Allan Cameron 40 Posted September 9, 2018 Author Posted September 9, 2018 Yep, plex built an in-app screensaver that activates for their app rather than the user selected Roku one. The old emby Roku app did this, but.. didn't check if music was playing.. but could've and not instantiated the screen saver. That's what I mean. It is almost like no in-app screen saver is present. And instead a timer is used to pop you onto the now playing screen. Instead of the screen saver being the now playing screen if music plays, when music isn't play show bouncy emby logo. Sent from my Nexus 7 using Tapatalk Then it looks like we need to be using a built in app screensaver like Plex does. Problem solved !
ebr 16335 Posted September 10, 2018 Posted September 10, 2018 Then it looks like we need to be using a built in app screensaver like Plex does. Problem solved ! Yes, that is correct. We will do this.
Faust666 1 Posted September 14, 2018 Posted September 14, 2018 Same issues on my four different Roku .
Luke 42243 Posted September 14, 2018 Posted September 14, 2018 We are looking into this, thanks guys.
