jaredallard 0 Posted January 26, 2018 Posted January 26, 2018 Emby Version: 3.2.70.0 OS: Linux directstream log: https://gist.github.com/jaredallard/411a15e318775f5941e37ef9e7ad75dc Steps: 1. Opened up media 2. Selected 'eng' audio track 3. Continued using the 'jpn' audio track despite showing it as using the 'eng' track. This happens regardless of player (android/chrome) As always, let me know if you need anything else (left server log out as I don't feel it contribs anything here)
Luke 42204 Posted January 26, 2018 Posted January 26, 2018 hi, are you sure you had the eng track selected? this seems to indicate you had jpn selected.
jaredallard 0 Posted January 26, 2018 Author Posted January 26, 2018 (edited) hi, are you sure you had the eng track selected? this seems to indicate you had jpn selected. Yep! 100% sure. Screen recording: no audio because I forgot to enable it, but it was JPN the entire time. ffprobe as well just to clarify at the end. Edited January 26, 2018 by jaredallard
Luke 42204 Posted January 26, 2018 Posted January 26, 2018 I'm not able to reproduce this so i wonder if the issue is specific to your media. can you provide a sample video for testing? thanks.
jaredallard 0 Posted January 27, 2018 Author Posted January 27, 2018 I'm not able to reproduce this so i wonder if the issue is specific to your media. can you provide a sample video for testing? thanks. PM'd a link.
Luke 42204 Posted January 28, 2018 Posted January 28, 2018 the problem here is that the default track is not the first audio track. chrome has no api to change tracks, so when we direct play, we are relying on it to choose the track marked as default. To resolve this we will have to trigger a transcode when the default track is not the first track.
jaredallard 0 Posted January 28, 2018 Author Posted January 28, 2018 the problem here is that the default track is not the first audio track. chrome has no api to change tracks, so when we direct play, we are relying on it to choose the track marked as default. To resolve this we will have to trigger a transcode when the default track is not the first track. Interesting, by transcode is that a literal transcode or is it able to just-in-time 'stream' it, like I've noticed it's able to do with most audio track switching.
Luke 42204 Posted January 28, 2018 Posted January 28, 2018 it would probably just be a container swap.
