jscoys 147 Posted February 7, 2018 Posted February 7, 2018 Hello guys, On the 3.2.70.10 and mentioned that the option to save pictures locally is not there and in the nfo the https links to themoviedb are putted there. It’s not possible to save pictures locally anymore? Sent from my iPhone using Tapatalk
Luke 42245 Posted February 7, 2018 Posted February 7, 2018 It sure is, have you explored all of the image saving options for each library?
jscoys 147 Posted February 7, 2018 Author Posted February 7, 2018 (edited) Ok i have this But on the nfo I have the https links Sent from my iPhone using Tapatalk Edited February 7, 2018 by jscoys
Luke 42245 Posted February 7, 2018 Posted February 7, 2018 Did you read all of the settings on that screen? I see one that might be related.
jscoys 147 Posted February 7, 2018 Author Posted February 7, 2018 ? Sent from my iPhone using Tapatalk
jscoys 147 Posted February 7, 2018 Author Posted February 7, 2018 Hum your right... in fact I switch from windows server to centos 7 recently and the directories are the same as before. But I guess for the library.db even if the link of the picture was in the previous nfo it overridden it with the https links. But I went on the movie details and now I have this in the nfo: So 3 links to the same fanart picture. When I edit pictures I have the same picture 3 times. Is it normal? Do you think I should delete nfo files? Sent from my iPhone using Tapatalk
jscoys 147 Posted February 7, 2018 Author Posted February 7, 2018 This one is worst... Sent from my iPhone using Tapatalk
jscoys 147 Posted February 8, 2018 Author Posted February 8, 2018 Ok @@Luke Thx for your help I will open an other ticket. This one can be closed, was my misunderstanding of the option. Thx again. Sent from my iPhone using Tapatalk
