tjustice86 0 Posted January 29, 2018 Posted January 29, 2018 Hello, I have been trying to set-up Emby and allow remote access with docker containers. No matter what I do I cannot connect from any app including the web app. If I put in the URL it will connect just fine as long as force SSL is not enabled, if force SSL is enabled then I get an error that there has been too many redirects. I have looked at the posts about setting up remote access and setting up reverse proxy and nothing is working, I am not sure where to begin any help would be greatly appreciated Thank you!
Luke 42245 Posted January 29, 2018 Posted January 29, 2018 what url are you putting in that ends up with too many redirects?
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 what url are you putting in that ends up with too many redirects? https://emby.domain.com That is how the reverse proxy is configured.
Luke 42245 Posted January 29, 2018 Posted January 29, 2018 Then i think what is happening is the reverse proxy is forwarding to emby over plain http so you should just keep that box unchecked and let your proxy handle it.
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 (edited) Okay, yes that fixes that issue, but I am still unable to connect via the emby connect and the different apps. Using the Chrome debugger I get an error stating that Mixed Content: The page at 'https://app.emby.media/home.html' was loaded over HTTPS, but requested an insecure resource 'http://XXX.XXX.XXX.XXX:8096/emby/Playback/BitrateTest?Size=500000'. This request has been blocked; the content must be served over HTTPS. Edited January 29, 2018 by tjustice86
dcrdev 255 Posted January 29, 2018 Posted January 29, 2018 Set your domain in custom domain, under advanced. Then in /var/lib/emby/config/system.xml change or add: <EnableHttps>true</EnableHttps> <RequireHttps>false</RequireHttps> Then restart emby: systemctl restart emby-server It will solve any issues you're having - that is provided you have configured your proxy correctly.
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 I still get the mixed content error.
dcrdev 255 Posted January 29, 2018 Posted January 29, 2018 (edited) Post your proxy configuration, a screenshot of your Emby dashboard and also the "Advanced" screen. Edit: Should look something like this: I'm guessing you're using nginx as with most people here - I'm using Apache, but you might find bits from my config useful: <VirtualHost *:80> ServerName sub.domain.com LogLevel warn ErrorLog "/storage/WWW/sub.domain.com/log/error_log" CustomLog "/storage/WWW/sub.domain.com/log/access_log" combined Redirect permanent / https://sub.domain.com/ </VirtualHost> <VirtualHost *:443> ServerName sub.domain.com LogLevel warn ErrorLog "/storage/WWW/sub.domain.com/log/ssl_error_log" TransferLog "/storage/WWW/sub.domain.com/log/ssl_access_log" CustomLog "/storage/WWW/sub.domain.com/log/ssl_request_log" \ "%t %h %{SSL_PROTOCOL}x %{SSL_CIPHER}x \"%r\" %b" RewriteEngine On RewriteCond %{HTTP:Connection} Upgrade [NC] RewriteCond %{HTTP:Upgrade} websocket [NC] RewriteRule /(.*) ws://127.0.0.1:8096/$1 [P,L] SSLProxyEngine On RequestHeader set Front-End-Https "On" ProxyPreserveHost On ProxyRequests off <Location /> ProxyPass http://127.0.0.1:8096/ ProxyPassReverse / </Location> SSLEngine on SSLCertificateFile /etc/httpd/ssl/server.pem SSLCertificateChainFile /etc/pki/CA/cacert.pem SSLCertificateKeyFile /etc/httpd/ssl/server.key SSLProtocol all -SSLv2 -SSLv3 -TLSv1 SSLCipherSuite ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA3$ SSLHonorCipherOrder on # HSTS (mod_headers is required) (15768000 seconds = 6 months) Header always set Strict-Transport-Security "max-age=15768000" </VirtualHost> Edited January 29, 2018 by dcrdev
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 I am using jwilder's nginx-proxy docker image. Here is my container for Emby:
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 (edited) Emby settings: Edited January 29, 2018 by tjustice86
dcrdev 255 Posted January 29, 2018 Posted January 29, 2018 (edited) This: Emby settings: Tells me that you didn't do this: Set your domain in custom domain, under advanced. Then in /var/lib/emby/config/system.xml change or add: <EnableHttps>true</EnableHttps> <RequireHttps>false</RequireHttps>Then restart emby: systemctl restart emby-server It will solve any issues you're having - that is provided you have configured your proxy correctly. Or you didn't restart the service afterward - double check the options I quoted above. Edited January 29, 2018 by dcrdev
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 (edited) Since this is a docker container there is no emby-server service. And I just noticed that when I restarted the container it overwrote the system.xml file (strange as it has not done this before). Would restarting the server in the dashboard commit the change? Edit: No it will not pick up the change Edit2: I don't mean to be difficult, and I know I messed that up to begin with but can you obfuscate the domain name in that picture. Edited January 29, 2018 by tjustice86
dcrdev 255 Posted January 29, 2018 Posted January 29, 2018 Since this is a docker container there is no emby-server service. And I just noticed that when I restarted the container it overwrote the system.xml file (strange as it has not done this before). Would restarting the server in the dashboard commit the change? Edit: No it will not pick up the change Edit2: I don't mean to be difficult, and I know I messed that up to begin with but can you obfuscate the domain name in that picture. Right, edited my post where I had quoted you. Try editing system.xml with the container shut down first.
