Z0m8ie 26 Posted January 26, 2018 Posted January 26, 2018 Hi Guys, When playing movies with DTS Audio, the web browser down mixes it to something else(not sure what). However when I play the same files in the Emby for WMC the little icon comes up on my receiver to say its DTS. The codec pack I'm using is Shark007 if that's of any help. Not sure if this is a codec or Emby problem?.
Solution Luke 42204 Posted January 26, 2018 Solution Posted January 26, 2018 What is the problem that you're trying to report? There is currently no web browser that supports DTS audio. 2
Happy2Play 9802 Posted January 26, 2018 Posted January 26, 2018 http://html5test.com/ shows your browser limitations/support. 1
Z0m8ie 26 Posted January 26, 2018 Author Posted January 26, 2018 What is the problem that you're trying to report? There is currently no web browser that supports DTS audio Hi, I was sure I saw the DTS icon on my receiver a while ago when I was watching a movie via the internet web client?, maybe I'm mistaken. Thanks for letting me know.
Luke 42204 Posted January 26, 2018 Posted January 26, 2018 No, it's not possible in the web browser. Thanks.
