shocker 135 Posted February 6, 2018 Posted February 6, 2018 Hello, I'm identified an issue with the transcoder on Roku (public and beta client as well) and I'm getting this error message: An unexpected problem (but not server timeout or HTTP error) has been detected. If I'm disabling the transcoding then everything is ok. Logs attached. transcode-log.txt
ebr 16336 Posted February 6, 2018 Posted February 6, 2018 ffmpeg failed: Error reinitializing filters! Failed to inject frame into filter network: Function not implemented Error while processing the decoded data for stream #0:0 Conversion failed!
lorac 119 Posted February 6, 2018 Posted February 6, 2018 Hello, I'm identified an issue with the transcoder on Roku (public and beta client as well) and I'm getting this error message: An unexpected problem (but not server timeout or HTTP error) has been detected. If I'm disabling the transcoding then everything is ok. Logs attached. It looks to be an issue with subtitles according to the log. Not that surprising. Sent from my STV100-3 using Tapatalk
shocker 135 Posted February 6, 2018 Author Posted February 6, 2018 Indeed in DirectPlay the subtitle is not working on Roku as well. I've tried with Emby web and everything is fine, the subtitle is working ok (see attached). Tested with the Plex app on Roku and: Transcoding: OK DirectPlay: OK I'm guessing that there is nothing wrong with subtile or I'm missing something?
Luke 42243 Posted February 6, 2018 Posted February 6, 2018 We may have to add something to our ffmpeg build. thanks.
shocker 135 Posted February 6, 2018 Author Posted February 6, 2018 @@Luke ping me if you need the subtitle file or the media in order to troubleshoot. Also it will be great if this will not require transcoding as it can be played as DirectPlay, the transcoder is triggered only due to subtitle Thanks guys!
Luke 42243 Posted February 25, 2018 Posted February 25, 2018 @@shocker Please try the 3.3.0.2 beta when available and let me know if the issue remains, thanks.
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 @@shocker Please try the 3.3.0.2 beta when available and let me know if the issue remains, thanks. Tested with the latest Roku Beta app and now the movie is starting with subtitle but the diacritics are not supported.
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 @@Luke please find it attached. Thanks ffmpeg-transcode-40268846-5c27-400c-a93a-fe276cb6a731.txt
Solution Luke 42243 Posted February 26, 2018 Solution Posted February 26, 2018 Would you mind replacing the font file here: /var/lib/emby/fonts With the attached font. See if that changes anything. Thanks. DroidSansFallback.zip 1
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 Indeed this new font is fixing the problem. Please find attached the new transcode log file. Thanks @@Luke ffmpeg-transcode-949aec9b-20d7-4dab-8e31-1ec0de3d1347.txt
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 Just to confirm, this new font will be added in the next beta release, right? If not to create my font replacing script after every update
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 Awesome! Thanks Luke. Any plans to support this type of subtitle with DirectPlay? I think this is the only missing thing on Roku as all other devices can already handle this
Luke 42243 Posted February 26, 2018 Posted February 26, 2018 We already do, but Roku does not support non-latin characters and therefore your language is excluded. You would have to first take that feature request to Roku. It might be worth re-evaluating to see if anything has changed. you could try forcing the direct play with user transcoding permissions as a test.
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 Tested again and the subtitle is not loaded without transcoding. If I'm opening the same video with the same subtitle via the plex roku app is working ok with directplay and latin characters, check my post #4
Luke 42243 Posted February 26, 2018 Posted February 26, 2018 it might require work in the app. @@ebr we might not need that language list anymore that we're using as a filter. Either that or perhaps just add his.
ebr 16336 Posted February 26, 2018 Posted February 26, 2018 Okay, can you get me a sample subtitle that doesn't currently work to test with?
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 (edited) I've attached the one from the above screenshots/logs. Edited February 26, 2018 by shocker
Luke 42243 Posted February 26, 2018 Posted February 26, 2018 better to zip it up so that the forum software doesn't mess with it.
shocker 135 Posted February 26, 2018 Author Posted February 26, 2018 attached. The.Sample.Subtitle.ro.srt.zip
