kofzhanganguo 39 Posted January 21, 2018 Posted January 21, 2018 Right-click to add a playlist, you can only add one piece of music. Left-click to add a music playlist is correct. EMBY Version 3.2.70.0 I hope the next version can be repaired, thank you
Luke 42204 Posted January 21, 2018 Posted January 21, 2018 Hi, the right click menu is specific to each item and is separate from the multi-select tool. You cannot mix them. 1
kofzhanganguo 39 Posted January 21, 2018 Author Posted January 21, 2018 Thanks for your help, I understand.
