mchadima 0 Posted February 7, 2018 Author Posted February 7, 2018 Thank you for your responses. Now we're getting somewhere. The player has no problem playing the direct stream from the HDHomerun device, which does not perform hardware transcoding, using the HDHomerun app on the Adroid TV box. Never a stutter. Indicates that there are no network issues, but there shouldn't be as it is gigabit ethernet. My question is why does Emby Server stream form the QNAP with ease, but demands full processor usage during playing recorded TV? Sorry again about my relative ignorance about video.
mastrmind11 722 Posted February 7, 2018 Posted February 7, 2018 Well what are your dvr settings? Also attach the transcode log from a time when this happened, it will state exactly why it's transcoding (as will the stats for nerds on the client as well as the dashboard when a transcode is happening).
mchadima 0 Posted February 7, 2018 Author Posted February 7, 2018 ffmpeg log 2-4 V3 is attached in post #17. It is the log of playback from DVR. I am not local to the server to post DVR settings but will do that when I am in a few hours.
mchadima 0 Posted February 7, 2018 Author Posted February 7, 2018 DVR settings: no paths have been designated for the three kinds of recordings. Automatically convert recordings to a streaming friendly format is unchecked. So is Preserve original audio when converting recordings (when possible).No Post Processing application (or path) and no Default Recording settings (time before and after.) Tested a recording after checking the Automatically convert recordings to a streaming friendly format box, but no better. Playback of recorded TV was still running the CPU at 99% and playback constantly froze.
mastrmind11 722 Posted February 7, 2018 Posted February 7, 2018 This seems bizarre. It appears ffmpeg is doing a video copy which should cost nothing, but eventually your server can't keep up w/ the copy. I've not seen this with direct play ts files, and converting to a stream friendly mkv will not fix it. I don't see a transcode going on anywhere, so not sure what @@ebr was referring to. Just for testing, try to play a recorded tv episode and check either stats for nerds or the dashboard and report back wtf it's actually doing.
mchadima 0 Posted February 8, 2018 Author Posted February 8, 2018 Played back 60 Minutes and have attached the Stats for Nerds data. Stats on the QNAP show CPU at 99%.
Luke 42245 Posted February 8, 2018 Posted February 8, 2018 Played back 60 Minutes and have attached the Stats for Nerds data. Stats on the QNAP show CPU at 99%. In this case your transcoding is just not able to go fast enough, so that would explain the freezing during playback.
Sammy 791 Posted February 8, 2018 Posted February 8, 2018 But why's it transcoding in the first place? Sent from my SM-G930P using Tapatalk
Luke 42245 Posted February 8, 2018 Posted February 8, 2018 Because the video codec is mpeg2 and he's on an X96mini. 2
Sammy 791 Posted February 8, 2018 Posted February 8, 2018 Because the video codec is mpeg2 and he's on an X96mini.Got it. Need MORE POWER! Sent from my SM-G930P using Tapatalk
mchadima 0 Posted February 8, 2018 Author Posted February 8, 2018 OK, I think I finally understand. If my QNAP had a faster processor, or my Android TV box could handle transcoding, then no problem? Like @@Sammy said MORE POWER! My final question (perhaps): why is Emby able to transcode a direct stream so efficiently (15% CPU) and not a playback of a recorded stream?
Sammy 791 Posted February 8, 2018 Posted February 8, 2018 OK, I think I finally understand. If my QNAP had a faster processor, or my Android TV box could handle transcoding, then no problem? Like @@Sammy said MORE POWER! My final question (perhaps): why is Emby able to transcode a direct stream so efficiently (15% CPU) and not a playback of a recorded stream?I just hooked up my new to me 2015 ShieldTV and tested Emby LiveTV (not RecordedTV) with ServerWMC / HDHR Prime using Emby Server on my i5 4690k Devil's Canyon. No issues at all and I also noticed the guide loads even faster than on Emby Theater too. Sent from my SM-G930P using Tapatalk
Sammy 791 Posted February 8, 2018 Posted February 8, 2018 What container is your RecordedTV in? Maybe Emby has to repackage it on the fly? Sent from my SM-G930P using Tapatalk
mchadima 0 Posted February 8, 2018 Author Posted February 8, 2018 It is in the default location for Emby TV recording. QNAP has the ability to set up automated transcoding. Supposedly, just tell it which folders to transcode. Since there is a delay between when a program is recorded and when it is watched, why not try that workaround? First test, QNAP didn't automatically transcode, but haven't had time to double check the settings. So told it to manually transcode the saved file. Failed: read/write error. Haven't investigated, but will report back. Still curious about why playback needs full CPU, but streaming from Emby doesn't. Possibly a simple answer, just displaying my lack of video experience.
