Senna 368 Posted February 16, 2018 Posted February 16, 2018 (edited) When DIRECT STREAMING local movie library content, it seems that same srt is displayed twice. I tested with changing subtitles styles in Apple TV settings by changing color to yellow and changing text in srt, to rule out embedded sub display. When playback of movie is started by pre selecting srt, I see yellow subtitles with right timing AND white subtitles with wrong slightly delayed timing. When I click FW/BW I see a white text appearing "Subtitles Loading". When Apple TV settings for closed captions is turned off, I see only white subtitles from srt. After playing for some time, some subtitle dialogs are skipped. Emby Settings tested for above symptoms : Playback settings Subtitle Selection: Default + Smart + Always Show Subtitles Default Subtitle language: Dutch Content: English/Dutch embedded subs + Dutch srt Allow subtitle extraction on the fly: not selected When I set Playback settings subtitle Selection to never and pre select None for Play with these settings, i get yellow subtitles but NOT the srt subtitles where I changed the text from !! @@Luke & @ebr, are subtitles cached on server ? Edit 1: Seems also that in Playback Settings Subtitle Selection, that this field isn't saved correctly when a setting is changed and reverts back to A previous setting, when an app restart from menu is done. Edited February 17, 2018 by Senna
ebr 16335 Posted February 17, 2018 Posted February 17, 2018 Edit 1: Seems also that in Playback Settings Subtitle Selection, that this field isn't saved correctly when a setting is changed and reverts back to A previous setting, when an app restart from menu is done. Sorry, but I didn't follow that at all...
Senna 368 Posted February 17, 2018 Posted February 17, 2018 User menu > Playback Settings > Subtitle Selection > ((Default, Smart, Only Forced, Always show Subtitles, Never)=field) When change in above is done, change is not saved when: User menu > Restart App
ebr 16335 Posted February 17, 2018 Posted February 17, 2018 If you back out to the home screen and then re-start the app, are they saved then?
Senna 368 Posted February 17, 2018 Posted February 17, 2018 No, that doesn't work either. Can't figure out the logic when it safes the right setting either.
shocker 135 Posted February 18, 2018 Author Posted February 18, 2018 Seems that @@Senna have a point here with the subtitle mode option. If I'm setting the settings for subtitles to: - Preferred subtitle language: English - Subtitle mode: No subtitle - Burn subtitles: Auto Then only the big subtitle is displayed automatically (checking the settings before going to resume the movie it says that the subtitle is set to none, but the english one is still automatically displayed). @@corey can you check the other way around, set the subtitle mode to Always play subtitles to see if you can reproduce this?
Senna 368 Posted February 18, 2018 Posted February 18, 2018 (edited) @@shocker Can you set the language for your Emby user you use on the Apple TV to English, so you can use the exact text that is used in the menus that you see on screen and edit your post accordingly, to avoid confusion which settings are used. Because where can I find the setting to set "burn subtitles: auto" Edited February 18, 2018 by Senna
shocker 135 Posted February 18, 2018 Author Posted February 18, 2018 @@shocker Can you set the language for your Emby user you use on the Apple TV to English, so you can use the exact text that is used in the menus that you see on screen and edit your post accordingly, to avoid confusion which settings are used. Sorry but I have no idea what are you talking about What language to be changed to English? And what is the confusion caused?
Senna 368 Posted February 18, 2018 Posted February 18, 2018 Because where can I find the setting to set "burn subtitles: auto"
shocker 135 Posted February 18, 2018 Author Posted February 18, 2018 Because where can I find the setting to set "burn subtitles: auto" I get your point now, but that question was not in your post, previously Check your subtitle settings via the web interface.
Senna 368 Posted February 18, 2018 Posted February 18, 2018 @@Luke, @ebr, @corey So to me it seems, that when we have double subtitles, the SRT gets burned in too. Otherwise I wouldn't see what I mentioned in this post: I tested with changing subtitles styles in Apple TV settings by changing color to yellow and changing text in srt, to rule out embedded sub display. When playback of movie is started by pre selecting srt, I see yellow subtitles with right timing AND white subtitles with wrong slightly delayed timing. When I click FW/BW I see a white text appearing "Subtitles Loading". When Apple TV settings for closed captions is turned off, I see only white subtitles from srt. After playing for some time, some subtitle dialogs are skipped. In above example I changed the text in srt, to see what the sources were from the double subtitle text displayed on screen, so I could see if it was the text from the embedded subs or from the srt. The duplicate subs showing on screen were both from the srt (because it showed my changed text), so the white ones were burned in by server and that explains the slight delay when the white ones were shown. Is that correct Luke ?
