makarai 109 Posted February 2, 2018 Posted February 2, 2018 Hey All, I have been running an Emby server for quite some time now and it works quite reliably. However, i recently migrated from an old FreeNAS system to the current version. I pretty much followed the FreeBSD instructions on here. I think. On the current version of FreeNAS they switched from warden Jails to iocage jails, so this is what i did. #create emby iocage iocage create --name=emby_iocage ip4_addr="igb0|192.168.0.100/24" -r 11.1-RELEASE iocage start emby_iocage #add storage iocage fstab -a emby_iocage /mnt/volume01/multimedia /multimedia01 nullfs rw 0 0 iocage fstab -a emby_iocage /mnt/volume02/multimedia /multimedia02 nullfs rw 0 0 iocage fstab -a emby_iocage /mnt/volume01/db/ssl/user-certs /certs nullfs rw 0 0 iocage console emby_iocage pkg install emby-server # Update FreeBSD ports tree modify installation based on emby recomendations portsnap fetch update portsnap extract # Remove default FFMpeg package pkg delete -f ffmpeg # Reinstall FFMpeg from ports with lame option enabled cd /usr/ports/multimedia/ffmpeg # Install ffmpeg build dependencies pkg install `make build-depends-list | tr '\n' ' ' | sed 's/\/usr\/ports\///g' | sed 's/audio\/lame //g'` make config # enable the lame option # enable the SMB option # enable the ass subtitles option # enable the opus subtitles option # enable the x265 subtitles option make install clean # hit enter a 1000s of times service emby-server onestop pw useradd -n emby -u 1000 -d /nonexistent -s /usr/sbin/nologin pw usermod emby -n emby -u 1000 pw usermod emby -n emby -g 1000 (where ### is the UID and GID of the user I want it to be) chown -R emby:emby /var/db/emby-server sysrc 'emby_server_user=emby' service emby-server onestart chown -R makarai:makarai /var/db/emby-server sysrc 'emby_server_user=makarai' #To Update always to the newest version and not the quarterly! Add folder pkg/repos/edit /usr/local/etc/pkg/repos/FreeBSD.conf FreeBSD: { url: "pkg+http://pkg.FreeBSD.org/${ABI}/latest" } pkg update pkg upgrade I followed the recommended changes in the ff-mpeg. I hope that is still all good. The server runs quite alright. However my error log is still full of random errors. 2018-02-02 08:13:23.445 Error HttpServer: Error in ProcessAccept *** Error Report *** Version: 3.2.70.0 Command line: /usr/local/lib/emby-server/MediaBrowser.Server.Mono.exe -os freebsd -ffmpeg /usr/local/bin/ffmpeg -ffprobe /usr/local/bin/ffprobe -programdata /var/db/emby-server Operating system: Unix 11.1.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: False Mono: 4.8.1 (4.8.1.0 Sat Nov 4 03:09:59 UTC 2017) Processor count: 8 Program data path: /var/db/emby-server Application directory: /usr/local/lib/emby-server System.Net.Sockets.SocketException (0x80004005): The socket has been shut down at Mono.Security.Protocol.Tls.SslStreamBase.EndRead (System.IAsyncResult asyncResult) [0x00057] in <11d29b2234814f928385c7f3dec82910>:0 at Mono.Net.Security.Private.LegacySslStream.EndAuthenticateAsServer (System.IAsyncResult asyncResult) [0x00011] in <65d66c5eaa6a48038257422d3c294dab>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00021] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at SocketHttpListener.Net.HttpConnection+<InitStream>c__async0.MoveNext () [0x000d1] in <162eaf81ed7b42da88afc3f7f8f3b047>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at SocketHttpListener.Net.HttpConnection+<Create>c__async1.MoveNext () [0x000b5] in <162eaf81ed7b42da88afc3f7f8f3b047>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at SocketHttpListener.Net.EndPointListener+<ProcessAccept>c__async0.MoveNext () [0x0011b] in <162eaf81ed7b42da88afc3f7f8f3b047>:0 System.Net.Sockets.SocketException at Mono.Security.Protocol.Tls.SslStreamBase.EndRead (System.IAsyncResult asyncResult) [0x00057] in <11d29b2234814f928385c7f3dec82910>:0 at Mono.Net.Security.Private.LegacySslStream.EndAuthenticateAsServer (System.IAsyncResult asyncResult) [0x00011] in <65d66c5eaa6a48038257422d3c294dab>:0 at System.Threading.Tasks.TaskFactory`1[TResult].FromAsyncCoreLogic (System.IAsyncResult iar, System.Func`2[T,TResult] endFunction, System.Action`1[T] endAction, System.Threading.Tasks.Task`1[TResult] promise, System.Boolean requiresSynchronization) [0x00021] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at SocketHttpListener.Net.HttpConnection+<InitStream>c__async0.MoveNext () [0x000d1] in <162eaf81ed7b42da88afc3f7f8f3b047>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable+ConfiguredTaskAwaiter.GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at SocketHttpListener.Net.HttpConnection+<Create>c__async1.MoveNext () [0x000b5] in <162eaf81ed7b42da88afc3f7f8f3b047>:0 --- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw () [0x0000c] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess (System.Threading.Tasks.Task task) [0x0004e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification (System.Threading.Tasks.Task task) [0x0002e] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.TaskAwaiter.ValidateEnd (System.Threading.Tasks.Task task) [0x0000b] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1+ConfiguredTaskAwaiter[TResult].GetResult () [0x00000] in <dbb16e0bacdc4a0f87478e401bc29b6c>:0 at SocketHttpListener.Net.EndPointListener+<ProcessAccept>c__async0.MoveNext () [0x0011b] in <162eaf81ed7b42da88afc3f7f8f3b047>:0 Maybe some of the advanced people can point me to the right direction. Cheers Mak
makarai 109 Posted February 2, 2018 Author Posted February 2, 2018 (edited) Hey Luke, Thanks for answering, the only problem i have are the errors in the logs and that the emby android app doesn't play specific files. I am wondering if the way i installed emby is 100% correctly. I attached my log file. Log.txt Edited February 2, 2018 by makarai
Luke 42238 Posted February 2, 2018 Posted February 2, 2018 Can we go over an example of something not playing? thanks.
