CatSama 1 Posted January 22, 2018 Posted January 22, 2018 (edited) I have a “Books” library. And I have some audio books there. Now I found that if I put some audios and a pdf (pdf is the scenario of the audio book) in in a folder, Emby scaner will ignore all the audios. Edited January 22, 2018 by CatSama
Luke 42245 Posted January 22, 2018 Posted January 22, 2018 Hi there, can you please show us the folder structure? thanks.
CatSama 1 Posted January 22, 2018 Author Posted January 22, 2018 (edited) Hi there, can you please show us the folder structure? thanks. like this ,flac is just one example ,mp3 wav have the same problem Edited January 22, 2018 by CatSama
Luke 42245 Posted March 19, 2018 Posted March 19, 2018 The issue is that we need to do a better job of handling mish-mash folder structures, or really, any folder structure. I've created a ticket on our tracker for this: https://github.com/MediaBrowser/Emby/issues/3207 Thanks.
CatSama 1 Posted April 25, 2018 Author Posted April 25, 2018 Hi there, can you please show us the folder structure? thanks. TEST.zip put this folder "TEST" into a "Books" library, then you will see Emby scaner ignore all the audios.
