paulbagshaw 2 Posted February 1, 2018 Posted February 1, 2018 Hi. I seem to be having trouble saving any changes I make to the series recording options. I can get into the settings OK but when I change the time setting from 'Anytme' to 'Around 7:30 pm', the change never saves and it always reverts back to 'Anytime'. Am i missing something? i.e. is there a save button somewhere or should the save be automatic?
Luke 42243 Posted February 1, 2018 Posted February 1, 2018 Hi, are you using a live tv plugin? And what kind of tuner do you have?
paulbagshaw 2 Posted February 1, 2018 Author Posted February 1, 2018 Hi. Thanks for the quick reply mate. No plugin (I think) - just using the features that come with the Emby server out of the box. I navigate to the 'series' section and open the recording options from there. I'm using a HD Homerun tuner.
Luke 42243 Posted February 1, 2018 Posted February 1, 2018 Ok, can you please attach the emby server log from the time that you attempted to do this? you can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks !
