TV of 2017 (by Phillips) Well, yeah Stop button on a remote control, opossite of play...? Squarre for symbol.
PaucS 0 Posted February 9, 2018 Author Posted February 9, 2018 Cmon, please help me, I am a big fan of emby and a big movie buff and this is causing me a big headache.
CBers 7554 Posted February 9, 2018 Posted February 9, 2018 Give @@ebr a chance to reply. He has to sleep as well
PaucS 0 Posted February 9, 2018 Author Posted February 9, 2018 And after all of my browsing in the app at the time of this troubles, it says to many errors ... well, no shit sherlock
CBers 7554 Posted February 9, 2018 Posted February 9, 2018 Please follow the link below and supply the logs, including the in-app logs when the problem occurs. https://emby.media/community/index.php?/topic/790-how-to-report-a-problem Thanks.
PaucS 0 Posted February 9, 2018 Author Posted February 9, 2018 Ok, I send data @11.24, username is PaucS
ebr 16337 Posted February 9, 2018 Posted February 9, 2018 Ok, I send data @11.24, username is PaucS Hi. Was that the name of the local Emby user on the server...? And what exact problem did you have during the time this log covers? Thanks.
PaucS 0 Posted February 10, 2018 Author Posted February 10, 2018 Yes, that is the name. PaucS Well my problem with sound is probably not in the logs. As I said, sound is not sync with picture and after I finished watching epp or movie, the sound still playes in background.
ebr 16337 Posted February 10, 2018 Posted February 10, 2018 I don't see any issues on the app end but it sounds like something is responding very slowly possibly. Can you please post a server (and any ffmpeg) log and indicate to us when in that log these problems occurred? Thanks.
snorkel 15 Posted February 12, 2018 Posted February 12, 2018 Almost sounds like the surround sound issue I was having with the shield. I also had a bunch of movies I had ripped from Bluray,dvd etc and they were all stereo, the TV shows where 5.1 surround. OP, if your device has a option to turn off surround, or use the setting in the emby android tv app to downmix to stereo. The downmix options resolved it for me as well as turning off the surround in the Shield settings. (I didn't see what device you are using). 1
PaucS 0 Posted February 13, 2018 Author Posted February 13, 2018 I don't see any issues on the app end but it sounds like something is responding very slowly possibly. Can you please post a server (and any ffmpeg) log and indicate to us when in that log these problems occurred? Thanks Well, someone said that problem could be in router, because of slow wifi, is it possible? For second Q I kinda do not underrstand what you mean
PaucS 0 Posted February 13, 2018 Author Posted February 13, 2018 Almost sounds like the surround sound issue I was having with the shield. I also had a bunch of movies I had ripped from Bluray,dvd etc and they were all stereo, the TV shows where 5.1 surround. OP, if your device has a option to turn off surround, or use the setting in the emby android tv app to downmix to stereo. The downmix options resolved it for me as well as turning off the surround in the Shield settings. (I didn't see what device you are using). My first thouhgt was also surrond but I unplugged it and sound on TV does the same, so ...
ebr 16337 Posted February 13, 2018 Posted February 13, 2018 For second Q I kinda do not underrstand what you mean Hi. Please see: How to Report a Problem
