shocker 135 Posted January 30, 2018 Posted January 30, 2018 Hello, If I'm watching a movie with internal subtitles (added into the mkv container), it's out of sync, there is 1-2s delay. Is this a known issue? Thanks
ebr 16337 Posted January 30, 2018 Posted January 30, 2018 No. We'd have to look at exactly how the item is playing. Thanks. How to Report a Problem
shocker 135 Posted January 30, 2018 Author Posted January 30, 2018 (edited) No. We'd have to look at exactly how the item is playing. Thanks. How to Report a Problem added the log Edit1: Tested on nvidia shield and it's working. Not sure if this is relevant or of the app is the same. This is only happening on Fire Stick and Apple TV shows a duplicate subtitle for this (i have another one opened for this on Apple TV). ffmpeg-remux-a3a6c6a0-1450-44cc-a919-92970028345a.txt.zip Edited January 30, 2018 by shocker
Solution ebr 16337 Posted January 30, 2018 Solution Posted January 30, 2018 Okay, on the Shield, was the item direct playing? On the FTV Stick it is having to remux to convert the audio which then means that it has to extract the subtitles from the video and deliver them externally. It may be in this situation that they get slightly out of kilter but we'll see what Luke thinks. In an upcoming version of the Fire TV app (in beta now actually) it shouldn't need to remux this item on the server anymore which may side-step this issue (but not really solve it). 1
shocker 135 Posted January 30, 2018 Author Posted January 30, 2018 Yes, on shield is in direct play, so that's the root cause If you want I can beta test for you guys, just let me know.
ebr 16337 Posted January 30, 2018 Posted January 30, 2018 If you want I can beta test for you guys, just let me know. It appears you already are .
shocker 135 Posted February 2, 2018 Author Posted February 2, 2018 I can confirm that this is fixed on v1.5.38.
joggs 24 Posted March 30, 2018 Posted March 30, 2018 (edited) Solved my problem as well. Thanks Edited March 30, 2018 by joggs
