weyb 25 Posted January 25, 2018 Author Posted January 25, 2018 bonsoir, il semblerait que cela fonctionne désormais !! je vais faire qq tests ce week-end pour confirmer ou infirmer... bien cordt 1
weyb 25 Posted January 26, 2018 Author Posted January 26, 2018 bonsoir, alors, ça marche !!! mais comme l'addon http://kodi.wiki/view/Add-on:Extras exige que le répertoire des extras soit "extras" uniquement, il faut tout mettre dedans, et la règle de nommage d'Emby (https://github.com/MediaBrowser/Wiki/wiki/Movie%20naming) qui dit qu'on peut avoir "deleted-scenes" par exemple, du coup, elle ne sert pas - ce qui est dommage ! - soit cette règle ne "sert à rien" - à cause de l'addon, - soit l'est pas le bon addon à utiliser --> ca serait lequel ? cordt 1
Luke 42239 Posted January 26, 2018 Posted January 26, 2018 Have you checked the deleted scenes in the web app?
Angelblue05 4132 Posted January 26, 2018 Posted January 26, 2018 (edited) @@Luke, he's saying the normal convention for Kodi, for behind the scene and all that is that it needs to exist within extras only. Emby seems to require a subfolder for everything, therefore, not compatible with Kodi. Is it possible to have the files named correctly, but all of them would be placed in the extras folder rather than separated folders for each type of extra content? Sent from my iPhone using Tapatalk Edited January 26, 2018 by Angelblue05
Luke 42239 Posted January 27, 2018 Posted January 27, 2018 Well you can put anything you want into the extras folder so I'm guessing that will probably be good enough. 1
Angelblue05 4132 Posted January 27, 2018 Posted January 27, 2018 (edited) And it will work in Emby too? Luke dit que tu peux mettre tous tes fichiers bonus dans extras. Ca devrait marcher. Sent from my iPhone using Tapatalk Edited January 27, 2018 by Angelblue05
weyb 25 Posted January 27, 2018 Author Posted January 27, 2018 hello, ok thanx, that's what I planned to do. but the question is : "why you guys at Emby did create this naming rule, if we can't use it ?" is it a Kodi limitation (and Emby's naming rule can be used with an other application) ? or did you create it without knowing that it wouldn't work in fact ? is http://kodi.wiki/view/Add-on:Extras the right addon ? regards
weyb 25 Posted February 5, 2018 Author Posted February 5, 2018 hello, 1/I was thinking about writing a tutorial about all of this implementation : what do you think ? if yes, where should I post it ? is there a special place to put it ? 2/is there a way to "see" the extras in kodi beside "their" movie (and not cliking on "c" on the remote to have "extras" on the menu) - or somewhere in the "movie" library (mediatheque) ? or in a special library ? 3/is there a way to know/to see that there are extras for a movie, without cliking on "c" on the remote (and realise there aren't any) ? regards
Angelblue05 4132 Posted February 6, 2018 Posted February 6, 2018 Hey, just saw your post 1/ Yeah. Just pm me. 2/ No. 3/ No. Extras are only supported because of add-ons. Kodi does not hold that information in database.
weyb 25 Posted February 7, 2018 Author Posted February 7, 2018 Hi, I pm-ed you as requested :-) regards
theghost31 4 Posted May 6, 2018 Posted May 6, 2018 (edited) Hi @@Angelblue05 I allow me to write here because I have an issue or maybe I don't understand something, but it's near of the initial topic BTW: Should have I to write in english or french. I'm french so I can change if it's useful. Anyway, I installed emby plugin. I'm connected to my emby server. Until now, everithing is OK. My questions: 1) How update the library of tvshows and movies ? At the left sidebar, I have the button "Update the library" or something like that but not sure that the list is updated in Kodi. If it's updated in kodi, is it updated in emby on the web interface also ? 2) Huge problem for me. When I finished an episode, it's marked as "watched" in Kodi and if I back in the menu and select again my tvshow in the list and then the season / episode of my tvshow and at this moment it's marked as "not seen" :/How Kodi can lost the status of the episode like that ? I'm a little bit lost so thank you in advance for your help EDIT1: OK after some investigations, In trakt it's up to date. In emby web interface it's up to date , so it's only in the kodi interface that's it's wrong ... Really weird EDIT2: If I exit Kodi and start it again, At the begin, after the emby refresh, the episode is marked as watched in Kodi, so the problem is fixed but I don't want leave and start Kodi everytime I watch a movie / episode. So is it a problem of refresh between Kodi / Emby ? EDIT3 (sorry for all these edits): The option "fast start" is disable. I don't know if that change something or not, so I wrote it, just in case. But in the "parameters" of Emby, If I do a "manual sync", it's works, Kodi is up to date. So I don't need, at least, to restart Kodi everytime.Do you think that you know the issue with this results ? Thank you Edited May 6, 2018 by theghost31
Angelblue05 4132 Posted May 6, 2018 Posted May 6, 2018 (edited) @@theghost31 1) No don't use that option. I wish I could remove it and banish it from existence. You'll have to repair your database most likely clicking this at any point messed up the database which is handled by the add-on. Best way is to launch the emby add-on > reset local database > yes/yes/no. Then let your content resync. 2) probably related to #1. Do not use update library, do not use clean on update. The way the sync works is anytime you do something that is related to emby content, it will send the information to your server. Then the server will trigger an event which applies the changes to Emby for Kodi. Likely, number 2, with the Kodi database not matching up to what the add-on expects, then you get weird behaviors, such as updates not correctly applied. Edited May 6, 2018 by Angelblue05
theghost31 4 Posted May 6, 2018 Posted May 6, 2018 @@Angelblue05Thank you for your answer. unfortunatly, after to have try to disable Trakt, reset the local database etc. It's exactly the same issue. I tried on an other PC ( also under Linux Ubuntu), same problem o.O
Angelblue05 4132 Posted May 6, 2018 Posted May 6, 2018 Are you certain it is not delayed? Can you provide your Kodi log capturing this issue? Do as you'd normally do to create this watched status problem, thank you.
theghost31 4 Posted May 7, 2018 Posted May 7, 2018 Hi This is my log where I start a movie, stop at the middle, try to back using the "..." in the menu but at the first click, that change the movie as "not watched" and if I click I can return in the previous menu ...I can do a video also if you want to have the UI / LOG in the same to understand my steps Thank you Edit: Other question about the backend of emby, What do you recommand to transcode ? VAAPI ? Intel Quick Shift ?. I have a I5 7260U. I selected INTEL QUICK SHIFT, but on my NUC and with two transcodage in the same time, I get 100% of CPU . Maybe it's normal.LOG: 09:53:58.449 T:139796315870976 NOTICE: EMBY.kodimonitor -> Method: GUI.OnScreensaverDeactivated Data: {"shuttingdown":false} 09:54:18.571 T:139797137131904 NOTICE: Log level changed to "LOG_LEVEL_DEBUG_FREEMEM" 09:54:18.571 T:139797137131904 NOTICE: Enabled debug logging due to GUI setting. Level 2. 09:54:18.571 T:139797137131904 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 09:54:18.572 T:139797137131904 DEBUG: ------ Window Init () ------ 09:54:20.004 T:139797137131904 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x001b, modifier: 0x0 09:54:20.138 T:139797137131904 DEBUG: OnKey: escape (0xf01b) pressed, action is PreviousMenu 09:54:20.145 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:54:20.504 T:139797137131904 DEBUG: ------ Window Deinit (SettingsCategory.xml) ------ 09:54:20.504 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 09:54:20.504 T:139797137131904 DEBUG: ------ Window Init (Settings.xml) ------ 09:54:20.505 T:139797137131904 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x0000, modifier: 0x0 09:54:20.704 T:139797137131904 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x001b, modifier: 0x0 09:54:20.838 T:139797137131904 DEBUG: OnKey: escape (0xf01b) pressed, action is PreviousMenu 09:54:20.838 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:54:21.103 T:139797137131904 DEBUG: ------ Window Deinit (Settings.xml) ------ 09:54:21.104 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 09:54:21.104 T:139797137131904 DEBUG: ------ Window Init (Home.xml) ------ 09:54:21.110 T:139797137131904 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x0000, modifier: 0x0 09:54:21.206 T:139797137131904 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x001b, modifier: 0x0 09:54:21.374 T:139797137131904 DEBUG: OnKey: escape (0xf01b) pressed, action is PreviousMenu 09:54:21.374 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:54:21.374 T:139797137131904 DEBUG: Keyboard: scancode: 0x09, sym: 0x001b, unicode: 0x0000, modifier: 0x0 09:54:23.405 T:139797137131904 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 09:54:23.405 T:139797137131904 DEBUG: OnKey: left (0xf082) pressed, action is Left 09:54:23.547 T:139797137131904 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 09:54:24.287 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:24.287 T:139797137131904 DEBUG: OnKey: left (0xf082) pressed, action is Left 09:54:24.437 T:139797137131904 DEBUG: Keyboard: scancode: 0x71, sym: 0x0114, unicode: 0x0000, modifier: 0x0 09:54:24.931 T:139797137131904 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 09:54:24.931 T:139797137131904 