CharleyVarrick 284 Posted February 3, 2018 Posted February 3, 2018 (edited) My main server is repeatedly losing disk drives. Getting email from StableBit DrivePool that one or more disks are missing on Server. When this happens, DrivePool shows the disk greyed out and missing. StableBit Scanner doesn't show it, nor Windows Explorer nor Windows disk management. Its plain gone! If I restart the computer, it will show up again, but will disappear again eventually. This is happening with 1-4 year old drives, and right now with a brand new drive (1 hour use). I have already replaced sata cables, tried switching power cable. I have about 10 hard drives pulled aside that behaved like this in the last 18 months or so. This started when I started using StableBit DrivePool/Scanner and also added a 4 ports sata expansion card. Please note that the disappearing drives occur as much when connected to expansion card as to m/b ports. What could cause this, apart from the drives themselves, the sata and power cables? PS: Drives are mostly Western Digital, but I recently tried Seagate 8tb, as is the case with the brand new one that disapeared within an hour of use. PPS: of the 10 hdd that went MiA on me, about 6 did so on my main server, and maybe 4 on my secondary server. Edited February 3, 2018 by jlr19
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 have you checked windows (which version) event viewer for any more info - i suspect you should see errors when the disks disappear as this has been going on for sometime - i doubt its the disks as it appears to be happening too often to multiple disks - if i understood your post could be a driver crash - i assume you have the latest drivers for your controllers (what are you using?) could be a hardware problem with the pc? is the power supply sufficient - i.e. over spec for your needs can you pull the sata card and run without it for a period as a test - could be a conflict with your m/b and or drivers if you move an affected drive to another pc does it exhibit the same behaviour? 1
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 IO Crest 4 Port SATA III PCI-e 2.0 x1 Controller Card Marvell Non-Raid with Low Profile Bracket SI-PEX40064 https://www.amazon.c...a_ICAkzbW5RWZSX For driver, I let DriverBooster find it for me. Again, drives have disappeared even when connected straight to m/b (as is the case right now). PSU is ThermalTake TR2 600w The server has 1 ssd and 7 hdd (4x WD green, 1x WD Blue, and 2 Seagate). No pci devices apart from sata expansion card.
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 (edited) Oh, and Hi PenkethBoy, btw Win7 x64 Ultimate (french canada): I am not to good (I suck) at hunting errors down in Windows, can you point me in the general direction? Edit: I might have found it, in Windows log, under system, about 8 red exclamation mark error telling that hard disk 0 is not ready for access Also about 30 yellow triangle warnings, mostly about error detected on pagefile job, 1 about unable to empty transaction log:damaged might have occured, Edited February 3, 2018 by jlr19
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 in disk management - what disk is disk 0
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 (edited) Disk 0 is the WD blue (1 year old) that disappeared earlier, that I replaced with the Seagate 8tb about 2 hours ago. The disk number is determined by the sata port in use, right (?). In the past, to try to pinpoint the source of the issue, I have tried different sata ports, on the m/b and the expansion card (to no definitve conclusion). Newb question: I tend to think my recurring issues started about when I installed the expansion card, but could it have ill effect on drives that are connected on the motherboard itself? Edited February 3, 2018 by jlr19
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 can you pull the sata card and run without it for a period as a test - could be a conflict with your m/b and or drivers Doing that means one of my two pools needs to go offline. For a few hours, I suppose I could manage, but I'd prefer not to if at all possible.
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 it could well be a conflict between the m/b sata chip and the sata card - hence why as a test removing it and running for a day or two might confirm or not the issue is related to the card - not ideal but would help diagnose is your m/b sata chip also by Marvell and is it the same version by chance as the card Chipset: Marvell 88SE9215
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 Doing that means one of my two pools needs to go offline. For a few hours, I suppose I could manage, but I'd prefer not to if at all possible. Then again, I already have one pool down
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 is your m/b sata chip also by Marvell and is it the same version by chance as the card Chipset: Marvell 88SE9215 M/b is Asus asus p8b75-m/csm according to their website its an Intel B75 chipset (This is klingon to me)
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 ok - check on the ASUS site that you have the latest m/b drivers for m/d loaded - i would disable(uninstall) the driver software you are using and use the official m/b drivers https://www.asus.com/us/Motherboards/P8B75MCSM/HelpDesk_Download/ chipset and sata as a start
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 (edited) ok - check on the ASUS site that you have the latest m/b drivers for m/d loaded - i would disable(uninstall) the driver software you are using and use the official m/b drivers https://www.asus.com/us/Motherboards/P8B75MCSM/HelpDesk_Download/ chipset and sata as a start Should I remove the sata card before? Edited February 3, 2018 by jlr19
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 I did remove the sata card Oddly enough, I am unable to install the sata driver, it barely starts then stop with an error message that this platform is not supported. In device manager, under storage controller, I had a Marvell 6g controller and Covecube disk enumerator, now I have only the later showing
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 you did download the win 7 64 bit sata driver for you board?
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 (edited) you did download the win 7 64 bit sata driver for you board? yes also swapped sata cable's port, as this sometimes gets Windows "thinking". Not today. Edited February 3, 2018 by jlr19
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 In device mgr, under storage controllers, only Covecube disk enumerator, and no unknow/problem device
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 and you are sure you are on 64bit? yes sir
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 I would reinstall windows, but I'd like to be more sure it would fix it. I have an extra 8tb brand new drive, I will try installing that one in place of the invisible one.
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 ok - if the m/b sata drivers wont install then just run the machine for a day or so as is and see if you get anymore errors or disks go missing not sure how often it happens did you try one of the disks in another machine to see if they work ok?
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 we could delete the m/b sata drivers in control panel and let windows find them again - but want to leave that for later - usually that works fine but dont want to get too drastic yet
CharleyVarrick 284 Posted February 3, 2018 Author Posted February 3, 2018 we could delete the m/b sata drivers in control panel and let windows find them again - but want to leave that for later - usually that works fine but dont want to get too drastic yet In Device manager, I have a branch called storage controllers, showing (now) only Covecube Disk Enumerator (before installing the chipset driver, there was a Marvell 6gps controller also there) There is another Device mgr branch called IDE/ATA/ATAPI controllers, this one has 6 entries: 2x ATA channel0, 2x ATA channel1 1x Intel R Series C216 chipset family 2 ports serial ata storage controller 1E08 1x Intel R Series C216 chipset family 4 ports serial ata storage controller 1E00
PenkethBoy 2068 Posted February 3, 2018 Posted February 3, 2018 those are you m/b sata controllers - for it looks like 6 physical ports but lets see if you get any more disks disappear first etc before we delete the drivers etc
