d00zah 152 Posted January 20, 2018 Posted January 20, 2018 (edited) Emby Server v3.2.70.0 MalwareBytes AntiMalware just completed an update & promptly decided that 'EmbyServer.exe' is ransomeware. Service was shut down & the executable quarantined, requiring a reboot. After the reboot, you can restore the executable from quarantine & exclude 'system' folder from further detection until they fix their definitions. If you are a user & haven't been bitten yet, I would suggest adding the exclusion before you do. Update: MWB reports 'the fix is in'. Stand down. Edited January 20, 2018 by d00zah 1
Luke 42204 Posted January 21, 2018 Posted January 21, 2018 Thanks for the info about the problem as well as the fix !
