Help to Photoshop's skill
I ask for help from someone with Photoshop' skiils to do something that I imagine is simple if they have skills but that after many hours I am unable to do it.
I would like to make a template for my 3D discs with the text Blu-Ray 3D ,as the sample image that I sent and put it in the template that I use for my BluRay discs, replacing the BluRay logo and respecting the size of the top because otherwise the "Make Blu-Ray Cover" program that I use will not work fine.
Any help I would appreciate it.
Edited by Teddy
Well, finally I could do it thanks to Coreldraw, which is much easier than doing it with Photoshop.
