Guest Posted January 21, 2018 Posted January 21, 2018 Hi, I experience some problem when video is transcoded from h265 to h264. The video in the log works fine in the web ui since it's not transcoding but when I use the emby app on an andriod phone it will not work. I have updated the graphic card drivers to the latest version and that solved some other issues I had but not this particular problem. The ffmpeg have an error message that I don't know how to solve. Best regards server-63652145228.txt ffmpeg-transcode-c2130c90-d372-4a81-8d98-07db876792dd.txt
Guest Posted January 21, 2018 Posted January 21, 2018 Hi, can you try disabling nvenc? thanks. Thanks for your reply. Unfortunately, disabling nvenc does not work either. Find a new log file attached. ffmpeg-transcode-7a0e83dc-44f0-49ca-9afc-b5ead910079f.txt
Luke 42204 Posted January 21, 2018 Posted January 21, 2018 yea there's something strange going on there. In any case, you're saying it's fine in the web app. The good news is that we're working on an android update that will make it use the same transcoding format as the web app and then this should go away. thanks.
Guest Posted January 21, 2018 Posted January 21, 2018 yea there's something strange going on there. In any case, you're saying it's fine in the web app. The good news is that we're working on an android update that will make it use the same transcoding format as the web app and then this should go away. thanks. Okey, that sounds good. When is it to be released? Another thing, could this be caused by audio transcoding? I just tried to cast to a chromecast and that work. The video transcoding was the same as when I used the android app. However, the audio was transcoded to mp3 when using the app but ac3 was used by the chromecast. The video is ac3.
Fratopolis 64 Posted January 22, 2018 Posted January 22, 2018 (edited) Kind of sounds like my issue. What server version are you on. I had to go back a version to get mine to work. https://emby.media/community/index.php?/topic/55175-after-32700-update-out-of-network-transcode-error-w-live-tv/ Edited January 22, 2018 by Fratopolis
Luke 42204 Posted January 22, 2018 Posted January 22, 2018 This is not related to your topic fratopolis, sorry.
Fratopolis 64 Posted January 22, 2018 Posted January 22, 2018 This is not related to your topic fratopolis, sorry. Doh, well remove my post!! Wish I could.
Luke 42204 Posted January 22, 2018 Posted January 22, 2018 Okey, that sounds good. When is it to be released? Another thing, could this be caused by audio transcoding? I just tried to cast to a chromecast and that work. The video transcoding was the same as when I used the android app. However, the audio was transcoded to mp3 when using the app but ac3 was used by the chromecast. The video is ac3. Should be on the beta channel this week. Thanks.
