Luke 42243 Posted January 29, 2018 Posted January 29, 2018 You should really think about making a version that allows the keyboard controls. Some videos look just fine and don't relly need adjusting, some are way off. It would be nice to adjust it on the fly. What do you want to adjust on the fly?
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 could I just replace the external mpv config file with the one in emby and have keyboard control? Use it as an external player.
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 The saturation, contrast and brightness. Some videos are washed out, some are oversaturated and some are dark.
Guest asrequested Posted January 29, 2018 Posted January 29, 2018 could I just replace the external mpv config file with the one in emby and have keyboard control? Use it as an external player. The other thing you could do is use mpv as an external player. That would give you the options you want.
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 That's what I'm talking about. Making a copy of the config file in Emby and putting it in the external MPV player. Will that work.
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 I tried using it that way but it stuttered really bad and crashed.
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 And the madvr wouldn't work at all.
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 When I stream movies on amazon prime or kodi they look perfect. it's only through emby that it's doing this.
Allenwalters 1 Posted January 29, 2018 Author Posted January 29, 2018 It also did it with P@#x, that's why I switched to Emby.
Guest asrequested Posted January 29, 2018 Posted January 29, 2018 (edited) As an external player, theater has no involvement. You'd need an mpv.conf for some things, and use keyboard control, for others. I can help you configure that. You'll need audio pass through and HWA, but it's easy to do. I'm at work, right now, but tonight I can walk you through it, tonight. Edited January 29, 2018 by Doofus
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 can we do it this weekend? I work 2nd shift.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 Do you think direct play could have anything to do with it? Maybe I can have Emby handle the video instead.
Guest asrequested Posted January 30, 2018 Posted January 30, 2018 You want the server to transcode it? I can just make a zip file with everything you need to use for an external player.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 Can I just downloload k-lite codec pack for it?
Guest asrequested Posted January 30, 2018 Posted January 30, 2018 No. MPV is ffmpeg not directshow. It's self-contained.
Guest asrequested Posted January 30, 2018 Posted January 30, 2018 Here you go. I've made it portable, so it won't interfere with other mpv configs. I've added a few exrta things in the conf. Like forced subs only when using PGS subs that have forced text, audio exclusivity and one or two others. If you don't want them, you can just delete the command. Unzip anywhere and use as your external player.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 Thank you. Best support I've ever had on a product. You guys are great.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 I'll try it out and let you know how it works.
Guest asrequested Posted January 30, 2018 Posted January 30, 2018 Any issues, just let me know. We can always adjust a few things.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 It works exactly like the built in player. I downloaded the K-lite standard using the built in mpc-hcx64 player and played some of the files directly with it and they look perfect. No oversaturation at all and way less banding. I think it's the player that's the problem.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 Now if I can configure it right I can use it as the external player.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 The 4K copy of E.T. was really bad with the mcplayer but plays perfect with mpc-hc.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 And I'm not seeing any stuttering.
Allenwalters 1 Posted January 30, 2018 Author Posted January 30, 2018 The only thing I noticed with the one you sent is the HDR doesn't kick in. Other than that it's the same.
