e123enitan 276 Posted January 24, 2018 Author Posted January 24, 2018 Why the server is tripping sort of errors continually 2018-01-22 00:00:40.705 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.102\Public_4\2TV Shows *** Error Report *** Version: 3.2.70.0 Command line: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: C:\Users\LinksysServer\AppData\Roaming\Emby-Server Application directory: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception (0x80004005): The specified network name is no longer available System.ComponentModel.Win32Exception No Stack Trace Available 2018-01-22 00:00:40.705 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.102\Public2\2Movies *** Error Report *** Version: 3.2.70.0 Command line: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: C:\Users\LinksysServer\AppData\Roaming\Emby-Server Application directory: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception (0x80004005): The specified network name is no longer available System.ComponentModel.Win32Exception No Stack Trace Available
Luke 42204 Posted January 24, 2018 Posted January 24, 2018 it appears your network is unavailable. The specified network name is no longer available
e123enitan 276 Posted January 24, 2018 Author Posted January 24, 2018 (edited) Why the server is tripping sort of errors continually 2018-01-22 00:00:40.705 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.102\Public_4\2TV Shows *** Error Report *** Version: 3.2.70.0 Command line: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: C:\Users\LinksysServer\AppData\Roaming\Emby-Server Application directory: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception (0x80004005): The specified network name is no longer available System.ComponentModel.Win32Exception No Stack Trace Available 2018-01-22 00:00:40.705 Error LibraryMonitor: Error in Directory watcher for: \\192.168.1.102\Public2\2Movies *** Error Report *** Version: 3.2.70.0 Command line: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1 64-Bit OS: True 64-Bit Process: True User Interactive: True Processor count: 16 Program data path: C:\Users\LinksysServer\AppData\Roaming\Emby-Server Application directory: C:\Users\LinksysServer\AppData\Roaming\Emby-Server\system System.ComponentModel.Win32Exception (0x80004005): The specified network name is no longer available System.ComponentModel.Win32Exception No Stack Trace Available it appear this indicate my NAS drive is offline, but why this happening for every movies after File name: '\\192.168.1.102\Public\Movies\ File name: '\\192.168.1.102\Public\Movies\Batman Forever (1995)\Batman Forever (1995)-logo.png' File name: '\\192.168.1.102\Public\Movies\Chinese Zodiac (2012)\Chinese Zodiac (2012)-HEVC-logo.png' File name: '\\192.168.1.102\Public\Movies\San Andreas (2015)\San Andreas (2015)-logo.png' These are old files that been re scanned with logo.png I would like to know if its the settings coz no settings that I am aware off has changed. Edited January 24, 2018 by e123enitan
e123enitan 276 Posted January 25, 2018 Author Posted January 25, 2018 (edited) I find this strange that no one else is reporting or seeing this issue, I just did a library scan no files added jus t see the server log activities surpriseingly see for your self Server log which turns cause E4K to sync this much files, NOTE all the movies and TV shows where added several years back what may be the reason for this eratic behaviour in the server Edited January 25, 2018 by e123enitan
Luke 42204 Posted January 25, 2018 Posted January 25, 2018 Have you tried the new EmbyCon addon? It doesn't require any syncing. You just install the addon, sign into your server and everything is right there.
Angelblue05 4132 Posted January 25, 2018 Posted January 25, 2018 Luke, it's already been suggested. Thank you. This should still be looked into. Sent from my iPhone using Tapatalk
e123enitan 276 Posted January 25, 2018 Author Posted January 25, 2018 Have you tried the new EmbyCon addon? It doesn't require any syncing. You just install the addon, sign into your server and everything is right there. I have Embycron, still I think the issue worth investigating to determining what is triggering unwanted scan in the server. Beside I strongly believe E4K is a great add on, beside occasional freezes at the initial sync it works fine and it has been improved overtime. I rebuild my server overnight, I will keep eyes on the behavior if anything weird shows up I shall report the issue, so far the behavior is settled for now.
