AllanMarcus 3 Posted January 25, 2018 Posted January 25, 2018 (edited) Hello. I've installed Emby and imported my tv, movie, and music libraries. I use Kodi and Plex, and both sync to Trakt.tv. I've verified that shows and movies in Trakt.tv are marked as watched. When I sync with the Emby Trakt plugin, it connects, but doesn't make anything as watched. Note: trakt debugging was on for the run with the log file below. Log file attached. Any ideas? Thanks. emby_log.txt Edited January 25, 2018 by AllanMarcus
Luke 42255 Posted January 25, 2018 Posted January 25, 2018 Hi, so you're saying that content in Emby is not marked watched?
AllanMarcus 3 Posted January 25, 2018 Author Posted January 25, 2018 Hi, so you're saying that content in Emby is not marked watched? Correct.
Luke 42255 Posted January 25, 2018 Posted January 25, 2018 @@AllanMarcus Hi, are your tv and movie libraries tagged with imdb id's or tvdb/tmdb id's? That's what we need in order to match data up with trakt. Check one of the movies that didn't update. Thanks.
AllanMarcus 3 Posted January 26, 2018 Author Posted January 26, 2018 @@AllanMarcus Hi, are your tv and movie libraries tagged with imdb id's or tvdb/tmdb id's? That's what we need in order to match data up with trakt. Check one of the movies that didn't update. Thanks. Yes, they are.
Luke 42255 Posted January 26, 2018 Posted January 26, 2018 can you give an example of something whose watch status didn't update, and tell us what you expected to happen? thanks !
AllanMarcus 3 Posted January 26, 2018 Author Posted January 26, 2018 (edited) can you give an example of something whose watch status didn't update, and tell us what you expected to happen? thanks ! I would be happy to. When a movie or episode is marked watched on Trakt, after the sync that movie or episode should be marked watched in Emby. This is how it works for the Kodi and Plex plug in. For example, I use Plex and watch a show. The plex trakt plug in marks the show watched on trakt. Then when the Emby trakt plugin syncs, that episode should be marked watched in Emby. In my current situation, I just started with Emby. I assumed I could just sync (pull) from Track.tv and it would mark watched all the stuff that is watched in Track.tv. Edited January 26, 2018 by AllanMarcus
Angelblue05 4132 Posted January 26, 2018 Posted January 26, 2018 Can you confirm your content is correctly identified in Emby? That they have the proper imdb/tvdb/tmdb id assigned? I'll test on my side and let you know if I'm able to reproduce this. Luke doesn't have trakt so it's harder for him to confirm there is an issue. I don't mind helping out.
paulsalter 84 Posted January 26, 2018 Posted January 26, 2018 I use Trakt quite a bit and just tested Marked something watched on the website, when running the Import Playstates from Trakt, this item is marked as watched in Emby One thing i notice in the above screenshot, I have the update watched history on trakt ticked Cant remember what the default is for this, so the description 'By default', could vary depending on the default state of this tick box
Angelblue05 4132 Posted January 26, 2018 Posted January 26, 2018 (edited) It's working for me. For some reason, I had issues with the plugin not being authorized to access my trakt account. So I set up another pin and now it works. @@AllanMarcus When you run the task, do you see errors in your server log? How long is the sync? Edited January 26, 2018 by Angelblue05
AllanMarcus 3 Posted January 26, 2018 Author Posted January 26, 2018 Can you confirm your content is correctly identified in Emby? That they have the proper imdb/tvdb/tmdb id assigned? I'll test on my side and let you know if I'm able to reproduce this. Luke doesn't have trakt so it's harder for him to confirm there is an issue. I don't mind helping out. I spot checked a few, and they look like they are identified correctly. I use Trakt quite a bit and just tested Marked something watched on the website, when running the Import Playstates from Trakt, this item is marked as watched in Emby One thing i notice in the above screenshot, I have the update watched history on trakt ticked Cant remember what the default is for this, so the description 'By default', could vary depending on the default state of this tick box I was under the impression Playstates was a percent complete thing.Regardless, I tried that and no luck. Shows and Movies are all still marked unwatched. Update Watched history looks like it set trakt to the state from Emby. I do't want that. That would set everything as unwatched in trakt, I think. It's working for me. For some reason, I had issues with the plugin not being authorized to access my trakt account. So I set up another pin and now it works. @@AllanMarcus When you run the task, do you see errors in your server log? How long is the sync? If I put an incorrect code in, it fails. If I put a correct code in, it takes less than 30 seconds. See attached log above. It would be REALLY helpful if the description of the option said : When on, this does this, when Off, it does that. Using the term "default" is pretty useless Thanks for all the help. I'm hopeful this will be figured out.
