emartinez 1 Posted January 26, 2018 Posted January 26, 2018 Hello, We are having problems to upgrade to version 3.2.60 or 70, our m3u tunners stop working, just when we update the server it seems to be working but a few minutes later it start giving errors trying to open new channels, from the android app we can see that it sais that there is no tunner available, from the web access it just trying to load the channel but it never connects. Al the channels are working in the m3u and if we dongrade the server again to 3.2.36 it works right. Attached is the server logs from the moment that we have upgrade to the downgrade.logs.zip
Luke 42205 Posted January 26, 2018 Posted January 26, 2018 hi there @@emartinez, this is a whole folder full of log files. can you please tell me which log files are from the time that you experienced the problem? thanks !
andrewbee 15 Posted January 27, 2018 Posted January 27, 2018 Experiencing this same issue as well. Tried manually upgrading but installer keeps getting blocked. Switched off my firewall, antivirus and Windows defender but still couldnt install.
Luke 42205 Posted January 27, 2018 Posted January 27, 2018 Experiencing this same issue as well. Tried manually upgrading but installer keeps getting blocked. Switched off my firewall, antivirus and Windows defender but still couldnt install. @@andrewbee can you tell us exactly what happens? is there an error message? thanks.
Happy2Play 9802 Posted January 27, 2018 Posted January 27, 2018 Experiencing this same issue as well. Tried manually upgrading but installer keeps getting blocked. Switched off my firewall, antivirus and Windows defender but still couldnt install. Sounds like the ClickOnce issue. https://emby.media/community/index.php?/topic/55143-question-about-installing-on-windows-10/?hl=%26quot%3Bclickonce%26quot%3B&do=findComment&comment=535635 1
andrewbee 15 Posted January 27, 2018 Posted January 27, 2018 Sounds like the ClickOnce issue. https://emby.media/community/index.php?/topic/55143-question-about-installing-on-windows-10/?hl=%26quot%3Bclickonce%26quot%3B&do=findComment&comment=535635 That solved my issue. Thank you
emartinez 1 Posted January 29, 2018 Author Posted January 29, 2018 Hi Luke, I have rename the logs with the important ones, 1 - Server working before upgrade in 3.2.36 version all working right 2 - UPgrade to 3.2.70 - All seems to be working right, we open some m3u channels and films, all seems to be workin, after a few minutes we try to open channels unssusesfully, in the web just stay in black screen with the circle of load, in the emby for android TV shows there is no tunner available. 3 - We try to load a previous backup, it seems to work at the beggining but soon the errors start. 4 - We try to remove all m3u tunners and create them again, the problem apear again. 5 - We downgrade the server to 3.2.36 all working again. logs-renamed.zip
Luke 42205 Posted January 29, 2018 Posted January 29, 2018 hi @@emartinez, that is an entire folder of log files. can you identify which ones are from the timeframe in which the problem occurred? thanks !
emartinez 1 Posted January 30, 2018 Author Posted January 30, 2018 Hi @@Luke, it is done and explained before logs numbered from 1 to 5, can you check it?
Luke 42205 Posted February 21, 2018 Posted February 21, 2018 @@emartinez, please try again with the next release of emby server, thanks !