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 (edited) Right, edited my post where I had quoted you. Try editing system.xml with the container shut down first. No dice. I have rebooted the entire server, the settings.xml stays the way it is supposed to and Emby still doesn't pick up the change. Edited January 29, 2018 by tjustice86
dcrdev 255 Posted January 29, 2018 Posted January 29, 2018 No dice. I have rebooted the entire server, the settings.xml stays the way it is supposed to and Emby still doesn't pick up the change. When you say the settings.xml "stays the way it is supposed to" , is that to say that the changes I suggested have persisted in the file? That being the case what does it say on the dashboard - is the main external address being listed as http or https? Can you post your system.xml - obviously removing any personal information ?
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 When you say the settings.xml "stays the way it is supposed to" , is that to say that the changes I suggested have persisted in the file? That being the case what does it say on the dashboard - is the main external address being listed as http or https? Can you post your system.xml - obviously removing any personal information ? ?xml version="1.0"?> <ServerConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <EnableDebugLevelLogging>false</EnableDebugLevelLogging> <EnableAutoUpdate>true</EnableAutoUpdate> <LogFileRetentionDays>3</LogFileRetentionDays> <RunAtStartup>false</RunAtStartup> <IsStartupWizardCompleted>true</IsStartupWizardCompleted> <EnableUPnP>false</EnableUPnP> <PublicPort>80</PublicPort> <PublicHttpsPort>443</PublicHttpsPort> <HttpServerPortNumber>8096</HttpServerPortNumber> <HttpsPortNumber>8920</HttpsPortNumber> <EnableHttps>true</EnableHttps> <EnableNormalizedItemByNameIds>true</EnableNormalizedItemByNameIds> <IsPortAuthorized>true</IsPortAuthorized> <AutoRunWebApp>true</AutoRunWebApp> <EnableRemoteAccess>true</EnableRemoteAccess> <EnableCaseSensitiveItemIds>true</EnableCaseSensitiveItemIds> <DisableLiveTvChannelUserDataName>true</DisableLiveTvChannelUserDataName> <PreferredMetadataLanguage>en</PreferredMetadataLanguage> <MetadataCountryCode>US</MetadataCountryCode> <SortReplaceCharacters> <string>.</string> <string>+</string> <string>%</string> </SortReplaceCharacters> <SortRemoveCharacters> <string>,</string> <string>&</string> <string>-</string> <string>{</string> <string>}</string> <string>'</string> </SortRemoveCharacters> <SortRemoveWords> <string>the</string> <string>a</string> <string>an</string> </SortRemoveWords> <MinResumePct>5</MinResumePct> <MaxResumePct>90</MaxResumePct> <MinResumeDurationSeconds>300</MinResumeDurationSeconds> <LibraryMonitorDelay>60</LibraryMonitorDelay> <EnableDashboardResponseCaching>true</EnableDashboardResponseCaching> <ImageSavingConvention>Compatible</ImageSavingConvention> <MetadataOptions> <MetadataOptions> <ItemType>Book</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Movie</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>MusicVideo</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>The Open Movie Database</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>The Open Movie Database</string> <string>FanArt</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Series</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheMovieDb</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>TheMovieDb</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>MusicAlbum</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>0</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheAudioDB</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>MusicArtist</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheAudioDB</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>BoxSet</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Season</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>0</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheMovieDb</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>FanArt</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Episode</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>0</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>The