mutu310 70 Posted January 28, 2018 Posted January 28, 2018 Hi, As far as I can tell, plugins are updated only when the Emby Server is restarted. In order to avoid version fragmentation of plugins, may I suggest that when plugins are auto-downloaded, if there are no clients connected and no scheduled tasks running, Emby Server would restart thus successfully installing the latest version of the plugin?
ebr 16332 Posted January 28, 2018 Posted January 28, 2018 This should already be happening if you have the option to automatically restart for updates selected.
mutu310 70 Posted January 28, 2018 Author Posted January 28, 2018 This should already be happening if you have the option to automatically restart for updates selected. As of yesterday I have: 116 unique users with version 2.0.0.7 3 unique users with 1.2.4.26 1 user with 2.0.0.1 1 user with 2.0.0.5 Today (so far) I released 2.0.1.0 for the latest beta and I have: 110 users with version 2.0.0.7 4 users with 2.0.1.0 3 users with 1.2.4.26 2 users with 2.0.0.1 1 user with 2.0.0.5 In particular, there should be no excuse for the 2.0.0.1 and 2.0.0.5 users not to be updated. 2.0.0.1 was released in September and on 26th December version 2.0.0.4 was released, which means that this user hasn't updated the plugin in over a month, and I know that that version is no longer working, but I can't sort of force him/her to upgrade
Luke 42239 Posted January 28, 2018 Posted January 28, 2018 The min required server version could be playing a role for people who are staying on older server versions.
ebr 16332 Posted January 29, 2018 Posted January 29, 2018 Also, if you are releasing as beta only people on the beta server line will see them.
Luke 42239 Posted January 29, 2018 Posted January 29, 2018 @@mutu310 please let us know if this helps. thanks !
mutu310 70 Posted January 29, 2018 Author Posted January 29, 2018 @@Luke @@ebr Versions 2.0.0.1, 2.0.0.4, 2.0.0.5, 2.0.0.6 and 2.0.0.7 all have: - Version class set to Release - Supports .NET checked - Supports .NET Core checked - Required Server Version set to 3.2.30.2 Yet there are 2 or 3 unique users still on 2.0.0.1 and at least 1 on 2.0.0.5 Then there are 3 on 1.2.4.26 (server version >= 3.0.5911.0 and < 3.2.27.0 [otherwise they would be upgraded to 1.2.4.27])
Luke 42239 Posted January 29, 2018 Posted January 29, 2018 We'd have to look at their server version and also server log. Maybe they are having a communication failure during the upgrade process. In other words this doesn't sound normal. Thanks.
mutu310 70 Posted January 29, 2018 Author Posted January 29, 2018 (edited) We'd have to look at their server version and also server log. Maybe they are having a communication failure during the upgrade process. In other words this doesn't sound normal. Thanks.I'm picking up anonymous data so there is no means for me to identify them. By the way, please introduce a max server version. This stops users installing an old plugin version that is incompatible with their Emby Server version and also should someone disable plugin updates and Emby Server is upgraded to a new version incompatible with the plugin version, he or she should receive a notification and have the plugin disabled. For example, the new beta requires some channel changes. If someone upgrades to the new beta without upgrading the plugins no channel plugin will work. Edited January 29, 2018 by mutu310
