Seven_ 0 Posted January 26, 2018 Posted January 26, 2018 Hi, i was trying to find a manual on how to use the app on my samsung TV 2013 F series is see no option on displaying playing status, i pressed info button but nothing happen i am a plex user and i want to migrate to emby, also there is any way to get a 1-2 days emby premiere so i can see how emby will work on my machine with all functions, thank you
Seven_ 0 Posted January 26, 2018 Author Posted January 26, 2018 yes i do, is the app from samsung store
Luke 42241 Posted January 26, 2018 Posted January 26, 2018 Ok, can you describe what you mean here a little more? is see no option on displaying playing status, i pressed info button but nothing happen You're saying you press the info button during playback? In Emby what you can do is press the settings cog inside the video player, then select stats for nerds.
Luke 42241 Posted January 26, 2018 Posted January 26, 2018 But using the info button as a shortcut for that would be a good idea too, thanks. 1
Seven_ 0 Posted January 26, 2018 Author Posted January 26, 2018 i will post more info tomorrow about the behaviour on Samsung TV 2013 F
CBers 7554 Posted January 26, 2018 Posted January 26, 2018 But using the info button as a shortcut for that would be a good idea too, thanks. IIRC, CMCG's Samsung app utilised the INFO button. Perhaps @@FrostByte can confirm. 1
FrostByte 5453 Posted January 26, 2018 Posted January 26, 2018 Yes, the old app would bring up things stats like Direct Play, etc using the Info button. If the new app could utilize the same button for Stats for Nerds that would be great especially if it could toggle it off and on. Right now it takes about three steps to show SFN and then again to turn it off. 1
Seven_ 0 Posted January 27, 2018 Author Posted January 27, 2018 (edited) more information about the information of the app on samsung 2013 TV from samsung app store This is the remote this how is look like on horizontal mode, why the half missing cover art and half displayed episode numbers ? and on vertical mode, why the posters so small ? since there was no way to be able to display the information while playing i press the guide button from the remote and show this and after that i press Return but for some reason you no button from there is working, you can navigate move to the left-right but that is all i think while playing that information will be handy because you can add the sub i think and other settings if you can access the cog, i hope that will help for further improvements Edited January 27, 2018 by Seven_
Luke 42241 Posted January 27, 2018 Posted January 27, 2018 Yea we are aware of some display problems on 2013 models due to those devices having older rendering engines. For what it's worth in the Samsung app store it is only available for 2014+. You may want to check out this community app from a community developer: https://emby.media/community/index.php?/topic/9869-samsung-smart-tv-2011-2014-third-party-app-install-instructions/ Thanks.
Seven_ 0 Posted February 6, 2018 Author Posted February 6, 2018 also i want to add, that mark as watched, add to favourites selecting a subtitle is not working, why release without testing i will never understand
Luke 42241 Posted February 6, 2018 Posted February 6, 2018 Sorry but these functions all work fine in my testing. How to report a problem: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
