Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 (edited) The original mini series was aired in two separate episodes (S00E01 and S00E02) since I only have one file that contains both episodes, I have to name it S00E01E02, the rest are individual files with the S00E03, S00E04 and S00E05: Edited May 30, 2021 by Richard Branches
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 1 minute ago, Luke said: Yes I would check the values for each episode. Each episode has its correct value, I already checked, but the server is putting those files with that syntax in the wrong position.
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 It was organized correctly with the previous server.
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 25 minutes ago, Richard Branches said: It was organized correctly with the previous server. Specials were excluded from next up in the previous release so what you're saying is not applicable.
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 29 minutes ago, Richard Branches said: Each episode has its correct value, I already checked, but the server is putting those files with that syntax in the wrong position. I would also check the special episode ordering values for each in the metadata editor, scroll down a little to locate those. There's nothing complicated about this. Just look at the numbers for each and that will determine the order.
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 I'm going to roll back to the previous server and then I'll take an screenshot of the same TV show, I'm telling you that the server is screwing up the the order of special episodes with the S00E01E02 or whatever.
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 Just now, Richard Branches said: I'm going to roll back to the previous server and then I'll take an screenshot of the same TV show, I'm telling you that the server is screwing up the the order of special episodes with the S00E01E02 or whatever. That makes no sense. 4.5 does not show specials in next up. Again just look at the numbers. It sounds like you're just dismissing what I'm saying without actually doing that
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 I give up, I haven't modified those files, I know they showed up correctly in the whatever version of the server of the above screenshot.
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 Because the previous version didn't show them at all. I would also check the special episode ordering values for each in the metadata editor, scroll down a little to locate those.
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 This is an screenshot of the server version 4.6.0.50, do you see the episode in its correct position??????
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 Again you're focusing on a previous build as opposed to looking at what I'm suggesting.
roaku 842 Posted May 30, 2021 Posted May 30, 2021 34 minutes ago, Luke said: That makes no sense. 4.5 does not show specials in next up. Again just look at the numbers. It sounds like you're just dismissing what I'm saying without actually doing that I believe 'previous version' for him means 4.6, and he's currently on 4.7 beta.
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 (edited) I deleted the 4.7.0.1 and downloaded that old 4.6.0.50 where the file appears correctly, isn't it obvious? I didn't scan the folders, I just went directly to the TV show and took the screenshot. The only difference between the old one and the new one is that the episodes without metadata in other TV shows appear before the first season in the old one while the new one fixes the problem, but the one I'm using to take the screenshots appears correctly. Edited May 30, 2021 by Richard Branches
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 11 minutes ago, Luke said: Again you're focusing on a previous build as opposed to looking at what I'm suggesting. It's obvious that the new one is screwing up special episodes with the S00EXXEXX syntax.
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 I would check the special episode ordering values for each in the metadata editor, scroll down a little to locate those.
Luke 42203 Posted May 30, 2021 Posted May 30, 2021 Yes, and that gives you your answer. That says that the special should be placed during season 1 just before episode 1. You've also configured the server in advanced settings to show specials during the seasons that they aired in.
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 That still doesn't explain why it puts the file in the correct position in the old server and not in the recent one?
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 4 minutes ago, Luke said: That says that the special should be placed during season 1 just before episode 1. The other special episodes also show exactly the same but they appear in their correct position, so?
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 (edited) 21 minutes ago, Luke said: You've also configured the server in advanced settings to show specials during the seasons that they aired in They didn't air during season 1 but before it, which makes no sense. I turned OFF the "Display specials within seasons they aired in" option and what it did was to remove all the specials from Next Up I also renamed the file to the regular S00E01 thinking it was the reason of the problem but it didn't put the file in the correct position either so I have to discard that. I give up. Good night. Edited May 30, 2021 by Richard Branches
roaku 842 Posted May 30, 2021 Posted May 30, 2021 (edited) 25 minutes ago, Luke said: Yes, and that gives you your answer. That says that the special should be placed during season 1 just before episode 1. You've also configured the server in advanced settings to show specials during the seasons that they aired in. He has multiple specials that should air before Season 1. His problem is that this set is *not* sorted according to their episode number. They're all appearing correctly before Season 1, but not ordered correctly among themselves. Edited May 30, 2021 by roaku 1
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 (edited) Another example before I go to bed: This one also puts two episodes in the wrong position, but the old server puts them in the correct position: Edited May 30, 2021 by Richard Branches
Richard Branches 334 Posted May 30, 2021 Author Posted May 30, 2021 10 hours ago, roaku said: They're all appearing correctly before Season 1, but not ordered correctly among themselves. Exactly, you've got the point.
Richard Branches 334 Posted June 1, 2021 Author Posted June 1, 2021 This is finally fixed after 3 years and 4 months, it was worth the wait!. Thank you.