AllanMarcus 3 Posted January 26, 2018 Author Posted January 26, 2018 (edited) Heres is the import playstates task log with both debugging turned on: 2018-01-26 06:52:59.530 Info TaskManager: Executing Import playstates from Trakt.tv2018-01-26 06:52:59.530 Info HttpServer: HTTP Response 204 to fe80::feaa:14ff:fe9b:5e14%2. Time: 5ms. http://linuxserver.local:8096/emby/ScheduledTasks/Running/5e47e7d3542ace9c367691a65cb31e862018-01-26 06:52:59.531 Info HttpClient: GET: https://api.trakt.tv/sync/watched/movies2018-01-26 06:52:59.533 Info HttpServer: HTTP GET http://linuxserver.local:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_11_6) AppleWebKit/604.3.5 (KHTML, like Gecko) Version/11.0.1 Safari/604.3.52018-01-26 06:52:59.534 Info HttpServer: HTTP Response 200 to fe80::feaa:14ff:fe9b:5e14%2. Time: 1ms. http://linuxserver.local:8096/emby/ScheduledTasks?isHidden=false2018-01-26 06:52:59.938 Info HttpClient: GET: https://api.trakt.tv/sync/watched/shows2018-01-26 06:53:00.726 Info Trakt: Trakt.tv watched Movies count = 3662018-01-26 06:53:00.726 Info Trakt: Trakt.tv watched Shows count = 2782018-01-26 06:53:03.149 Info TaskManager: Import playstates from Trakt.tv Completed after 0 minute(s) and 3 seconds2018-01-26 06:53:03.150 Info ServerManager: Sending web socket message ScheduledTaskEnded2018-01-26 06:53:03.150 Info TaskManager: ExecuteQueuedTasks Nothing. Maybe that is the issue. Import Playstates doesn't appear to be working. Edited January 26, 2018 by AllanMarcus
Luke 42255 Posted January 26, 2018 Posted January 26, 2018 @@Angelblue05 you're able to import playstates from trakt, right? 1
AllanMarcus 3 Posted January 26, 2018 Author Posted January 26, 2018 (edited) @@Angelblue05 you're able to import playstates from trakt, right? Opps, misread. Edited January 26, 2018 by AllanMarcus
Angelblue05 4132 Posted January 28, 2018 Posted January 28, 2018 (edited) @@Luke Yes. From trakt. Unwatched in Emby, Watched in Trakt. Import from Trakt = Watched in Emby. Edited January 28, 2018 by Angelblue05
Angelblue05 4132 Posted January 28, 2018 Posted January 28, 2018 (edited) @@AllanMarcus I know it sounds a bit crazy but with your log, it can clearly see trakt watched status. Are you certain the trakt task isn't working? Maybe you are logged on the wrong user vs where Trakt is syncing the watched status to? I know the user name dropdown is buggy in the plugin settings. It always resets to the first user in the list after hitting save (even if it shows the correct user info elsewhere). Can you make sure the credentials of Trakt are assigned to the right user? Edited January 28, 2018 by Angelblue05
AllanMarcus 3 Posted January 28, 2018 Author Posted January 28, 2018 I only have one user profile, and it's the same user, but.... Good lord, it's working now. I don't get it. I really don't understand why it's working now. When I say "it's working now", I mean nothing has changed, but all my watched shows are marked as watched now. They were no before. I can only surmise that some action was talking place in the background. Some action that doesn't get logged, and it just took time to complete. Well, mark this one closed and solved by sun spots. 1
