Image quality in TV Guide
capitaineflam25
Hi,
Is this possible to remove maxWidth parameter in images URL for the guide ?
As you can see on the attached image, original image is large enough to be displayed with good quality, but when called from the TV Guide page the parameter ?maxHeight=360&maxWidth=240 makes it too small to be displayed with good quality.
Edited by capitaineflam25
  • Like 1
capitaineflam25
I realized that the maxHeight/maxWidth are OK when the guide is displayed on home.html (They are set to maxHeight=633&maxWidth=422 which is appropriate), but not on livetvitems.html where they are too small.
Tested on 3.2.70.11 beta
Thanks, we'll take a look.