DEBUG: OnKey: down (0xf081) pressed, action is Down 09:54:25.104 T:139797137131904 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 09:54:25.875 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:25.875 T:139797137131904 DEBUG: OnKey: down (0xf081) pressed, action is Down 09:54:26.050 T:139797137131904 DEBUG: Keyboard: scancode: 0x74, sym: 0x0112, unicode: 0x0000, modifier: 0x0 09:54:27.606 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:27.607 T:139797137131904 DEBUG: OnKey: right (0xf083) pressed, action is Right 09:54:27.610 T:139796302464768 DEBUG: Thread JobWorker start, auto delete: true 09:54:27.773 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:37.050 T:139797137131904 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 09:54:37.297 T:139797137131904 DEBUG: OnKey: return (0xf00d) pressed, action is Select 09:54:37.297 T:139797137131904 DEBUG: Activating window ID: 10025 09:54:37.639 T:139797137131904 DEBUG: ------ Window Deinit (Home.xml) ------ 09:54:37.646 T:139797137131904 DEBUG: ------ Window Init (MyVideoNav.xml) ------ 09:54:37.649 T:139797137131904 DEBUG: CGUIMediaWindow::GetDirectory (videodb://inprogresstvshows/60/-2/?tvshowid=60) 09:54:37.649 T:139797137131904 DEBUG: ParentPath = [videodb://inprogresstvshows/60/-2/?tvshowid=60] 09:54:37.655 T:139797137131904 DEBUG: RunQuery took 1 ms for 17 items query: select * from episode_view WHERE episode_view.idShow = 60 09:54:37.658 T:139797137131904 DEBUG: RunQuery took 1 ms for 0 items query: select * from movie_view join movielinktvshow on movielinktvshow.idMovie=movie_view.idMovie WHERE movielinktvshow.idShow = 60 09:54:37.663 T:139797137131904 DEBUG: WindowVideoNav::GetDirectory 09:54:37.671 T:139793918772992 DEBUG: Thread BackgroundLoader start, auto delete: false 09:54:37.677 T:139793918772992 DEBUG: Thread BackgroundLoader 139793918772992 terminating 09:54:37.677 T:139797137131904 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 09:54:39.540 T:139797137131904 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x000d, modifier: 0x0 09:54:39.644 T:139797137131904 DEBUG: OnKey: return (0xf00d) pressed, action is Select 09:54:39.650 T:139797137131904 DEBUG: OnPlayMedia plugin://plugin.video.emby.tvshows/10d903bc66e8f180de73ac0d471e9712/?dbid=2200&mode=play&id=2d5ece82ee7607f988e511f89e671aa5&filename=The_Simpsons_S29E14.mkv 09:54:39.650 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc 09:54:39.650 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear 09:54:39.650 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc 09:54:39.650 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd 09:54:39.651 T:139797137131904 DEBUG: StartScript - calling plugin Emby('plugin://plugin.video.emby.tvshows/10d903bc66e8f180de73ac0d471e9712/','3','?dbid=2200&mode=play&id=2d5ece82ee7607f988e511f89e671aa5&filename=The_Simpsons_S29E14.mkv') 09:54:39.651 T:139796345247488 DEBUG: Thread LanguageInvoker start, auto delete: false 09:54:39.651 T:139796345247488 INFO: initializing python engine. 09:54:39.651 T:139796345247488 DEBUG: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): start processing 09:54:39.666 T:139796345247488 DEBUG: -->Python Interpreter Initialized<-- 09:54:39.666 T:139796345247488 DEBUG: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): the source file to load is "/root/.kodi/addons/plugin.video.emby.tvshows/default.py" 09:54:39.666 T:139796345247488 DEBUG: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): setting the Python path to /root/.kodi/addons/plugin.video.emby.tvshows:/root/.kodi/addons/script.module.certifi/lib:/root/.kodi/addons/script.module.chardet/lib:/root/.kodi/addons/script.module.idna/lib:/root/.kodi/addons/script.module.requests/lib:/root/.kodi/addons/script.module.urllib3/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat 09:54:39.666 T:139796345247488 DEBUG: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): entering source directory /root/.kodi/addons/plugin.video.emby.tvshows 09:54:39.666 T:139796345247488 DEBUG: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): instantiating addon using automatically obtained id of "plugin.video.emby.tvshows" dependent on version 2.19.0 of the xbmc.python api 09:54:39.672 T:139793918772992 DEBUG: Thread scriptobs start, auto delete: false 09:54:39.719 T:139796315870976 NOTICE: EMBY.kodimonitor -> Method: Playlist.OnClear Data: {"playlistid":1} 09:54:39.871 T:139797137131904 DEBUG: ------ Window Init (DialogBusy.xml) ------ 09:54:39.935 T:139796345247488 NOTICE: EMBY.default_tvshows -> Parameter string: ?dbid=2200&mode=play&id=2d5ece82ee7607f988e511f89e671aa5&filename=The_Simpsons_S29E14.mkv 09:54:40.023 T:139796345247488 NOTICE: EMBY.playbackutils -> Play called: Fears of a Clown 09:54:40.109 T:139796345247488 NOTICE: EMBY.playutils -> playback info: {u'SupportsDirectStream': True, u'Container': u'mkv', u'RequiresClosing': False, u'IgnoreDts': False, u'IgnoreIndex': False, u'DefaultAudioStreamIndex': 1, u'SupportsDirectPlay': True, u'MediaStreams': [{u'IsInterlaced': False, u'Index': 0, u'AverageFrameRate': 23.9760246, u'TimeBase': u'1/1000', u'Width': 1280, u'VideoRange': u'SDR', u'Codec': u'h264', u'IsForced': False, u'AspectRatio': u'16:9', u'Type': u'Video', u'IsTextSubtitleStream': False, u'Profile': u'High', u'DisplayTitle': u'720P H264', u'NalLengthSize': u'4', u'ColorSpace': u'bt709', u'CodecTimeBase': u'1001/48000', u'RealFrameRate': 23.9760246, u'Level': 41, u'RefFrames': 1, u'BitDepth': 8, u'BitRate': 2126424, u'IsDefault': True, u'IsAnamorphic': False, u'SupportsExternalStream': False, u'Height': 720, u'IsAVC': True, u'PixelFormat': u'yuv420p', u'IsExternal': False}, {u'IsAnamorphic': False, u'IsInterlaced': False, u'DisplayTitle': u'Dolby Digital 5.1 Default', u'SupportsExternalStream': False, u'ChannelLayout': u'5.1', u'Index': 1, u'Type': u'Audio', u'IsForced': False, u'Level': 0, u'Channels': 6, u'Codec': u'ac3', u'CodecTimeBase': u'1/48000', u'TimeBase': u'1/1000', u'SampleRate': 48000, u'BitRate': 384000, u'IsTextSubtitleStream': False, u'IsDefault': True, u'IsExternal': False}, {u'IsAnamorphic': False, u'IsInterlaced': False, u'DisplayTitle': u'Fre Default', u'SupportsExternalStream': True, u'Language': u'fre', u'Title': u'FR', u'Index': 2, u'IsForced': False, u'DeliveryMethod': u'Embed', u'Codec': u'subrip', u'CodecTimeBase': u'0/1', u'TimeBase': u'1/1000', u'Level': 0, u'Type': u'Subtitle', u'IsTextSubtitleStream': True, u'IsDefault': True, u'IsExternal': False}], u'Type': u'Default', u'ReadAtNativeFramerate': False, u'RequiresLooping': False, u'Path': u'{emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token}', u'RequiresOpening': False, u'Bitrate': 2126424, u'IsRemote': False, u'Name': u'The_Simpsons_S29E14', u'RequiredHttpHeaders': {}, u'SupportsTranscoding': False, u'Formats': [], u'Protocol': u'File', u'IsInfiniteStream': False, u'GenPtsInput': False, u'VideoType': u'VideoFile', u'ETag': u'fe6c35f9d479781058b7cff8471265ba', u'RunTimeTicks': 12766400512, u'SupportsProbing': True, u'Id': u'2d5ece82ee7607f988e511f89e671aa5', u'DefaultSubtitleStreamIndex': 2} 09:54:40.111 T:139796345247488 NOTICE: EMBY.playutils -> play method: DirectStream play url: {emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token} 09:54:40.171 T:139796345247488 INFO: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): script successfully run 09:54:40.203 T:139793918772992 DEBUG: Thread scriptobs 139793918772992 terminating 09:54:40.203 T:139797137131904 INFO: easy_aquire - Created session to https://mydomain.com 09:54:40.246 T:139796345247488 WARNING: CPythonInvoker(8, /root/.kodi/addons/plugin.video.emby.tvshows/default.py): the python script "/root/.kodi/addons/plugin.video.emby.tvshows/default.py" has left several classes in memory that we couldn't clean up. The classes include: N9XBMCAddon9xbmcaddon5AddonE 09:54:40.246 T:139796345247488 INFO: Python script stopped 09:54:40.246 T:139796345247488 DEBUG: Thread LanguageInvoker 139796345247488 terminating 09:54:40.265 T:139797137131904 DEBUG: CCurlFile::GetMimeType - https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 -> video/x-matroska 09:54:40.266 T:139797137131904 DEBUG: Loading settings for https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 09:54:40.268 T:139797137131904 DEBUG: CPlayerCoreFactory::GetPlayers(https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45) 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mms/udp 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: streams 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: aacp/sdp 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: mp2 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv 09:54:40.268 T:139797137131904 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio 09:54:40.268 T:139797137131904 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players 09:54:40.268 T:139797137131904 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (VideoPlayer) 09:54:40.268 T:139797137131904 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0 09:54:40.268 T:139797137131904 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1 09:54:40.268 T:139797137131904 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players 09:54:40.268 T:139796345247488 DEBUG: Thread RefClock start, auto delete: false 09:54:40.271 T:139796345247488 DEBUG: CVideoSyncDRM::Setup - setting up DRM 09:54:40.271 T:139797137131904 DEBUG: Radio UECP (RDS) Processor - new CDVDRadioRDSData 09:54:40.271 T:139797137131904 NOTICE: VideoPlayer: Opening: https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 09:54:40.271 T:139797137131904 