Open Movie Database</string> <string>TheMovieDb</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>The Open Movie Database</string> <string>TheMovieDb</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> </MetadataOptions> <EnableAutomaticRestart>true</EnableAutomaticRestart> <SkipDeserializationForBasicTypes>true</SkipDeserializationForBasicTypes> <ServerName>BDE</ServerName> <WanDdns>emby.domain.com</WanDdns> <UICulture>en-US</UICulture> <SaveMetadataHidden>false</SaveMetadataHidden> <ContentTypes /> <RemoteClientBitrateLimit>0</RemoteClientBitrateLimit> <SchemaVersion>0</SchemaVersion> <EnableAnonymousUsageReporting>true</EnableAnonymousUsageReporting> <EnableFolderView>false</EnableFolderView> <EnableGroupingIntoCollections>false</EnableGroupingIntoCollections> <DisplaySpecialsWithinSeasons>true</DisplaySpecialsWithinSeasons> <DisplayCollectionsView>false</DisplayCollectionsView> <LocalNetworkAddresses /> <CodecsUsed /> <EnableChannelView>false</EnableChannelView> <EnableExternalContentInSuggestions>true</EnableExternalContentInSuggestions> <RequireHttps>false</RequireHttps> <IsBehindProxy>false</IsBehindProxy> <EnableNewOmdbSupport>true</EnableNewOmdbSupport> <ImageExtractionTimeoutMs>0</ImageExtractionTimeoutMs> <PathSubstitutions /> <EnableSimpleArtistDetection>true</EnableSimpleArtistDetection> </ServerConfiguration> And my last post was current screenshot of server dashboard.
Solution dcrdev 255 Posted January 29, 2018 Solution Posted January 29, 2018 Just tested this in a docker container - Forgot you need this also: <IsBehindProxy>true</IsBehindProxy> [root@hell01-serv01 srv]# docker run -d --volume /srv/emby:/config --publish 8096:8096 --publish 8920:8920 --env UID=986 --env GID=982 emby/embyserver:latest Unable to find image 'emby/embyserver:latest' locally Trying to pull repository docker.io/emby/embyserver ... latest: Pulling from docker.io/emby/embyserver 0ffadd58f2a6: Pull complete 5cacdd04b1d8: Pull complete 706399fd142b: Pull complete de3650ad955a: Pull complete ab4911d1f38c: Pull complete Digest: sha256:6ebefc5249c492e82c6c973ab42e75ae0d6de0960f03681050ca89e8ea1524b1 0c4cce4326aa125daa64900118380f14d07ef4e3e428077bd0fe03c35072265f [root@hell01-serv01 srv]# ls emby cache config data localization logs root [root@hell01-serv01 srv]# nano emby/config/system.xml [root@hell01-serv01 srv]# docker ps CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES 0c4cce4326aa emby/embyserver:latest "/init" 6 minutes ago Up 6 minutes 1900/udp, 0.0.0.0:8096->8096/tcp, 7359/udp, 0.0.0.0:8920->8920/tcp agitated_volhard 74dd44873f1e haugene/transmission-openvpn "dumb-init /etc/openv" 22 hours ago Up 22 hours 0.0.0.0:9091->9091/tcp transmission-openvpn c5187fa808aa collabora/code "/bin/sh -c 'bash sta" 47 hours ago Up 47 hours 127.0.0.1:9980->9980/tcp collabora-online [root@hell01-serv01 srv]# docker restart agitated_volhard agitated_volhard [root@hell01-serv01 config]# cat system.xml <?xml version="1.0"?> <ServerConfiguration xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <EnableDebugLevelLogging>false</EnableDebugLevelLogging> <EnableAutoUpdate>true</EnableAutoUpdate> <LogFileRetentionDays>3</LogFileRetentionDays> <RunAtStartup>false</RunAtStartup> <IsStartupWizardCompleted>true</IsStartupWizardCompleted> <EnableUPnP>true</EnableUPnP> <PublicPort>80</PublicPort> <PublicHttpsPort>443</PublicHttpsPort> <HttpServerPortNumber>8096</HttpServerPortNumber> <HttpsPortNumber>8920</HttpsPortNumber> <EnableHttps>true</EnableHttps> <EnableNormalizedItemByNameIds>true</EnableNormalizedItemByNameIds> <IsPortAuthorized>true</IsPortAuthorized> <AutoRunWebApp>true</AutoRunWebApp> <EnableRemoteAccess>true</EnableRemoteAccess> <EnableCaseSensitiveItemIds>true</EnableCaseSensitiveItemIds> <DisableLiveTvChannelUserDataName>true</DisableLiveTvChannelUserDataName> <PreferredMetadataLanguage>en</PreferredMetadataLanguage> <MetadataCountryCode>US</MetadataCountryCode> <SortReplaceCharacters> <string>.