uzbek 0 Posted February 1, 2018 Posted February 1, 2018 Info section keeps reverting back to the original that it pulled from internet even tho I had already changed it to how I wanted it. It seems to be doing it atleast when it tries to update subtitle selection for the video. Would it be possible to add like "LOCK" option for the info section of the video, so it wouldnt try to refresh it after user has already made it how they like it. For example, I add finnish info under the english info it pulled from the internet. And those finnish parts keep disappearing. Super annoying to add the correct info multiple times.
Luke 42204 Posted February 2, 2018 Posted February 2, 2018 Hi there, can you please discuss a specific example of this? Thanks !
uzbek 0 Posted February 2, 2018 Author Posted February 2, 2018 (edited) Hi there, can you please discuss a specific example of this? Thanks ! Like for example, Sel8nne movie that I have. https://i.imgur.com/r8obpUO.png First image has the info that it pulls from internet. Second image has me edit the finnish info to it. https://i.imgur.com/YkAspLa.png Then after some time it has somehow reverted back to first image. Edited February 2, 2018 by uzbek
uzbek 0 Posted February 2, 2018 Author Posted February 2, 2018 Is this a local video on your server? yes
Luke 42204 Posted February 2, 2018 Posted February 2, 2018 have you enabled saving metadata to nfo files in your media folders?
uzbek 0 Posted February 3, 2018 Author Posted February 3, 2018 have you enabled saving metadata to nfo files in your media folders? Yes https://i.imgur.com/oNcJDPH.png
Happy2Play 9802 Posted February 3, 2018 Posted February 3, 2018 Does the overview correspond with what is displayed in the nfo?
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 (edited) Does the overview correspond with what is displayed in the nfo? Where would I find that? Edited February 4, 2018 by uzbek
Luke 42204 Posted February 4, 2018 Posted February 4, 2018 Check the overview that you see in the emby metadata editor and compare that to the overview inside the .nfo file.
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 Check the overview that you see in the emby metadata editor and compare that to the overview inside the .nfo file. Where is the nfo file located?
Luke 42204 Posted February 4, 2018 Posted February 4, 2018 It would be in the same folder as the video, usually with the same file name.
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 It would be in the same folder as the video, usually with the same file name. There is no nfo file in any of my stuff?
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 Should it create nfo file when I edit the overview?
Happy2Play 9802 Posted February 4, 2018 Posted February 4, 2018 Should it create nfo file when I edit the overview? Only if you have "Save artwork and metadata into media folders" enabled per library.
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 Only if you have "Save artwork and metadata into media folders" enabled per library. Ok, I didnt have that in the folder options, lets see if that fixes it
Luke 42204 Posted February 4, 2018 Posted February 4, 2018 Nonetheless you still shouldn't be having this problem no matter how you configure the setting. Can you try to figure out around what time it changes? Then we can look at the server log from that time frame.
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 (edited) Nonetheless you still shouldn't be having this problem no matter how you configure the setting. Can you try to figure out around what time it changes? Then we can look at the server log from that time frame. Well it still reverts to something else than I edited, cos the linebreak (<p>) goes missing now. how it looks now after it reverted: https://i.imgur.com/ytOYfjS.png Edited February 4, 2018 by uzbek
Happy2Play 9802 Posted February 4, 2018 Posted February 4, 2018 Well it still reverts to something else than I edited, cos the linebreak (<p>) goes missing now. Are there errors in the log when you do that?
Luke 42204 Posted February 4, 2018 Posted February 4, 2018 Yes please try to capture the information requested. Thanks.
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 You guys cant make this occur on your end? If you edit the overview and put like some random text there and <p> and stuff and then edit subtitles to make all the <p>'s disappear
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 Are there errors in the log when you do that? Yes please try to capture the information requested. Thanks. Where is the log I should look for?
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 Like anything I do just makes it reload the whole thing from somewhere (probably the nfo now) and the nfo doesnt have the linebreaks (<p>'s) in it. So it just blend the english overview to the finnish overview that I have added.
Luke 42204 Posted February 4, 2018 Posted February 4, 2018 can you try making a different kind of change besides that? because we do not officially support html content in overviews so perhaps that is the problem.
uzbek 0 Posted February 4, 2018 Author Posted February 4, 2018 can you try making a different kind of change besides that? because we do not officially support html content in overviews so perhaps that is the problem. How do I make an empty line the way it would work?
