Nisten 15 Posted January 22, 2018 Posted January 22, 2018 Title: X-Men (1992) Part of Library Type: Cartoons Issue 1: The description of the show is in German Issue 2: The primary picture is for a more recent iteration of the show when its supposed to be the retro iteration of the show (i can manually change this but it might be a contributing factor) I don't know what sort of logs you need but let me know if you need any.
Solution Deathsquirrel 745 Posted January 22, 2018 Solution Posted January 22, 2018 Most likely your naming doesn't match the source data. Look at thetvdb to ensure it's named properly. In this example the first episode of season 1 would be something like: \\SHARE\TV\X-Men The Animated Series\Season 01\X-Men The Animated Series S01E01 Night of the Sentinels (Part1).mkv 1
Nisten 15 Posted January 22, 2018 Author Posted January 22, 2018 I don't have the animated series suffix at the end so I'll try changing it and then report back with my findings
Luke 42204 Posted January 22, 2018 Posted January 22, 2018 hi @@Nisten, please let us know your findings. thanks.
Nisten 15 Posted January 23, 2018 Author Posted January 23, 2018 Adding "the animated series" suffix did the trick
