bkh 7 Posted February 8, 2018 Posted February 8, 2018 Hello, does Emby work with the Cable Router FritzBox 6590? Answer fom AVM-Support: Ein Test zu dem genannte Programm liegt nicht vor, solange dieses aber RTP-Streams (Real-Time Transport Protocol) unterstützt steht dem nichts im Wege. Anyone tested this Configuration? bkh
Luke 42244 Posted February 8, 2018 Posted February 8, 2018 Hi, it should work fine. Are you having an issue?
bkh 7 Posted February 10, 2018 Author Posted February 10, 2018 Not yet, i have to test it. If it don't work, i will return back. bkh
bkh 7 Posted February 23, 2018 Author Posted February 23, 2018 Sorry for the delay. Now the 6590 is working. I can create a playlist for SD-, HD- and Radio-Channels. But, i have no idea how to get working with emby. Yes, i need help bkh
SchnohneX 0 Posted April 20, 2018 Posted April 20, 2018 I think I am farther ahead than bkn (as I have everything BUT recording working) and I will gladly write an FAQ/WIKI about this hardware once all my problems are explained or resolved. Cheers! (Other thread: https://emby.media/community/index.php?/topic/58109-livetv-guide-works-recording-silently-fails-fritzbox-6490-dvr/?p=569413)
