Baenwort 119 Posted February 1, 2018 Posted February 1, 2018 (edited) So I can reach scheduledirect.org from both a W10 PC, TrueOS laptop, Android and iOS phones, and from the FreeNAS system itself via the CLI and using PING. However, Emby server reports that it can reach scheduledirect when I try to retrieve lineup data or when I try to re-add scheduledirect after deleting the entry in the LiveTV tab of the server config. It even works from the server jail CLI. I've attached the Emby log with the error and below is the result of a ping command from the jail at the same time the log was generated. root@emby_2:/ # ping -c 5 json.schedulesdirect.org PING lb-sd-832157689.us-east-1.elb.amazonaws.com (52.4.157.82): 56 data bytes 64 bytes from 52.4.157.82: icmp_seq=0 ttl=227 time=63.500 ms 64 bytes from 52.4.157.82: icmp_seq=1 ttl=227 time=56.190 ms 64 bytes from 52.4.157.82: icmp_seq=2 ttl=227 time=50.479 ms 64 bytes from 52.4.157.82: icmp_seq=3 ttl=227 time=51.388 ms 64 bytes from 52.4.157.82: icmp_seq=4 ttl=227 time=51.149 ms --- lb-sd-832157689.us-east-1.elb.amazonaws.com ping statistics --- 5 packets transmitted, 5 packets received, 0.0% packet loss round-trip min/avg/max/stddev = 50.479/54.541/63.500/4.918 ms SDerrorLog.txt Edited February 1, 2018 by Baenwort
Luke 42238 Posted February 1, 2018 Posted February 1, 2018 It's not just schedules direct it's all other domains as well so it looks like you need to configure the network connection of the jail.
