Mattpan77@gmail.com 0 Posted January 25, 2018 Posted January 25, 2018 i have a sagemcom5260 router provided by Spectrum. I'm having trouble forwarding port properly for remote access. I have already created a static ip address.
Guest asrequested Posted January 25, 2018 Posted January 25, 2018 Try this http://openmyip.com/Sagemcom-Fast-5260-router-setup
Mattpan77@gmail.com 0 Posted January 25, 2018 Author Posted January 25, 2018 I seemed to have followed that step by step and somehow I can only access my server in Network.
Guest asrequested Posted January 25, 2018 Posted January 25, 2018 Try working through this guide, and see where you hit a problem https://github.com/MediaBrowser/Wiki/wiki/Connectivity
Luke 42204 Posted January 25, 2018 Posted January 25, 2018 @@Mattpan77@gmail.com, please let us know if this helps. Thanks ! 1
Mattpan77@gmail.com 0 Posted January 25, 2018 Author Posted January 25, 2018 still nothing. Ive had my server working perfectly with my old router in the past. but for some reason this one is just not working
Happy2Play 9802 Posted January 25, 2018 Posted January 25, 2018 Do you have more then one router on your network?
Luke 42204 Posted January 26, 2018 Posted January 26, 2018 Can you tell us where you hit a problem in the connectivity guide? Thanks.
Mattpan77@gmail.com 0 Posted January 26, 2018 Author Posted January 26, 2018 these are my settings for router and i only have one router
Mattpan77@gmail.com 0 Posted January 26, 2018 Author Posted January 26, 2018 I added a screenshot but I dont see it there anywhere ?
Happy2Play 9802 Posted January 26, 2018 Posted January 26, 2018 (edited) If my google search was correct, that router has a Firewall. Did you add your port forwarding rule to the firewall setting? Edited January 26, 2018 by Happy2Play
harrv 90 Posted January 26, 2018 Posted January 26, 2018 Seems that the o.p. may not be back, but just in case, when the symptom is that you can't connect externally, in addition to firewall and router settings, it's now worth checking to make sure that the "Allow remote connections to this Emby Server" preference is enabled. (The green check box in this screenshot.)
Luke 42204 Posted January 26, 2018 Posted January 26, 2018 @@Mattpan77@gmail.com, please let us know if this helps. if the issue persists, please tell us where you hit a problem in the connectivity guide. Thanks.
Mattpan77@gmail.com 0 Posted January 29, 2018 Author Posted January 29, 2018 I have added a port forwarding rule on the router and the box is checked for allow remote connections. I'm thinking that i forwarded the port improperly though? Ive tried it a few different ways and none seem to help.
Guest asrequested Posted January 29, 2018 Posted January 29, 2018 Do you have a software firewall? An internet protection app?
Mattpan77@gmail.com 0 Posted January 29, 2018 Author Posted January 29, 2018 No I do not, And I've had emby server running previously before i got this router. My other router that i had it working on was broken,
Guest asrequested Posted January 30, 2018 Posted January 30, 2018 You may need to call tech support. Maybe there's an issue with firmware.
Abobader 3485 Posted January 30, 2018 Posted January 30, 2018 Good day, Some ISP or router need this to be open: If you only using http, then only port 80 and 8096 need to be enabled. Otherwise, I suggest what Doofus said. My best
arche 177 Posted January 30, 2018 Posted January 30, 2018 Just a question, does this router support NAT Loopback? I know I have had this problem with Xfinity's routers for testing. Just a thought.
