Koleckai Silvestri 1154 Posted February 2, 2018 Posted February 2, 2018 How do you fast forward and rewind on the Fire TV? Pressing the buttons only skips forward the amount specified in the user settings. If you want to fast forward 15 minutes, it takes a lot of button presses. I am using the standard FireTV Voice Remote.
ebr 16337 Posted February 2, 2018 Posted February 2, 2018 You can use the chapters to jump larger increments.
Koleckai Silvestri 1154 Posted February 2, 2018 Author Posted February 2, 2018 (edited) And how do you do that? I need to relay this information to family with limited technical knowledge. The fewer button pushes the better. Wife already complains about having to turn Closed Captioning on all the time. Edited February 2, 2018 by Koleckai Silvestri
ebr 16337 Posted February 2, 2018 Posted February 2, 2018 Hit any key (arrow down works) and then move along the buttons on the bottom of the OSD and click on the one that looks like a movie clap-board. Then navigate to the chapter you want and click it.
Super Friends 0 Posted September 19, 2018 Posted September 19, 2018 How about letting those that purchase the app adjust the skip forward time?
ebr 16337 Posted September 19, 2018 Posted September 19, 2018 How about letting those that purchase the app adjust the skip forward time? Holding the right/left/ff/rew button down will cause it to start skipping in larger increments over time. You can now skip very quickly through an entire movie.
alok1 14 Posted December 31, 2023 Posted December 31, 2023 On 9/19/2018 at 6:05 PM, ebr said: Holding the right/left/ff/rew button down will cause it to start skipping in larger increments over time When I hold down the Right button, the video skips only 10 seconds and slowly on my Samsung TV. It doesn't skip faster in larger increments over time as you said. Please fix this. Tried on version 1.6.4, 1.6.9, 1.7.0. In every version, this issue is present.
GrimReaper 4898 Posted December 31, 2023 Posted December 31, 2023 16 minutes ago, kakashi55 said: When I hold down the Right button, the video skips only 10 seconds and slowly on my Samsung TV. It doesn't skip faster in larger increments over time as you said. Please fix this. Tried on version 1.6.4, 1.6.9, 1.7.0. In every version, this issue is present. You've posted in the AndroidTV client app section, which is completely different app than the one you're using on Samsung SmartTV. Post under respective forum section to see whether that function is even implemented on that platform and, if so, what is user feedback, whether yours is an isolated issue or systemic one.