</string> <string>+</string> <string>%</string> </SortReplaceCharacters> <SortRemoveCharacters> <string>,</string> <string>&</string> <string>-</string> <string>{</string> <string>}</string> <string>'</string> </SortRemoveCharacters> <SortRemoveWords> <string>the</string> <string>a</string> <string>an</string> </SortRemoveWords> <MinResumePct>5</MinResumePct> <MaxResumePct>90</MaxResumePct> <MinResumeDurationSeconds>300</MinResumeDurationSeconds> <LibraryMonitorDelay>60</LibraryMonitorDelay> <EnableDashboardResponseCaching>true</EnableDashboardResponseCaching> <ImageSavingConvention>Compatible</ImageSavingConvention> <MetadataOptions> <MetadataOptions> <ItemType>Book</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Movie</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>MusicVideo</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>The Open Movie Database</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>The Open Movie Database</string> <string>FanArt</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Series</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheMovieDb</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>TheMovieDb</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>MusicAlbum</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>0</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheAudioDB</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>MusicArtist</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheAudioDB</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>BoxSet</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>1</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Logo</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Art</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Disc</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers /> <MetadataFetcherOrder /> <DisabledImageFetchers /> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Season</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>0</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Banner</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> <ImageOption> <Type>Thumb</Type> <Limit>0</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>TheMovieDb</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>FanArt</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> <MetadataOptions> <ItemType>Episode</ItemType> <ImageOptions> <ImageOption> <Type>Backdrop</Type> <Limit>0</Limit> <MinWidth>1280</MinWidth> </ImageOption> <ImageOption> <Type>Primary</Type> <Limit>1</Limit> <MinWidth>0</MinWidth> </ImageOption> </ImageOptions> <DisabledMetadataSavers /> <LocalMetadataReaderOrder /> <DisabledMetadataFetchers> <string>The Open Movie Database</string> <string>TheMovieDb</string> </DisabledMetadataFetchers> <MetadataFetcherOrder /> <DisabledImageFetchers> <string>The Open Movie Database</string> <string>TheMovieDb</string> </DisabledImageFetchers> <ImageFetcherOrder /> </MetadataOptions> </MetadataOptions> <EnableAutomaticRestart>true</EnableAutomaticRestart> <SkipDeserializationForBasicTypes>true</SkipDeserializationForBasicTypes> <WanDdns>sub.domain.com</WanDdns> <UICulture>en-GB</UICulture> <SaveMetadataHidden>false</SaveMetadataHidden> <ContentTypes /> <RemoteClientBitrateLimit>0</RemoteClientBitrateLimit> <SchemaVersion>0</SchemaVersion> <EnableAnonymousUsageReporting>true</EnableAnonymousUsageReporting> <EnableFolderView>false</EnableFolderView> <EnableGroupingIntoCollections>false</EnableGroupingIntoCollections> <DisplaySpecialsWithinSeasons>true</DisplaySpecialsWithinSeasons> <DisplayCollectionsView>false</DisplayCollectionsView> <LocalNetworkAddresses /> <CodecsUsed /> <EnableChannelView>false</EnableChannelView> <EnableExternalContentInSuggestions>true</EnableExternalContentInSuggestions> <RequireHttps>false</RequireHttps> <IsBehindProxy>true</IsBehindProxy> <EnableNewOmdbSupport>true</EnableNewOmdbSupport> <ImageExtractionTimeoutMs>0</ImageExtractionTimeoutMs> <PathSubstitutions /> <EnableSimpleArtistDetection>true</EnableSimpleArtistDetection> </ServerConfiguration> 1
tjustice86 0 Posted January 29, 2018 Author Posted January 29, 2018 That did the trick!!! Thank you! I was about to start pulling my hair out!