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED 09:54:40.276 T:139796345247488 DEBUG: CVideoReferenceClock: Detected refreshrate: 30.000 hertz 09:54:40.277 T:139797137131904 DEBUG: CCurlFile::GetMimeType - https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 -> video/x-matroska 09:54:40.277 T:139797137131904 DEBUG: LinuxRendererGL: Cleaning up GL resources 09:54:40.277 T:139797137131904 DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16 09:54:40.277 T:139793918772992 DEBUG: Thread VideoPlayer start, auto delete: false 09:54:40.277 T:139793918772992 NOTICE: Creating InputStream 09:54:40.277 T:139793918772992 DEBUG: CurlFile::Open(0x7f244edeb670) https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 09:54:40.455 T:139793918772992 DEBUG: CFileCache::Open - opening <emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream> using cache 09:54:40.455 T:139793918772992 DEBUG: CurlFile::Open(0x7f24a402efc0) https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 09:54:40.530 T:139793918772992 NOTICE: Creating Demuxer 09:54:40.531 T:139794231305984 DEBUG: Thread FileCache start, auto delete: false 09:54:40.531 T:139793918772992 DEBUG: Open - probing detected format [matroska,webm] 09:54:40.531 T:139794231305984 INFO: easy_aquire - Created session to https://mydomain.com 09:54:40.531 T:139794231305984 DEBUG: CurlFile::CReadState::Connect - Resume from position 339269282 09:54:40.674 T:139793918772992 DEBUG: Seek - waiting for position 339333637. 09:54:40.692 T:139793918772992 DEBUG: Open - avformat_find_stream_info starting 09:54:40.704 T:139793918772992 DEBUG: Open - av_find_stream_info finished 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Input #0, matroska,webm, https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c4': 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Metadata: 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: encoder : libebml v1.3.5 + libmatroska v1.4.8 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: creation_time : 2018-04-11 16:18:55 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Duration: 00:21:16.64, start: 0.000000, bitrate: 2126 kb/s 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Stream #0:0: Video: h264 (High), yuv420p(tv, bt709/unknown/unknown), 1280x720, SAR 1:1 DAR 16:9, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default) 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Metadata: 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: BPS-eng : 1740534 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: DURATION-eng : 00:21:16.609000000 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: NUMBER_OF_FRAMES-eng: 30608 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: NUMBER_OF_BYTES-eng: 277747756 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_WRITING_APP-eng: mkvmerge v22.0.0 ('At The End Of The World') 64-bit 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_WRITING_DATE_UTC-eng: 2018-04-11 16:18:55 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default) 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Metadata: 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: BPS-eng : 384000 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: DURATION-eng : 00:21:16.640000000 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: NUMBER_OF_FRAMES-eng: 39895 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: NUMBER_OF_BYTES-eng: 61278720 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_WRITING_APP-eng: mkvmerge v22.0.0 ('At The End Of The World') 64-bit 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_WRITING_DATE_UTC-eng: 2018-04-11 16:18:55 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Stream #0:2(fre): Subtitle: subrip (default) 09:54:40.704 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: Metadata: 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: title : FR 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: BPS-eng : 105 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: DURATION-eng : 00:20:19.314000000 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: NUMBER_OF_FRAMES-eng: 422 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: NUMBER_OF_BYTES-eng: 16008 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_WRITING_APP-eng: mkvmerge v22.0.0 ('At The End Of The World') 64-bit 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_WRITING_DATE_UTC-eng: 2018-04-11 16:18:55 09:54:40.705 T:139793918772992 INFO: ffmpeg[7F244EDEC700]: _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES 09:54:40.705 T:139793918772992 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 0 09:54:40.705 T:139793918772992 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 1 09:54:40.705 T:139793918772992 DEBUG: CDVDDemuxFFmpeg::AddStream ID: 2 09:54:40.705 T:139793918772992 DEBUG: CDVDInputStreamFile::SetReadRate - set cache throttle rate to 292383 bytes per second 09:54:40.705 T:139793918772992 NOTICE: Opening stream: 0 source: 256 09:54:40.705 T:139793918772992 NOTICE: Creating video codec with codec id: 28 09:54:40.705 T:139793918772992 DEBUG: FactoryCodec - Video: - Opening 09:54:40.705 T:139793918772992 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 09:54:40.705 T:139793918772992 DEBUG: CDVDVideoCodecFFmpeg - Updated codec: ff-h264 09:54:40.705 T:139793918772992 DEBUG: FactoryCodec - Video: ff-h264 - Opened 09:54:40.705 T:139793918772992 DEBUG: CVideoPlayerVideo::OpenStream - open stream with codec id: 28 09:54:40.705 T:139793918772992 NOTICE: Creating video thread 09:54:40.705 T:139793918772992 NOTICE: Opening stream: 1 source: 256 09:54:40.705 T:139793918772992 NOTICE: Finding audio codec for: 86019 09:54:40.705 T:139793918772992 DEBUG: FactoryCodec - Audio: FFmpeg - Opening 09:54:40.705 T:139793901991680 DEBUG: Thread VideoPlayerVideo start, auto delete: false 09:54:40.705 T:139793901991680 NOTICE: running thread: video_thread 09:54:40.705 T:139793918772992 DEBUG: FactoryCodec - Audio: FFmpeg - Opened 09:54:40.705 T:139793918772992 NOTICE: Creating audio thread 09:54:40.706 T:139793918772992 NOTICE: Opening stream: 2 source: 256 09:54:40.706 T:139793918772992 DEBUG: FactoryCodec - Overlay: Text Subtitle Decoder - Opening 09:54:40.706 T:139793825412864 DEBUG: Thread VideoPlayerAudio start, auto delete: false 09:54:40.706 T:139793918772992 DEBUG: FactoryCodec - Overlay: Text Subtitle Decoder - Opened 09:54:40.706 T:139793825412864 NOTICE: running thread: CVideoPlayerAudio::Process() 09:54:40.706 T:139793918772992 DEBUG: OnPlayBackStarted: play state was 1, starting 1 09:54:40.706 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 1 09:54:40.706 T:139797137131904 DEBUG: PlayFile: OpenFile succeed, play state 2 09:54:40.706 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:40.706 T:139797137131904 DEBUG: OnPlayBackStarted: play state was 2, starting 0 09:54:40.706 T:139793901991680 INFO: CVideoPlayerVideo - Stillframe left, switching to normal playback 09:54:40.706 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.706 T:139797137131904 DEBUG: Keyboard: scancode: 0x24, sym: 0x000d, unicode: 0x0000, modifier: 0x0 09:54:40.707 T:139793901991680 DEBUG: VAAPI - open decoder 09:54:40.713 T:139793901991680 DEBUG: VAAPI - initialize version 0.39 09:54:40.713 T:139793901991680 DEBUG: VAAPI - driver in use: Intel i965 driver for Intel(R) Kabylake - 1.7.0 09:54:40.713 T:139793901991680 DEBUG: VAAPI - attrib 0 (get/set) min -100 max 100 value 0x0 09:54:40.713 T:139793901991680 DEBUG: VAAPI - attrib 1 (get/set) min 0 max 100 value 0x32 09:54:40.713 T:139793901991680 DEBUG: VAAPI - attrib 2 (get/set) min -180 max 180 value 0x0 09:54:40.713 T:139793901991680 DEBUG: VAAPI - attrib 3 (get/set) min 0 max 100 value 0x32 09:54:40.713 T:139793901991680 DEBUG: VAAPI - attrib 6 (get/set) min 0 max 3 value 0x0 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 0 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 1 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 13 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 6 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 7 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 15 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 16 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 8 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 9 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 10 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile -1 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 12 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 14 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 17 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 18 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 19 09:54:40.713 T:139793901991680 DEBUG: VAAPI - profile 21 09:54:40.714 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 2 09:54:40.714 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:40.714 T:139793817020160 DEBUG: Thread Vaapi-Output start, auto delete: false 09:54:40.714 T:139793817020160 NOTICE: COutput::OnStartup: Output Thread created 09:54:40.716 T:139793825412864 DEBUG: CDVDAudio::Pause - pausing audio stream 09:54:40.716 T:139793825412864 DEBUG: Previous line repeats 1 times. 