we87 0 Posted February 8, 2018 Posted February 8, 2018 Ive search for the switches but cannot find them And leaving "repeat forever" check inside MPCHC doesnt let a movie played in emby repeat. /loop /repeat /repeatforever All do not work. Any ideas? Also, just to verify I have selected "generic" player as an external player, pointed it to the mpchc exe file, and used the other box to add commands so it looks like "{0} /loop" Using Windows 7, Windows Media Center, and Emby - Just want the movies to repeat until I hit stop. Thank you all very much.
Luke 42237 Posted February 8, 2018 Posted February 8, 2018 @@Teddy or @@AdrianW might be a good resource for this.
Teddy 100 Posted February 8, 2018 Posted February 8, 2018 (edited) I use MPC only to play a movie ever since Windows 7 but I have never needed it for Emby for WMC. I use the WMC build player and Powerdvd 15 for the ISO images of DVD and Bluray.I do not see personally any advantage in using MPC for the avi, mkv files ... since from my remote control I can control all the actions from my sofa with WMC player native.To repeat the videos in loop you can locate the task-bar at bottom of WMP and locate the button "Turn repeat on", hoover over to locate, the other is shuffle, I imagine that it could be work for WMC since it uses WMP to play video. (I have never tried it but you could try it) Edited February 8, 2018 by Teddy
AdrianW 1058 Posted February 9, 2018 Posted February 9, 2018 @@Teddy or @@AdrianW might be a good resource for this. Maybe a few years ago - but I no longer use Windows 7, Media Center or MPC-HC. I'm fully switched to ET on Win 10 now.
