kingy444 117 Posted January 23, 2018 Posted January 23, 2018 Just a minor one. If you have the option to delete empty folders turned on in AutoOrganise it doesnt actually delete top level folders. Example below might help Watch Folder Folder 1 Doesnt get deletedSubFolder 1 Gets Deleted SubFolder 2 Gets DeletedSubSubFolder 1 Gets Deleted Folder 2 Doesnt get deletedSubFolder 3 Gets Deleted Folder 3 Doesnt get deleted Logs dont seem to even display the folder names for those top level folders. I have been manually deleting folders, so i dont have an example log right now, but can create the issue manually if logs required.
Luke 42253 Posted January 23, 2018 Posted January 23, 2018 It only deletes the folder that contains the media files that were organized. It's not intended to be a maid for your watch folder.
kingy444 117 Posted January 24, 2018 Author Posted January 24, 2018 It only deletes the folder that contains the media files that were organized. It's not intended to be a maid for your watch folder. makes sense - i guess i had only ever put files there directly or in bulk like above. a test with a single folder and sub file works as expected. Not sure if the wording on that can be any clearer? a note along what you wrote should clear it up for future ppl similiar to me