09:54:40.716 T:139793825412864 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through) 09:54:40.716 T:139793825412864 DEBUG: CVideoPlayerAudio:: synctype set to 1: resample 09:54:40.716 T:139796554970880 INFO: CActiveAESink::OpenSink - initialize sink 09:54:40.716 T:139796554970880 DEBUG: CActiveAESink::OpenSink - trying to open device PULSE:Default 09:54:40.718 T:139796554970880 DEBUG: PulseAudio: Context authorizing 09:54:40.719 T:139796554970880 DEBUG: PulseAudio: Context setting name 09:54:40.719 T:139796554970880 DEBUG: PulseAudio: Context ready 09:54:40.719 T:139796554970880 DEBUG: PULSE does not support format: AE_FMT_FLOATP - will fallback to AE_FMT_FLOAT 09:54:40.729 T:139793817020160 DEBUG: VAAPI::COutput::CreateEGLContext - created context 09:54:40.729 T:139793817020160 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/libsse4-x86_64-linux.so) 09:54:40.729 T:139793817020160 DEBUG: Loading: /usr/lib/x86_64-linux-gnu/kodi/system/libsse4-x86_64-linux.so 09:54:40.732 T:139793817020160 DEBUG: VAAPI::COutput::InitBufferPool - Surfaces created 09:54:40.732 T:139793901991680 DEBUG: CDVDVideoCodecFFmpeg - Updated codec: ff-h264-vaapi 09:54:40.733 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.735 T:139796302464768 DEBUG: Previous line repeats 1 times. 09:54:40.735 T:139796302464768 DEBUG: CGUIInfoManager::SetCurrentMovie(https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45) 09:54:40.736 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc 09:54:40.736 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay 09:54:40.743 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.753 T:139796554970880 DEBUG: PulseAudio: Stream ready 09:54:40.755 T:139796554970880 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms 09:54:40.760 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.765 T:139796554970880 DEBUG: CActiveAESink::OpenSink - PULSE Initialized: 09:54:40.765 T:139796554970880 DEBUG: Output Device : Default 09:54:40.765 T:139796554970880 DEBUG: Sample Rate : 48000 09:54:40.765 T:139796554970880 DEBUG: Sample Format : AE_FMT_FLOAT 09:54:40.765 T:139796554970880 DEBUG: Channel Count : 2 09:54:40.765 T:139796554970880 DEBUG: Channel Layout: FL,FR 09:54:40.765 T:139796554970880 DEBUG: Frames : 2400 09:54:40.765 T:139796554970880 DEBUG: Frame Size : 8 09:54:40.772 T:139796487857920 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted 09:54:40.772 T:139793901991680 DEBUG: Previous line repeats 1 times. 09:54:40.772 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.773 T:139793918772992 DEBUG: CVideoPlayer::HandleMessages - player started 1 09:54:40.778 T:139793901991680 DEBUG: CRenderManager::Configure - change configuration. 1280x720. display: 1280x720. framerate: 23.98. format: VAAPI 09:54:40.778 T:139797137131904 DEBUG: ------ Window Deinit (DialogBusy.xml) ------ 09:54:40.781 T:139797137131904 DEBUG: DeleteRenderer - deleting renderer 09:54:40.781 T:139797137131904 DEBUG: LinuxRendererGL: Cleaning up GL resources 09:54:40.801 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:40.801 T:139797137131904 DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16 09:54:40.801 T:139797137131904 DEBUG: GL: Requested render method: 0 09:54:40.801 T:139797137131904 DEBUG: GL: BaseYUV2RGBGLSLShader: defines: #define XBMC_texture_rectangle 0 #define XBMC_texture_rectangle_hack 0 #define XBMC_STRETCH 0 #define XBMC_NV12_RRG 09:54:40.801 T:139797137131904 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader 09:54:40.802 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:40.802 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:40.803 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:40.803 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:40.807 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:40.807 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:40.807 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:40.807 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:40.809 T:139797137131904 NOTICE: GL: NPOT texture support detected 09:54:40.809 T:139797137131904 NOTICE: GL: Using GL_ARB_pixel_buffer_object 09:54:40.809 T:139797137131904 NOTICE: Using GL_TEXTURE_2D 09:54:40.809 T:139797137131904 DEBUG: CRenderManager::Configure - 4 09:54:40.809 T:139793901991680 DEBUG: CVideoReferenceClock: Clock speed 100.100000% 09:54:40.812 T:139793918772992 DEBUG: CVideoPlayer::HandleMessages - player started 2 09:54:40.812 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 3 09:54:40.812 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:40.812 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 0 09:54:40.812 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:40.812 T:139793918772992 DEBUG: VideoPlayer::Sync - Audio - pts: 160000.000000, cache: 394525.628570, totalcache: 550000.011921 09:54:40.812 T:139793918772992 DEBUG: VideoPlayer::Sync - Video - pts: 0.000000, cache: 50000.000000, totalcache: 100000.000000 09:54:40.812 T:139793825412864 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(-234525.628570) 09:54:40.812 T:139793901991680 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(-234525.628570) 09:54:40.812 T:139793825412864 DEBUG: CDVDAudio::Resume - resume audio stream 09:54:40.812 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.812 T:139796487857920 DEBUG: ActiveAE - start sync of audio stream 09:54:40.813 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:40.835 T:139797137131904 DEBUG: Previous line repeats 2 times. 09:54:40.835 T:139797137131904 DEBUG: GL: Requested render method: 0 09:54:40.835 T:139797137131904 DEBUG: GL: BaseYUV2RGBGLSLShader: defines: #define XBMC_texture_rectangle 0 #define XBMC_texture_rectangle_hack 0 #define XBMC_STRETCH 0 #define XBMC_NV12_RRG 09:54:40.835 T:139797137131904 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader 09:54:40.836 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:40.836 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:40.836 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:40.836 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:40.840 T:139797137131904 NOTICE: GL: NPOT texture support detected 09:54:40.840 T:139797137131904 NOTICE: GL: Using GL_ARB_pixel_buffer_object 09:54:40.846 T:139797137131904 DEBUG: Activating window ID: 12005 09:54:40.850 T:139797137131904 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------ 09:54:40.852 T:139797137131904 DEBUG: ------ Window Init (VideoFullScreen.xml) ------ 09:54:40.853 T:139797137131904 NOTICE: Display resolution ADJUST : DP-1: 3840x2160 @ 23.98Hz (30) (weight: 0.000) 09:54:40.853 T:139797137131904 NOTICE: CWinSystemX11::SetFullScreen - calling xrandr 09:54:40.854 T:139797137131904 DEBUG: OnLostDevice - notify display change event 09:54:40.854 T:139797137131904 DEBUG: Flush - flushing renderer 09:54:40.865 T:139797137131904 NOTICE: VideoPlayer: OnLostDisplay received 09:54:40.865 T:139797137131904 INFO: XRANDR: /usr/lib/x86_64-linux-gnu/kodi/kodi-xrandr --screen 0 --output DP-1 --mode 0x4d 09:54:40.926 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error of 73.471740, start adjusting 09:54:40.926 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error 23.471740 below threshold of 30.000000 09:54:41.177 T:139793825412864 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: 1 09:54:41.236 T:139797137131904 INFO: GL: Maximum texture width: 16384 09:54:41.280 T:139797137131904 DEBUG: GL: Requested render method: 0 09:54:41.281 T:139797137131904 DEBUG: GL: BaseYUV2RGBGLSLShader: defines: #define XBMC_texture_rectangle 0 #define XBMC_texture_rectangle_hack 0 #define XBMC_STRETCH 0 #define XBMC_NV12_RRG 09:54:41.281 T:139797137131904 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader 09:54:41.282 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:41.282 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:41.284 T:139796315870976 NOTICE: EMBY.kodimonitor -> Method: Player.OnPlay Data: {"item":{"id":2200,"type":"episode"},"player":{"playerid":1,"speed":1}} 09:54:41.284 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:41.284 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:41.288 T:139796315870976 NOTICE: EMBY.kodimonitor -> kodi_id: 2200 item_type: episode 09:54:41.293 T:139796315870976 NOTICE: EMBY.player -> ONPLAYBACK_STARTED: {emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token} itemid: 2d5ece82ee7607f988e511f89e671aa5 09:54:41.301 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:41.301 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:41.302 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:41.302 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:41.307 T:139797137131904 NOTICE: GL: NPOT texture support detected 09:54:41.307 T:139797137131904 NOTICE: GL: Using GL_ARB_pixel_buffer_object 09:54:41.307 T:139797137131904 NOTICE: Using GL_TEXTURE_2D 09:54:41.309 T:139793901991680 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: 1 09:54:41.326 T:139797137131904 DEBUG: NotifyXRREvent - notify display reset event 09:54:41.520 T:139797137131904 DEBUG: RecreateWindow - current output: DP-1, mode: 0x4d, refresh: 23.976 09:54:41.520 T:139797137131904 DEBUG: OnLostDevice - notify display change event 09:54:41.520 T:139797137131904 DEBUG: Flush - flushing renderer 09:54:41.520 T:139797137131904 NOTICE: VideoPlayer: OnLostDisplay received 09:54:41.520 T:139793825412864 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: 1 09:54:41.520 T:139793901991680 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: 1 09:54:41.532 T:139797137131904 DEBUG: Window Manager Name: Compiz 09:54:41.550 T:139797137131904 DEBUG: CWinSystemX11::RefreshEGLContext: refreshing context 09:54:41.608 T:139797137131904 NOTICE: VideoPlayer: OnResetDisplay received 09:54:41.609 T:139793825412864 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_PAUSE: 0 09:54:41.609 T:139793901991680 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_PAUSE: 0 09:54:41.609 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:41.610 T:139797137131904 INFO: GL: Maximum texture width: 16384 09:54:41.614 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:41.622 T:139793901991680 DEBUG: Previous line repeats 2 times. 