Jacques 0 Posted January 28, 2018 Posted January 28, 2018 Hello, Sorry if this has been covered before. I am looking to add live TV for use with Emby. I don't want to spend much at the moment. I see on Emby settings it says 'other' under the tuner settings. Does this mean I could buy a cheap USB tuner and it will work? If not could anyone suggest any cheap budget tuners. I would only really use it for recording live TV. Many Thanks for the help in advance
Luke 42243 Posted January 28, 2018 Posted January 28, 2018 Hi, I would recommend an HD Homerun network tuner.
snorkel 15 Posted January 29, 2018 Posted January 29, 2018 Hi, I would recommend an HD Homerun network tuner. +1 they have a new quad tuner one now as well as the dual tuner model. Luke, what are your thoughts on the model that does the hardware encoding to h264?
