TimOlaf 3 Posted January 28, 2018 Posted January 28, 2018 I am running Emby server for my music collection, and using the web app to play music. (Chrome browser shows "http://app.emby.media\...."in the URL field.) I use saved playlists, but I'm wondering if there's a way to just, on the fly, decided what to "play next", like a live, current queue. I would like to just add a couple of albums to play in order, just for that session, without having to create a playlist from scratch that I won't ever want to listen to again in the future. I have seen this feature in many media players. Does it exist here? Thanks!
Luke 42221 Posted January 28, 2018 Posted January 28, 2018 hi @@TimOlaf, have you tried clicking one of the 3-dot menus that are on top of posters while music is already playing?
TimOlaf 3 Posted January 28, 2018 Author Posted January 28, 2018 I had not tried that, thanks! I see that option is only available when you are looking just at the one, individual album. I usually play albums from the album list. This is easy enough. Finally, is there a way to view the entire current queue? For some reason I cannot find that. I would like to be able to add an album, but then go into the queue and remove a particular track.
Luke 42221 Posted January 28, 2018 Posted January 28, 2018 When you're playing music you'll see the now playing bar at the bottom. On the right side of that there is a playlist icon you can click.
TimOlaf 3 Posted January 28, 2018 Author Posted January 28, 2018 I thought that was the playlist icon, but when I click that, it only brings up the currently playing track and nothing else. It's the same as if I click anywhere on the bottom "now playing" banner. The playlist icon does get a green circle on it, right after I click it, so I'm pretty sure Emby knows that icon was clicked. But only brings up the current single track. It shows the track playing, at the top of an otherwise dark screen, with the track progress, etc. But no other tracks. However, it does continue to play the album, so the other tracks are definitely in the queue.
Luke 42221 Posted January 28, 2018 Posted January 28, 2018 Are you remote controlling another device?
TimOlaf 3 Posted January 28, 2018 Author Posted January 28, 2018 My music is on my desktop, running Emby server. I'm on a laptop on the same wireless network, logged into my Emby server on the desktop. If I understand the question, I think the answer is yes.
TimOlaf 3 Posted January 28, 2018 Author Posted January 28, 2018 (edited) Ok, I moved to my desktop, and now I am able to utlize the playlist icon. That works. Thanks. It just doesn't work from the remote laptop. I just realized, perhaps the "other device" you meant was playing to a chromecast, I'm sorry I just realized. So, I was using the laptop to access the desktop server, but actually was casting to a chromecast. Edited January 28, 2018 by TimOlaf
Luke 42221 Posted January 28, 2018 Posted January 28, 2018 Currently playlist manipulation is not yet added when remote controlling, but it's planned for the future. thanks.
mistercoffee 0 Posted July 10, 2019 Posted July 10, 2019 Currently playlist manipulation is not yet added when remote controlling, but it's planned for the future. thanks. Hi @@Luke, is this still planned? Thanks!