09:54:41.622 T:139793901991680 NOTICE: CDVDVideoCodecFFmpeg::CDropControl: calculated diff time: 41727 09:54:41.623 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:41.624 T:139793817020160 WARNING: COutput::QueueReturnPicture - pic not found 09:54:41.627 T:139796315870976 NOTICE: EMBY.player -> ADDING_FILE: {'{emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token}': {'currentfile': '{emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token}', 'SubtitleStreamIndex': '', 'playsession_id': u'1426fa4ddfcb49f6882fe33b75e6eac0', 'AudioStreamIndex': 1, 'mediasource_id': u'2d5ece82ee7607f988e511f89e671aa5', 'item_id': u'2d5ece82ee7607f988e511f89e671aa5', 'Type': u'Episode', 'playmethod': u'DirectStream', 'refresh_id': u'10d903bc66e8f180de73ac0d471e9712', 'currentPosition': 0, 'runtime': 12766400512}} 09:54:41.627 T:139797137131904 DEBUG: GL: Requested render method: 0 09:54:41.628 T:139797137131904 DEBUG: GL: BaseYUV2RGBGLSLShader: defines: #define XBMC_texture_rectangle 0 #define XBMC_texture_rectangle_hack 0 #define XBMC_STRETCH 0 #define XBMC_NV12_RRG 09:54:41.628 T:139797137131904 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader 09:54:41.631 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:41.631 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:41.633 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:41.633 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:41.644 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:41.644 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:41.645 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:41.645 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:41.649 T:139797137131904 NOTICE: GL: NPOT texture support detected 09:54:41.649 T:139797137131904 NOTICE: GL: Using GL_ARB_pixel_buffer_object 09:54:41.649 T:139797137131904 NOTICE: Using GL_TEXTURE_2D 09:54:41.649 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 1 09:54:41.677 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:41.677 T:139797137131904 INFO: GL: Enabling VSYNC 09:54:41.908 T:139797137131904 DEBUG: GL: Requested render method: 0 09:54:41.908 T:139797137131904 DEBUG: GL: BaseYUV2RGBGLSLShader: defines: #define XBMC_texture_rectangle 0 #define XBMC_texture_rectangle_hack 0 #define XBMC_STRETCH 0 #define XBMC_NV12_RRG 09:54:41.908 T:139797137131904 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader 09:54:41.908 T:139797137131904 DEBUG: GL: Vertex Shader compilation log: 09:54:41.908 T:139797137131904 DEBUG: GL: Vertex Shader compiled successfully 09:54:41.909 T:139797137131904 DEBUG: GL: Pixel Shader compilation log: 09:54:41.909 T:139797137131904 DEBUG: GL: Fragment Shader compiled successfully 09:54:41.912 T:139797137131904 NOTICE: GL: NPOT texture support detected 09:54:41.912 T:139797137131904 NOTICE: GL: Using GL_ARB_pixel_buffer_object 09:54:41.939 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error 483.159628 above threshold of 200.000000 09:54:42.070 T:139796345247488 DEBUG: CVideoSyncDRM::Setup - setting up DRM 09:54:42.070 T:139796345247488 DEBUG: CVideoReferenceClock: Detected refreshrate: 23.976 hertz 09:54:42.071 T:139793901991680 DEBUG: CVideoReferenceClock: Clock speed 99.999899% 09:54:42.378 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error 0.159628, last average error: 483.159628 09:54:42.504 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error of 263.077027, start adjusting 09:54:42.818 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error 0.817557 below threshold of 30.000000 09:54:45.573 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:45.574 T:139797137131904 DEBUG: OnKey: right (0xf083) pressed, action is StepForward 09:54:45.574 T:139797137131904 DEBUG: ------ Window Init (DialogSeekBar.xml) ------ 09:54:45.577 T:139797137131904 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------ 09:54:45.701 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:45.951 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:45.951 T:139797137131904 DEBUG: OnKey: right (0xf083) pressed, action is StepForward 09:54:46.118 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:46.452 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:46.452 T:139797137131904 DEBUG: OnKey: right (0xf083) pressed, action is StepForward 09:54:46.537 T:139793901991680 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333 09:54:46.618 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:47.118 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:47.119 T:139797137131904 DEBUG: OnKey: right (0xf083) pressed, action is StepForward 09:54:47.327 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:47.828 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:47.828 T:139797137131904 DEBUG: OnKey: right (0xf083) pressed, action is StepForward 09:54:47.995 T:139797137131904 DEBUG: Keyboard: scancode: 0x72, sym: 0x0113, unicode: 0x0000, modifier: 0x0 09:54:48.579 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnSeek from xbmc 09:54:48.579 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnSeek 09:54:48.583 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 1 09:54:48.583 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:48.583 T:139793918772992 DEBUG: demuxer seek to: 306761.000000 09:54:48.583 T:139794231305984 INFO: CFileCache::Process - Source read didn't return any data! Hit eof(?) 09:54:48.583 T:139793918772992 DEBUG: Seek - waiting for position 339316390. 09:54:48.585 T:139794231305984 DEBUG: CurlFile::CReadState::Connect - Resume from position 108198557 09:54:48.607 T:139793918772992 DEBUG: SeekTime - seek ended up on time 309267 09:54:48.607 T:139793918772992 DEBUG: demuxer seek to: 306761.000000, success 09:54:48.607 T:139793918772992 DEBUG: CVideoPlayer::FlushBuffers - flushing buffers 09:54:48.643 T:139796315870976 NOTICE: EMBY.kodimonitor -> Method: Player.OnSeek Data: {"item":{"id":2200,"type":"episode"},"player":{"playerid":1,"seekoffset":{"hours":0,"milliseconds":0,"minutes":5,"seconds":0},"speed":1,"time":{"hours":0,"milliseconds":745,"minutes":5,"seconds":6}}} 09:54:48.729 T:139793825412864 DEBUG: CDVDAudio::Pause - pausing audio stream 09:54:48.836 T:139793825412864 DEBUG: CDVDAudio::Flush - flush audio stream 09:54:48.836 T:139793825412864 DEBUG: CDVDAudio::Pause - pausing audio stream 09:54:48.836 T:139793825412864 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE 09:54:48.836 T:139793901991680 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE 09:54:48.836 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 2 09:54:48.837 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:48.837 T:139793901991680 INFO: CVideoPlayerVideo - Stillframe left, switching to normal playback 09:54:48.837 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:48.837 T:139793901991680 DEBUG: VAAPI::Release pre-cleanup 09:54:48.837 T:139793901991680 DEBUG: CDVDVideoCodecFFmpeg - Updated codec: ff-h264 09:54:48.837 T:139793901991680 DEBUG: VAAPI - open decoder 09:54:48.837 T:139793647957760 DEBUG: Thread Vaapi-Output start, auto delete: false 09:54:48.837 T:139793647957760 NOTICE: COutput::OnStartup: Output Thread created 09:54:48.847 T:139793825412864 DEBUG: CDVDAudio::Pause - pausing audio stream 09:54:48.859 T:139793647957760 DEBUG: VAAPI::COutput::CreateEGLContext - created context 09:54:48.863 T:139793647957760 DEBUG: VAAPI::COutput::InitBufferPool - Surfaces created 09:54:48.863 T:139793901991680 DEBUG: CDVDVideoCodecFFmpeg - Updated codec: ff-h264-vaapi 09:54:48.864 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:48.865 T:139793901991680 DEBUG: Previous line repeats 1 times. 09:54:48.865 T:139793901991680 WARNING: CVideoSurfaces::ClearReference - surface invalid 09:54:48.865 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:48.876 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:48.876 T:139797137131904 NOTICE: VAAPI::Close 09:54:48.877 T:139793817020160 NOTICE: COutput::OnExit: Output Thread terminated 09:54:48.877 T:139793817020160 DEBUG: Thread Vaapi-Output 139793817020160 terminating 09:54:48.877 T:139797137131904 DEBUG: VAAPI::FiniVAAPIOutput destroying 2 video surfaces 09:54:48.878 T:139793918772992 DEBUG: CVideoPlayer::HandleMessages - player started 1 09:54:48.878 T:139793918772992 DEBUG: CVideoPlayer::HandleMessages - player started 2 09:54:48.878 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 3 09:54:48.878 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:48.878 T:139793918772992 DEBUG: CVideoPlayer::SetCaching - caching state 0 09:54:48.878 T:139793918772992 DEBUG: CDVDClock::SetSpeedAdjust - adjusted:0.000000 09:54:48.878 T:139793918772992 DEBUG: VideoPlayer::Sync - Audio - pts: 309536000.000000, cache: 287166.947464, totalcache: 550000.011921 09:54:48.878 T:139793918772992 DEBUG: VideoPlayer::Sync - Video - pts: 309267000.000000, cache: 50000.000000, totalcache: 100000.000000 09:54:48.878 T:139793901991680 DEBUG: CVideoPlayerVideo - CDVDMsg::GENERAL_RESYNC(309167000.000000) 09:54:48.878 T:139793825412864 DEBUG: CVideoPlayerAudio - CDVDMsg::GENERAL_RESYNC(309167000.000000) 09:54:48.878 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:48.878 T:139793825412864 DEBUG: CDVDAudio::Resume - resume audio stream 09:54:48.878 T:139793901991680 DEBUG: CVideoPlayerVideo::CalcDropRequirement - hurry: 0 09:54:48.884 T:139796487857920 DEBUG: Previous line repeats 3 times. 