Angelblue05 4132 Posted January 28, 2018 Posted January 28, 2018 Maybe a caching issue? Anyway, glad it's working for you now
MatsF 0 Posted January 13, 2019 Posted January 13, 2019 I have the exact same problem. I have just installed Emby Server and one of the first things I wanted to do is to sync the watch state from Trakt.tv to Emby, because everything is unwatched in Emby right now. I have checked and all the tvdb/imdb ids are in the movies and in the shows (don´t know how to check the episodes but they are there with the right Season/episode information. I have tried using different browsers, Edge and Chrome. I have tried to restart the server. I change and save the settings at the right user with Trakt settings in Emby.The Authentication PIN is not there the second time I go in to Trakt settings in Emby, but that may be by design.. Here is the log: 2019-01-13 01:26:01.208 Info TaskManager: Executing Import playstates from Trakt.tv2019-01-13 01:26:01.208 Info HttpServer: HTTP Response 204 to 10.9.8.246. Time: 2ms. http://10.9.8.74:8096/emby/ScheduledTasks/Running/5e47e7d3542ace9c367691a65cb31e862019-01-13 01:26:01.211 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies2019-01-13 01:26:01.218 Info HttpServer: HTTP GET http://10.9.8.74:8096/emby/ScheduledTasks?isHidden=false. UserAgent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/71.0.3578.98 Safari/537.36 2019-01-13 01:26:01.221 Info HttpServer: HTTP Response 200 to 10.9.8.246. Time: 3ms. http://10.9.8.74:8096/emby/ScheduledTasks?isHidden=false2019-01-13 01:26:01.471 Info HttpClient: GET https://api.trakt.tv/sync/watched/shows2019-01-13 01:26:02.272 Info Trakt: Trakt.tv watched Movies count = 662019-01-13 01:26:02.272 Info Trakt: Trakt.tv watched Shows count = 2712019-01-13 01:26:02.630 Info HttpClient: GET https://api.trakt.tv/sync/watched/movies2019-01-13 01:26:02.931 Info HttpClient: GET https://api.trakt.tv/sync/watched/shows2019-01-13 01:26:04.846 Info Trakt: Trakt.tv watched Movies count = 662019-01-13 01:26:04.846 Info Trakt: Trakt.tv watched Shows count = 2712019-01-13 01:26:05.168 Info TaskManager: Import playstates from Trakt.tv Completed after 0 minute(s) and 3 seconds2019-01-13 01:26:05.170 Info TaskManager: ExecuteQueuedTasks I am out of ideas!
Luke 42255 Posted January 13, 2019 Posted January 13, 2019 Hi there, please attach the complete emby server log. thanks.
MatsF 0 Posted January 13, 2019 Posted January 13, 2019 Hi Luke, Thank you. Here it is (hopefully) embyserver-63682940203.txt
Luke 42255 Posted January 13, 2019 Posted January 13, 2019 Can you discuss an example that we should be looking at? thanks.
MatsF 0 Posted January 13, 2019 Posted January 13, 2019 (edited) https://trakt.tv/movies/deadpool-2-2018 I saw this a while ago and it is marked as watched in Trakt and has the following information in Emby: IMDb Id: tt5463162 TheMovieDb Id:383498 TheMovieDb Collection Id:448150 Did you see anything in the log? Edited January 13, 2019 by MatsF
Luke 42255 Posted January 14, 2019 Posted January 14, 2019 Only references to live tv channels called deadpool. Did you setup a movie library?
