richwphillips@yahoo.com 3 Posted January 27, 2018 Author Posted January 27, 2018 Not sure what happened to my original post there. Oops. Anyway. I can't get the dashboard or the library to load on my Windows laptop. It was working fine this morning. Then the links that are usually on the left side of the dashboard (settings, etc) disappeared while the rest of the dashboard was still visible. Now when I try to access the dashboard or the library, all I get is a blank screen.
jordy 284 Posted January 27, 2018 Posted January 27, 2018 tried deleting your browser cache? that's assuming you're using the web browser... 1
richwphillips@yahoo.com 3 Posted January 27, 2018 Author Posted January 27, 2018 No I didn't. Let me try that. Thanks.
Luke 42204 Posted January 27, 2018 Posted January 27, 2018 Are you sure you've started up your Emby Server?
richwphillips@yahoo.com 3 Posted January 28, 2018 Author Posted January 28, 2018 I'm apparently so technically challenged that I keep typing a reply out and then posting nothing! Clearing the cache did the trick so thanks a lot, Jordy. And thanks to you too, Luke. I know you're really busy, but you always take the time to respond quickly when newbies like me have issues. And you don't make people like me who are are less tech savvy than yourself feel stupid. It's a refreshing change from many other tech sites and I'm sure I'm far from the only newbie who is very grateful for that. 1
Happy2Play 9802 Posted January 28, 2018 Posted January 28, 2018 I'm apparently so technically challenged that I keep typing a reply out and then posting nothing! Clearing the cache did the trick so thanks a lot, Jordy. And thanks to you too, Luke. I know you're really busy, but you always take the time to respond quickly when newbies like me have issues. And you don't make people like me who are are less tech savvy than yourself feel stupid. It's a refreshing change from many other tech sites and I'm sure I'm far from the only newbie who is very grateful for that. Do you have any browser add-ons? I have seen this blank post before. https://emby.media/community/index.php?/topic/51919-testing-posting-capabilities/?p=501623
richwphillips@yahoo.com 3 Posted January 28, 2018 Author Posted January 28, 2018 Yes I do. I use Chrome with a number of extensions, including adblock. Thanks for the info, Happy2Play.