09:54:48.884 T:139796487857920 DEBUG: ActiveAE - start sync of audio stream 09:54:49.026 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error of 70.196827, start adjusting 09:54:49.026 T:139796487857920 DEBUG: ActiveAE::SyncStream - average error 20.196827 below threshold of 30.000000 09:54:51.706 T:139797137131904 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------ 09:54:51.706 T:139797137131904 DEBUG: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------ 09:54:53.709 T:139793901991680 DEBUG: CPullupCorrection: detected pattern of length 1: 41708.33, frameduration: 41708.333333 09:54:56.585 T:139797137131904 DEBUG: LIRC: Update - NEW at 33290694:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:54:56.585 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is OSD 09:54:56.585 T:139797137131904 DEBUG: ------ Window Init (VideoOSD.xml) ------ 09:54:56.585 T:139797137131904 INFO: Loading skin file: VideoOSD.xml, load type: KEEP_IN_MEMORY 09:54:56.596 T:139797137131904 DEBUG: ------ Window Init (DialogSeekBar.xml) ------ 09:54:56.596 T:139797137131904 DEBUG: ------ Window Init (Custom_1109_TopBarOverlay.xml) ------ 09:54:57.753 T:139797137131904 DEBUG: LIRC: Update - NEW at 33291862:0000000000000cd0 00 KEY_RIGHT sonyarrow (KEY_RIGHT) 09:54:57.753 T:139797137131904 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right 09:54:58.337 T:139797137131904 DEBUG: LIRC: Update - NEW at 33292446:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:54:58.337 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 09:54:58.337 T:139797137131904 NOTICE: CVideoPlayer::CloseFile() 09:54:58.338 T:139797137131904 NOTICE: VideoPlayer: waiting for threads to exit 09:54:58.342 T:139793918772992 NOTICE: CVideoPlayer::OnExit() 09:54:58.342 T:139793918772992 NOTICE: Closing stream player 1 09:54:58.342 T:139793918772992 NOTICE: Waiting for audio thread to exit 09:54:58.399 T:139793825412864 NOTICE: thread end: CVideoPlayerAudio::OnExit() 09:54:58.399 T:139793825412864 DEBUG: Thread VideoPlayerAudio 139793825412864 terminating 09:54:58.399 T:139793918772992 NOTICE: Closing audio device 09:54:58.460 T:139793918772992 DEBUG: CDVDAudio::Flush - flush audio stream 09:54:58.460 T:139796487857920 DEBUG: CActiveAE::DiscardStream - audio stream deleted 09:54:58.460 T:139796487857920 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted 09:54:58.460 T:139793918772992 DEBUG: Previous line repeats 2 times. 09:54:58.460 T:139793918772992 NOTICE: Deleting audio codec 09:54:58.460 T:139796554970880 INFO: CActiveAESink::OpenSink - initialize sink 09:54:58.460 T:139793918772992 NOTICE: Closing stream player 2 09:54:58.460 T:139793918772992 NOTICE: waiting for video thread to exit 09:54:58.486 T:139793901991680 NOTICE: thread end: video_thread 09:54:58.486 T:139793901991680 DEBUG: Thread VideoPlayerVideo 139793901991680 terminating 09:54:58.486 T:139793918772992 NOTICE: deleting video codec 09:54:58.487 T:139793918772992 DEBUG: VAAPI::Release pre-cleanup 09:54:58.487 T:139793918772992 NOTICE: Closing stream player 3 09:54:58.487 T:139794231305984 DEBUG: Thread FileCache 139794231305984 terminating 09:54:58.494 T:139793918772992 DEBUG: OnPlayBackStopped: play state was 2, starting 0 09:54:58.494 T:139793918772992 DEBUG: Thread VideoPlayer 139793918772992 terminating 09:54:58.494 T:139797137131904 NOTICE: VideoPlayer: finished waiting 09:54:58.494 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc 09:54:58.494 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop 09:54:58.495 T:139797137131904 DEBUG: DeleteRenderer - deleting renderer 09:54:58.495 T:139797137131904 NOTICE: VAAPI::Close 09:54:58.496 T:139793647957760 NOTICE: COutput::OnExit: Output Thread terminated 09:54:58.497 T:139793647957760 DEBUG: Thread Vaapi-Output 139793647957760 terminating 09:54:58.497 T:139797137131904 DEBUG: VAAPI::FiniVAAPIOutput destroying 5 video surfaces 09:54:58.497 T:139797137131904 NOTICE: VAAPI::Close - closing decoder context 09:54:58.497 T:139797137131904 DEBUG: LinuxRendererGL: Cleaning up GL resources 09:54:58.497 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:54:58.497 T:139797137131904 DEBUG: ------ Window Deinit (VideoOSD.xml) ------ 09:54:58.497 T:139797137131904 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------ 09:54:58.500 T:139797137131904 NOTICE: CWinSystemX11::SetFullScreen - calling xrandr 09:54:58.500 T:139797137131904 DEBUG: OnLostDevice - notify display change event 09:54:58.646 T:139796554970880 DEBUG: CActiveAESink::OpenSink - trying to open device PULSE:Default 09:54:58.650 T:139796554970880 DEBUG: PulseAudio: Context authorizing 09:54:58.651 T:139796554970880 DEBUG: PulseAudio: Context setting name 09:54:58.651 T:139796554970880 DEBUG: PulseAudio: Context ready 09:54:58.669 T:139796554970880 DEBUG: PulseAudio: Stream ready 09:54:58.670 T:139796554970880 NOTICE: PulseAudio: Opened device Default in pcm mode with Buffersize 150 ms 09:54:58.672 T:139796554970880 DEBUG: CActiveAESink::OpenSink - PULSE Initialized: 09:54:58.672 T:139796554970880 DEBUG: Output Device : Default 09:54:58.672 T:139796554970880 DEBUG: Sample Rate : 44100 09:54:58.672 T:139796554970880 DEBUG: Sample Format : AE_FMT_FLOAT 09:54:58.672 T:139796554970880 DEBUG: Channel Count : 2 09:54:58.672 T:139796554970880 DEBUG: Channel Layout: FL,FR 09:54:58.672 T:139796554970880 DEBUG: Frames : 2205 09:54:58.672 T:139796554970880 DEBUG: Frame Size : 8 09:54:58.674 T:139796487857920 DEBUG: CActiveAE::ClearDiscardedBuffers - buffer pool deleted 09:54:58.674 T:139797137131904 DEBUG: Previous line repeats 1 times. 09:54:58.674 T:139797137131904 NOTICE: VideoPlayer: OnLostDisplay received 09:54:58.674 T:139797137131904 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED 09:54:58.674 T:139797137131904 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED 09:54:58.674 T:139797137131904 INFO: XRANDR: /usr/lib/x86_64-linux-gnu/kodi/kodi-xrandr --screen 0 --output DP-1 --mode 0x49 09:54:59.079 T:139797137131904 INFO: GL: Maximum texture width: 16384 09:54:59.121 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 09:54:59.126 T:139797137131904 DEBUG: ------ Window Init (MyVideoNav.xml) ------ 09:54:59.127 T:139797137131904 DEBUG: CGUIMediaWindow::GetDirectory (videodb://inprogresstvshows/60/-2/?tvshowid=60) 09:54:59.127 T:139797137131904 DEBUG: ParentPath = [videodb://inprogresstvshows/60/-2/?tvshowid=60] 09:54:59.132 T:139797137131904 DEBUG: RunQuery took 1 ms for 17 items query: select * from episode_view WHERE episode_view.idShow = 60 09:54:59.134 T:139797137131904 DEBUG: RunQuery took 1 ms for 0 items query: select * from movie_view join movielinktvshow on movielinktvshow.idMovie=movie_view.idMovie WHERE movielinktvshow.idShow = 60 09:54:59.137 T:139797137131904 DEBUG: WindowVideoNav::GetDirectory 09:54:59.144 T:139793639565056 DEBUG: Thread BackgroundLoader start, auto delete: false 09:54:59.149 T:139793639565056 DEBUG: Thread BackgroundLoader 139793639565056 terminating 09:54:59.151 T:139796315870976 NOTICE: EMBY.player -> Played_information: {'{emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token}': {'currentfile': '{emby-server}/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key={emby-token}', 'SubtitleStreamIndex': 2, 'playsession_id': u'1426fa4ddfcb49f6882fe33b75e6eac0', 'AudioStreamIndex': 1, 'mediasource_id': u'2d5ece82ee7607f988e511f89e671aa5', 'item_id': u'2d5ece82ee7607f988e511f89e671aa5', 'Type': u'Episode', 'playmethod': u'DirectStream', 'refresh_id': u'10d903bc66e8f180de73ac0d471e9712', 'currentPosition': 318.22900390625, 'runtime': 12766400512}} 09:54:59.152 T:139796315870976 NOTICE: EMBY.player -> stop playback called. 09:54:59.189 T:139793639565056 DEBUG: Thread JobWorker start, auto delete: true 09:54:59.207 T:139796315870976 NOTICE: EMBY.player -> Percent complete: 0.24927073501 Mark played at: 0.9 09:54:59.208 T:139796315870976 ERROR: GetDirectory - Error getting /root/.kodi/userdata/addon_data/plugin.video.emby/temp/ 09:54:59.238 T:139797137131904 DEBUG: ------ Window Deinit (DialogSeekBar.xml) ------ 09:54:59.238 T:139797137131904 DEBUG: ------ Window Deinit (Custom_1109_TopBarOverlay.xml) ------ 09:54:59.238 T:139797137131904 NOTICE: CVideoPlayer::CloseFile() 09:54:59.238 T:139797137131904 NOTICE: VideoPlayer: waiting for threads to exit 09:54:59.238 T:139797137131904 NOTICE: VideoPlayer: finished waiting 09:54:59.238 T:139797137131904 NOTICE: CVideoPlayer::CloseFile() 09:54:59.238 T:139797137131904 NOTICE: VideoPlayer: waiting for threads to exit 09:54:59.238 T:139797137131904 NOTICE: VideoPlayer: finished waiting 09:54:59.239 T:139797137131904 DEBUG: Radio UECP (RDS) Processor - delete ~CDVDRadioRDSData 09:54:59.921 T:139796345247488 DEBUG: Thread RefClock 139796345247488 terminating 09:54:59.922 T:139793639565056 DEBUG: DoWork - Saving file state for video item https://mydomain.com:443/emby/Videos/2d5ece82ee7607f988e511f89e671aa5/stream?static=true&MediaSourceId=2d5ece82ee7607f988e511f89e671aa5&PlaySessionId=1426fa4ddfcb49f6882fe33b75e6eac0&api_key=d4d8e28fbd434183885b956615379c45 09:54:59.922 T:139797137131904 DEBUG: NotifyXRREvent - notify display reset event 09:54:59.950 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnUpdate from xbmc 09:54:59.950 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnUpdate 09:54:59.959 T:139796638000896 DEBUG: CAnnouncementManager - Announcement: OnUpdate from xbmc 09:54:59.959 T:139796638000896 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnUpdate 09:55:00.114 T:139797137131904 DEBUG: RecreateWindow - current output: DP-1, mode: 0x49, refresh: 30.000 09:55:00.114 T:139797137131904 DEBUG: OnLostDevice - notify display change event 09:55:00.126 T:139797137131904 DEBUG: Window Manager Name: Compiz 09:55:00.139 T:139797137131904 DEBUG: CWinSystemX11::RefreshEGLContext: refreshing context 09:55:00.176 T:139797137131904 INFO: GL: Maximum texture width: 16384 09:55:00.181 T:139796315870976 NOTICE: EMBY.kodimonitor -> Method: VideoLibrary.OnUpdate Data: {"item":{"id":2200,"type":"episode"}} 09:55:00.186 T:139796315870976 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/emby.db - 139796306084584 09:55:00.188 T:139796315870976 NOTICE: EMBY.database -> Verifying emby DB 09:55:00.191 T:139797137131904 INFO: GL: Enabling VSYNC 09:55:00.192 T:139796315870976 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/emby.db - 139796306084584 09:55:00.221 T:139796315870976 NOTICE: EMBY.kodimonitor -> Method: VideoLibrary.OnUpdate Data: {"id":2200,"type":"episode"} 09:55:00.232 T:139796315870976 NOTICE: EMBY.kodimonitor -> Item is invalid for playstate update 09:55:02.318 T:139797137131904 DEBUG: LIRC: Update - NEW at 33296427:00000000000002f0 00 KEY_UP sonyarrow (KEY_UP) 09:55:02.318 T:139797137131904 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up 09:55:04.810 T:139797137131904 DEBUG: LIRC: Update - NEW at 33298919:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:55:04.810 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 09:55:04.810 T:139797137131904 DEBUG: CGUIMediaWindow::GetDirectory (videodb://inprogresstvshows/60/) 09:55:04.810 T:139797137131904 DEBUG: ParentPath = [videodb://inprogresstvshows/] 09:55:04.842 T:139796302464768 DEBUG: RunQuery took 26 ms for 1 items query: SELECT * FROM season_view WHERE season_view.idShow = 60 09:55:04.843 T:139796302464768 DEBUG: RunQuery took 1 ms for 0 items query: select * from movie_view join movielinktvshow on movielinktvshow.idMovie=movie_view.idMovie WHERE movielinktvshow.idShow = 60 09:55:04.848 T:139797137131904 DEBUG: CGUIMediaWindow::GetDirectory (videodb://inprogresstvshows/60/-2/?tvshowid=60) 09:55:04.848 T:139797137131904 DEBUG: ParentPath = [videodb://inprogresstvshows/] 09:55:04.850 T:139793639565056 DEBUG: RunQuery took 0 ms for 17 items query: select * from episode_view WHERE episode_view.idShow = 60 09:55:04.852 T:139793639565056 DEBUG: RunQuery took 0 ms for 0 items query: select * from movie_view join movielinktvshow on movielinktvshow.idMovie=movie_view.idMovie WHERE movielinktvshow.idShow = 60 09:55:04.856 T:139797137131904 DEBUG: WindowVideoNav::GetDirectory 09:55:04.862 T:139796345247488 DEBUG: Thread BackgroundLoader start, auto delete: false 09:55:04.871 T:139796345247488 DEBUG: Thread BackgroundLoader 139796345247488 terminating 09:55:10.461 T:139797137131904 DEBUG: LIRC: Update - NEW at 33304569:00000000000002f0 00 KEY_UP sonyarrow (KEY_UP) 09:55:10.461 T:139797137131904 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up 09:55:11.232 T:139797137131904 DEBUG: LIRC: Update - NEW at 33305341:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:55:11.232 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 09:55:11.233 T:139797137131904 DEBUG: CGUIMediaWindow::GetDirectory (videodb://inprogresstvshows/) 09:55:11.233 T:139797137131904 DEBUG: ParentPath = [] 09:55:11.260 T:139796302464768 DEBUG: RunQuery took 19 ms for 20 items query: SELECT * FROM tvshow_view WHERE watchedCount != 0 AND totalCount != watchedCount ORDER BY c00 09:55:11.263 T:139796345247488 DEBUG: Thread BackgroundLoader start, auto delete: false 09:55:11.276 T:139796345247488 DEBUG: Thread BackgroundLoader 139796345247488 terminating 09:55:11.281 T:139793639565056 ERROR: DoWork - Direct texture file loading failed for resource://resource.images.studios.white/FOX.png 09:55:11.281 T:139793639565056 DEBUG: GetImageHash - unable to stat url resource://resource.images.studios.white/FOX.png 09:55:14.222 T:139797137131904 DEBUG: LIRC: Update - NEW at 33308331:00000000000002e9 00 KEY_BACK sonymedia (KEY_BACK) 09:55:14.222 T:139797137131904 DEBUG: OnKey: menu (0xd8) pressed, action is Back 09:55:14.222 T:139797137131904 DEBUG: CGUIMediaWindow::GetDirectory () 09:55:14.222 T:139797137131904 DEBUG: ParentPath = [] 09:55:14.234 T:139796345247488 DEBUG: Thread BackgroundLoader start, auto delete: false 09:55:14.242 T:139796345247488 DEBUG: Thread BackgroundLoader 139796345247488 terminating 09:55:14.545 T:139797137131904 DEBUG: LIRC: Update - NEW at 33308654:00000000000002e9 00 KEY_BACK sonymedia (KEY_BACK) 09:55:14.545 T:139797137131904 DEBUG: OnKey: menu (0xd8) pressed, action is Back 09:55:14.546 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:55:14.879 T:139797137131904 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------ 09:55:14.880 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Activate new 09:55:14.880 T:139797137131904 DEBUG: ------ Window Init (Home.xml) ------ 09:55:14.880 T:139797137131904 DEBUG: CDirectoryProvider[special://skin/playlists/inprogress_movies.xsp]: refreshing.. 09:55:14.880 T:139797137131904 DEBUG: CDirectoryProvider[special://skin/playlists/recent_unwatched_movies.xsp]: refreshing.. 09:55:14.881 T:139797137131904 DEBUG: CDirectoryProvider[special://skin/playlists/unwatched_movies.xsp]: refreshing.. 09:55:14.881 T:139797137131904 DEBUG: CDirectoryProvider[special://skin/playlists/random_movies.xsp]: refreshing.. 09:55:14.882 T:139796345247488 DEBUG: Thread JobWorker start, auto delete: true 09:55:14.882 T:139797137131904 DEBUG: CDirectoryProvider[videodb://movies/genres/]: refreshing.. 09:55:14.882 T:139797137131904 DEBUG: CDirectoryProvider[videodb://inprogresstvshows]: refreshing.. 09:55:14.882 T:139797137131904 DEBUG: CDirectoryProvider[special://skin/playlists/recent_unwatched_episodes.xsp]: refreshing.. 09:55:14.882 T:139797137131904 DEBUG: CDirectoryProvider[special://skin/playlists/unwatched_tvshows.xsp]: refreshing.. 09:55:14.882 T:139797137131904 DEBUG: CDirectoryProvider[videodb://tvshows/genres/]: refreshing.. 09:55:14.882 T:139797137131904 DEBUG: CDirectoryProvider[videodb://tvshows/studios/]: refreshing.. 09:55:14.884 T:139797137131904 DEBUG: CDirectoryProvider[addons://sources/video/]: refreshing.. 09:55:14.884 T:139797137131904 DEBUG: CDirectoryProvider[addons://sources/audio/]: refreshing.. 09:55:14.884 T:139797137131904 DEBUG: CDirectoryProvider[addons://sources/executable/]: refreshing.. 09:55:14.884 T:139797137131904 DEBUG: CDirectoryProvider[addons://sources/image/]: refreshing.. 09:55:14.885 T:139797137131904 DEBUG: CDirectoryProvider[special://videoplaylists/]: refreshing.. 09:55:14.885 T:139797137131904 DEBUG: CDirectoryProvider[pvr://channels/tv/*?view=lastplayed]: refreshing.. 09:55:14.885 T:139797137131904 DEBUG: CDirectoryProvider[pvr://channels/radio/*?view=lastplayed]: refreshing.. 09:55:14.909 T:139793639565056 DEBUG: RunQuery took 2 ms for 52 items query: select * from movie_view WHERE ((movie_view.dateAdded > '1900-01-01')) AND ((movie_view.playCount IS NULL OR movie_view.playCount < 1)) 09:55:14.909 T:139796302464768 DEBUG: RunQuery took 2 ms for 11 items query: select * from movie_view WHERE (movie_view.idFile IN (SELECT DISTINCT idFile FROM bookmark WHERE type = 1)) 09:55:14.910 T:139796345247488 DEBUG: RunQuery took 3 ms for 52 items query: select * from movie_view WHERE ((movie_view.playCount IS NULL OR movie_view.playCount = 0)) 09:55:14.932 T:139797137131904 DEBUG: LIRC: Update - NEW at 33309041:00000000000002e9 00 KEY_BACK sonymedia (KEY_BACK) 09:55:14.932 T:139797137131904 DEBUG: OnKey: menu (0xd8) pressed, action is Back 09:55:14.933 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:55:14.941 T:139796302464768 DEBUG: RunQuery took 2 ms for 68 items query: select * from movie_view 09:55:14.944 T:139796345247488 DEBUG: RunQuery took 2 ms for 21 items query: SELECT genre.genre_id, genre.name, count(1), count(files.playCount) FROM genre JOIN genre_link ON genre.genre_id = genre_link.genre_id JOIN movie_view ON genre_link.media_id = movie_view.idMovie AND genre_link.media_type='movie' JOIN files ON files.idFile = movie_view.idFile GROUP BY genre.genre_id 09:55:14.951 T:139797137131904 DEBUG: LIRC: Update - NEW at 33309060:00000000000002e9 00 KEY_BACK sonymedia (KEY_BACK) 09:55:14.951 T:139797137131904 DEBUG: OnKey: menu (0xd8) pressed, action is Back 09:55:14.952 T:139797137131904 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate 09:55:14.965 T:139793639565056 DEBUG: RunQuery took 19 ms for 20 items query: SELECT * FROM tvshow_view WHERE watchedCount != 0 AND totalCount != watchedCount ORDER BY c00 09:55:14.973 T:139796345247488 DEBUG: RunQuery took 7 ms for 763 items query: select * from episode_view WHERE ((episode_view.dateAdded > '1900-01-01')) AND ((episode_view.playCount IS NULL OR episode_view.playCount < 1)) 09:55:14.982 T:139796302464768 DEBUG: RunQuery took 9 ms for 14 items query: SELECT * FROM tvshow_view WHERE ((tvshow_view.watchedcount = 0)) AND ((tvshow_view.totalCount > 0)) 09:55:14.988 T:139793639565056 DEBUG: RunQuery took 14 ms for 17 items query: SELECT genre.genre_id, genre.name FROM genre JOIN genre_link ON genre.genre_id = genre_link.genre_id JOIN tvshow_view ON genre_link.media_id = tvshow_view.idShow AND genre_link.media_type='tvshow' GROUP BY genre.genre_id 09:55:15.024 T:139793639565056 DEBUG: RunQuery took 16 ms for 25 items query: SELECT studio.studio_id, studio.name FROM studio JOIN studio_link ON studio.studio_id = studio_link.studio_id JOIN tvshow_view ON studio_link.media_id = tvshow_view.idShow AND studio_link.media_type='tvshow' GROUP BY studio.studio_id 09:55:15.039 T:139796345247488 DEBUG: CMultiPathDirectory::GetDirectory(multipath://special%3a%2f%2fprofile%2fplaylists%2fvideo/special%3a%2f%2fprofile%2fplaylists%2fmixed/) 09:55:15.039 T:139796345247488 DEBUG: Getting Directory (special://profile/playlists/video) 09:55:15.039 T:139796345247488 DEBUG: Getting Directory (special://profile/playlists/mixed) 09:55:15.040 T:139796345247488 DEBUG: CMultiPathDirectory::MergeItems, items = 2 09:55:15.040 T:139796345247488 DEBUG: Testing path: [000] special://profile/playlists/video/Emby f137a2dd21bbc1b99aa5c0f6bf02a805.xsp 09:55:15.040 T:139796345247488 DEBUG: CMultiPathDirectory::MergeItems, items = 2, took 1 ms 09:55:15.041 T:139793639565056 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/tv/*?view=lastplayed) 09:55:15.042 T:139796345247488 DEBUG: CPVRDirectory::GetDirectory(pvr://channels/radio/*?view=lastplayed) 09:55:15.070 T:139797137131904 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture 'DefaultStudio.png' 09:55:16.074 T:139797137131904 DEBUG: Previous line repeats 5 times. 