Luke 42245 Posted February 8, 2018 Posted February 8, 2018 OK, I think I finally understand. If my QNAP had a faster processor, or my Android TV box could handle transcoding, then no problem? Like @@Sammy said MORE POWER! My final question (perhaps): why is Emby able to transcode a direct stream so efficiently (15% CPU) and not a playback of a recorded stream? Can we look at some specific examples? thanks !
mchadima 0 Posted February 8, 2018 Author Posted February 8, 2018 I posted ffmpeg logs for both stream and recorded TV playback in post #17.
Luke 42245 Posted February 8, 2018 Posted February 8, 2018 by the way since you're on a 64-bit machine i would suggest switching to our new qnap package: https://emby.media/community/index.php?/topic/24369-qnap-setup/ it has support for vaapi hardware acceleration built in, which you can play with enabling to see if transcoding performs any better with it.
mchadima 0 Posted February 11, 2018 Author Posted February 11, 2018 Upgraded to 3.2.70.0. Changed transcoding to VA API. Recorded another episode of CBS Sunday Morning. Playback not improved, and ffmpeg log attached. CPU again at 99%. Any sense why TV streaming is flawless, also mpeg2, at 15% CPU, yet playback stresses resources? Trying to get something to work with recorded TV, here's an update on automated background transcoding supposedly a part of QNAP software (not). Plenty of complaints from users about the read/write fail when transcoding starts. A post suggested to downgrade CodexPack to 4.2.7, which works to fix the transcoding error. Transcoding a 6 GB file took 30 minutes and playback displayed no freezing. Only problem was the audio and video was not in sync. Only tried one file so far, so need to investigate further. Stats of the transcoded file is attached in case you are curious. ffmpeg log 2-11.txt
Luke 42245 Posted February 12, 2018 Posted February 12, 2018 I would suggest installing our new package that I looked to above. What you're currently using is a community package and is a little more difficult for us to answer questions on. Thanks.
mchadima 0 Posted February 13, 2018 Author Posted February 13, 2018 Installed update (sorry about the "community" install previously). No joy anywhere. Live TV is no longer working. Tried three channels, each would show channel data as if it was ready to display, then spinning wheel and black screen, to be followed by repeat of same, finally each attempt would end with "Too many errors. Giving up." Tried playback of recorded TV. Same result. ffmpeg logs are attached. Server log attached. Send Android TV log from device as well. Tried Live TV using Chrome on Win 10, logged into the server through the Emby QNAP Server program. Video freezes, but spotty audio playback. ffmpeg log send called "ffmpeg QNAP thru browser". Of note: 12 hours ago, Live TV played flawlessly (after installing this update) on another TV on a different Android TV device. Hmmm. Also, HD Homerun app plays Live TV flawlessly on this device, as usual, at this time. Emby Server log 2-13.txt ffmpeg log 2-13 DVR playback.txt ffmpeg log 2-13.txt ffmpeg QNAP thru browser.txt
ebr 16337 Posted February 13, 2018 Posted February 13, 2018 It still looks like the server is simply not fast enough to handle the load when transcoding is needed. You could try turning off vaapi.
mchadima 0 Posted February 16, 2018 Author Posted February 16, 2018 Turning of VA API doen't help. Can I ask a simple question? Why does Emby play Live TV flawlessly, same network, same NAS, same Android TV boxes, and use 15% CPU. But then playback of recorded TV fails due to CPU running at 99%? 1
ebr 16337 Posted February 16, 2018 Posted February 16, 2018 Why does Emby play Live TV flawlessly, same network, same NAS, same Android TV boxes, and use 15% CPU. But then playback of recorded TV fails due to CPU running at 99%? Due to the container the recording ends up in (.ts) being not seek-able in the Android player.
solidus28 12 Posted February 18, 2018 Posted February 18, 2018 Due to the container the recording ends up in (.ts) being not seek-able in the Android player.Does an HDHomeRun Extend help this situation by handling the transcoding or does it still end up in a non seekable .ts container, just with h264 inside? Sent from my LGLS992 using Tapatalk
ebr 16337 Posted February 18, 2018 Posted February 18, 2018 Does an HDHomeRun Extend help this situation by handling the transcoding or does it still end up in a non seekable .ts container, just with h264 inside? Sent from my LGLS992 using Tapatalk It still ends up in the same container.
