ZIPNVW 1 Posted February 6, 2018 Posted February 6, 2018 Hello,I am having an issue with Emby being able to see my media collection. I tried to use Emby Docker image in OMV but I did not find any guides and I could not get it working. I installed Emby by SSH into my NAS under the root account. I am able to access the WebUI and it seems to be working. My issue is that when I try to add a share folder to the library, Emby complains that it is not there. I am only guessing but i think it is a permission issue. I am running OMV4. I have a pool of 4 drives under UnionFS. My folder structure is set up where the main folder is "Media". under that, I have a folder for SD Movies, HD Movies, and UHD Moves, TV Shows Etc.Any insight would be appreciated. ZIPN
mastrmind11 722 Posted February 6, 2018 Posted February 6, 2018 what user is the server running as, and what are your permissions on the share(s)? 1
ZIPNVW 1 Posted February 6, 2018 Author Posted February 6, 2018 (edited) Thank you. I am still trying to learn. I will try to figure our the commands to get this info. Edited February 6, 2018 by ZIPNVW
mastrmind11 722 Posted February 6, 2018 Posted February 6, 2018 Thank you. I am still trying to learn. I will try to figure our the commands to get this info. oh, ok. jump into the command line and go to the root of your "media" mount and type ls -l paste the output in a reply. to find the user running emby server type ps aux | grep emby 1
ZIPNVW 1 Posted February 6, 2018 Author Posted February 6, 2018 Just an update. I uninstalled emby and want to reinstalled it. I know how to SSH in as root. What are the preffered way to install it? Should a create a new user "emby"?
Luke 42245 Posted February 6, 2018 Posted February 6, 2018 There's writeup about our docker here: https://hub.docker.com/r/emby/embyserver/
ZIPNVW 1 Posted February 6, 2018 Author Posted February 6, 2018 Is it recommended to do the Docker in OMV or install on the system direct?
mastrmind11 722 Posted February 6, 2018 Posted February 6, 2018 Just an update. I uninstalled emby and want to reinstalled it. I know how to SSH in as root. What are the preffered way to install it? Should a create a new user "emby"? Yes. You should never install/run things as root. Create a new user and run the container as that user. Then make sure that user has r/w to your mount(s), and that's it. The link Luke provided should walk you through it. 1
ZIPNVW 1 Posted February 6, 2018 Author Posted February 6, 2018 I can install Docker-CE in OMV. I could not figure out the setting for Emby so I tried to install directly.
ZIPNVW 1 Posted February 6, 2018 Author Posted February 6, 2018 Yes. You should never install/run things as root. Create a new user and run the container as that user. Then make sure that user has r/w to your mount(s), and that's it. The link Luke provided should walk you through it. The link looks like its dealing with an install when Docker is installed. I only have OMV. I installed the Docker Plug-in. I DL the Emby image from the Repo. I started it with Network Mode set to Host, and I added "/sharefolders/media" to the Host path. I added user "emby" and gave it permissions under ACL to read/write the Media folder and all file/subfolders inside. Under Privileges, I gave user emby read/write. When I try to add the share to "Movies-UHD" that is under "Media", Emby cannot find it.
mastrmind11 722 Posted February 6, 2018 Posted February 6, 2018 Not sure then, I'm not familiar w/ OMV. You might have better luck asking the question in the OMV section. 1
ZIPNVW 1 Posted February 6, 2018 Author Posted February 6, 2018 Thanks... I did but no one responded yet. That is why I wanted to install emby direct and not in a docker so I can reach a greater pool of users in case I had questions.
Solution ZIPNVW 1 Posted February 7, 2018 Author Solution Posted February 7, 2018 Well... I got it to work finally. Thank you very much mastrmind11 for trying to help. I scrapped docker and installed emby via the Atp Tool. I added the repository for Debian9 from Opensuse.org. I guess this helps with permissions since emby started up and found the media folder.I was very close to scraping the whole thing and just install Server2016 but I tried one last time. 1
