rickyd25 0 Posted January 29, 2018 Author Posted January 29, 2018 re did the error im having and ive sent another log so hopefully it shows the issue
ebr 16337 Posted January 29, 2018 Posted January 29, 2018 Okay, a couple questions: 1) You are on a remote connection to a commercial provider over https, correct? 2) You are on a Sony TV? 3) Have you modified the TV in any way or put it into developer mode? In your log, I see a slew of the following messages: 01-29 22:14:31.415 7398 7398 E libc : Access denied finding property "persist.mtk.mlog2logcat" 01-29 22:14:31.416 7398 7398 E libc : Access denied finding property "persist.mtk.mlog2logcat" 01-29 22:14:31.416 7398 7398 E libc : Access denied finding property "persist.mtk.mlog2logcat" I Googled that message and came up with one thread on the Sony forums that may or may not be related to the issue you are having but it seems it is some situation where a component on the TV goes a bit haywire.
rickyd25 0 Posted January 30, 2018 Author Posted January 30, 2018 Yes that's right and yes a do my tv as far as I'm aware it hasn't been touched in the settings I've factory reset my tv this morning before work so I'll send another log when I get home
rickyd25 0 Posted January 30, 2018 Author Posted January 30, 2018 ive tried it and it seems to have worked although it still freezes when i try to send a log, i managed to get through a entire episode without any problems so hopefully this problem doesn't come back