09:55:16.074 T:139797137131904 DEBUG: LIRC: Update - NEW at 33310182:00000000000002d0 00 KEY_LEFT sonyarrow (KEY_LEFT) 09:55:16.074 T:139797137131904 DEBUG: OnKey: 169 (0xa9, obc86) pressed, action is Left 09:55:19.103 T:139797137131904 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/libsse4-x86_64-linux.so) 09:55:20.484 T:139797137131904 DEBUG: LIRC: Update - NEW at 33314593:00000000000002f0 00 KEY_UP sonyarrow (KEY_UP) 09:55:20.484 T:139797137131904 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up 09:55:20.498 T:139793918772992 DEBUG: Thread JobWorker start, auto delete: true 09:55:20.814 T:139797137131904 DEBUG: LIRC: Update - NEW at 33314922:00000000000002f0 00 KEY_UP sonyarrow (KEY_UP) 09:55:20.814 T:139797137131904 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up 09:55:21.454 T:139797137131904 DEBUG: LIRC: Update - NEW at 33315562:0000000000000cd0 00 KEY_RIGHT sonyarrow (KEY_RIGHT) 09:55:21.454 T:139797137131904 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right 09:55:22.046 T:139797137131904 DEBUG: LIRC: Update - NEW at 33316155:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:55:22.047 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 09:55:22.047 T:139797137131904 DEBUG: Activating window ID: 10004 09:55:22.411 T:139797137131904 DEBUG: ------ Window Deinit (Home.xml) ------ 09:55:22.412 T:139797137131904 DEBUG: ------ Window Init (Settings.xml) ------ 09:55:24.612 T:139797137131904 DEBUG: LIRC: Update - NEW at 33318721:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:55:24.612 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 09:55:24.613 T:139797137131904 DEBUG: Activating window ID: 10016 09:55:24.946 T:139797137131904 DEBUG: ------ Window Deinit (Settings.xml) ------ 09:55:24.946 T:139797137131904 DEBUG: ------ Window Init (SettingsCategory.xml) ------ 09:55:26.359 T:139797137131904 DEBUG: LIRC: Update - NEW at 33320468:0000000000000cd0 00 KEY_RIGHT sonyarrow (KEY_RIGHT) 09:55:26.359 T:139797137131904 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right 09:55:27.111 T:139797137131904 DEBUG: LIRC: Update - NEW at 33321220:00000000000002d0 00 KEY_LEFT sonyarrow (KEY_LEFT) 09:55:27.112 T:139797137131904 DEBUG: OnKey: 169 (0xa9, obc86) pressed, action is Left 09:55:27.654 T:139797137131904 DEBUG: LIRC: Update - NEW at 33321763:0000000000000af0 00 KEY_DOWN sonyarrow (KEY_DOWN) 09:55:27.654 T:139797137131904 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down 09:55:27.943 T:139797137131904 DEBUG: LIRC: Update - NEW at 33322052:0000000000000af0 00 KEY_DOWN sonyarrow (KEY_DOWN) 09:55:27.943 T:139797137131904 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down 09:55:28.988 T:139797137131904 INFO: CheckIdle - Closing session to https://mydomain.com (easy=0x7a63ee0, multi=0x7f24a40037c0) 09:55:28.998 T:139797137131904 INFO: CheckIdle - Closing session to https://mydomain.com (easy=0x7f245071e2e0, multi=0x7f2450727100) 09:55:29.645 T:139797137131904 DEBUG: LIRC: Update - NEW at 33323754:0000000000000af0 00 KEY_DOWN sonyarrow (KEY_DOWN) 09:55:29.645 T:139797137131904 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down 09:55:29.950 T:139797137131904 DEBUG: LIRC: Update - NEW at 33324059:0000000000000af0 00 KEY_DOWN sonyarrow (KEY_DOWN) 09:55:29.950 T:139797137131904 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down 09:55:30.161 T:139797137131904 DEBUG: LIRC: Update - NEW at 33324270:0000000000000af0 00 KEY_DOWN sonyarrow (KEY_DOWN) 09:55:30.161 T:139797137131904 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down 09:55:30.646 T:139797137131904 DEBUG: LIRC: Update - NEW at 33324754:0000000000000af0 00 KEY_DOWN sonyarrow (KEY_DOWN) 09:55:30.646 T:139797137131904 DEBUG: OnKey: 167 (0xa7, obc88) pressed, action is Down 09:55:31.430 T:139797137131904 DEBUG: LIRC: Update - NEW at 33325538:0000000000000cd0 00 KEY_RIGHT sonyarrow (KEY_RIGHT) 09:55:31.430 T:139797137131904 DEBUG: OnKey: 168 (0xa8, obc87) pressed, action is Right 09:55:32.079 T:139797137131904 DEBUG: LIRC: Update - NEW at 33326187:0000000000000a70 00 KEY_ENTER sonyarrow (KEY_ENTER) 09:55:32.079 T:139797137131904 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select 09:55:32.079 T:139797137131904 NOTICE: Disabled debug logging due to GUI setting. Level 0. 09:55:32.079 T:139797137131904 NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
theghost31 4 Posted May 7, 2018 Posted May 7, 2018 I'm sorry, I can see it's too huge to show that in a message but everytime I want to edit my message, the edit feature of the forum is crashing :/If you want to delete the log, let me know, I will write it with an other way if it's necessary Thank you in advance
Angelblue05 4132 Posted May 7, 2018 Posted May 7, 2018 I don't see any server event which makes me think the add-on is unable to connect to your server websocket. But that is something that would show in the beginning of the log. The calls are made to wss://{server}/embywebsocket
theghost31 4 Posted May 7, 2018 Posted May 7, 2018 (edited) Here you have the wss. I just restarted Kodi : 10:31:09.383 T:140091602196224 NOTICE: EMBY.librarysync -> ---===### Starting LibrarySync ###===--- 10:31:09.386 T:140091612714752 NOTICE: EMBY.websocket_client -> websocket url: wss://mydomain.com:443/embywebsocket?api_key={emby-token}&deviceId=2D2CCDB4F1AE4F10AFF205D85547F9B3 10:31:09.388 T:140091602196224 NOTICE: EMBY.utils -> verifying advanced settings 10:31:09.390 T:140091612714752 NOTICE: EMBY.websocket_client -> ----===## Starting WebSocketClient ##===---- 10:31:09.393 T:140091602196224 NOTICE: EMBY.librarysync -> Doing DB Version Check 10:31:09.394 T:140091602196224 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/emby.db - 140092169701464 10:31:09.396 T:140091602196224 NOTICE: EMBY.database -> Verifying emby DB 10:31:09.398 T:140091602196224 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/emby.db - 140092169701464 10:31:09.399 T:140091602196224 NOTICE: EMBY.librarysync -> current: 3.0.22 minimum: 1.1.63 10:31:09.400 T:140091602196224 NOTICE: EMBY.librarysync -> Database version: 3.0.22 10:31:09.402 T:140091602196224 NOTICE: EMBY.librarysync -> SyncDatabase (started) 10:31:09.410 T:140091602196224 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/emby.db - 140092169701232 10:31:09.413 T:140091602196224 NOTICE: EMBY.database -> Verifying emby DB 10:31:09.419 T:140091602196224 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/MyVideos107.db - 140092169701696 10:31:09.494 T:140091602196224 NOTICE: EMBY.views -> sorted views: [u'Movies', u'TV Shows'] 10:31:09.496 T:140091602196224 NOTICE: EMBY.views -> Clearing nodes properties. 10:31:09.659 T:140091602196224 NOTICE: EMBY.views -> Removing views: [] 10:31:09.661 T:140091602196224 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/MyVideos107.db - 140092169701696 10:31:09.663 T:140091602196224 NOTICE: EMBY.database -> number of rows updated: 2 10:31:09.674 T:140091602196224 NOTICE: EMBY.database -> commit: /root/.kodi/userdata/Database/emby.db 10:31:09.679 T:140091602196224 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/emby.db - 140092169701232 10:31:10.919 T:140091602196224 NOTICE: EMBY.connectionmanager -> Begin ConnectionManager constructor 10:31:10.924 T:140091602196224 NOTICE: EMBY.utils -> Toggling screensaver: {u'jsonrpc': u'2.0', u'id': 1, u'result': True} 10:31:10.934 T:140091602196224 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/emby.db - 140092169701696 10:31:10.936 T:140091602196224 NOTICE: EMBY.database -> Verifying emby DB 10:31:10.940 T:140091602196224 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/MyVideos107.db - 140092169701232 10:31:11.056 T:140091602196224 NOTICE: EMBY.views -> sorted views: [u'Movies', u'TV Shows'] 10:31:11.058 T:140091602196224 NOTICE: EMBY.views -> Clearing nodes properties. 10:31:11.236 T:140091602196224 NOTICE: EMBY.views -> Removing views: [] 10:31:11.261 T:140091602196224 NOTICE: EMBY.objects.movies -> Media folders: [{'id': u'f137a2dd21bbc1b99aa5c0f6bf02a805', 'mediatype': 'movies', 'name': u'Movies'}] 10:31:11.297 T:140091602196224 NOTICE: EMBY.read_embyserver -> Waiting for empty download spot: 3 10:31:11.565 T:140091602196224 NOTICE: EMBY.objects._common -> Update for Movies: [] 10:31:11.572 T:140093672814336 ERROR: ADDON: Dll NextPVR PVR Client - Client returned bad status (1) from Create and is not usable 10:31:11.573 T:140091602196224 NOTICE: EMBY.objects._common -> Update for BoxSet: [] 10:31:11.576 T:140091602196224 NOTICE: EMBY.librarysync -> SyncDatabase (finished movies in: 0:00:00) 10:31:11.600 T:140091602196224 NOTICE: EMBY.librarysync -> SyncDatabase (finished boxsets in: 0:00:00) 10:31:11.604 T:140091602196224 NOTICE: EMBY.objects.musicvideos -> Media folders: [] 10:31:11.604 T:140091602196224 NOTICE: EMBY.librarysync -> SyncDatabase (finished musicvideos in: 0:00:00) 10:31:11.612 T:140091602196224 NOTICE: EMBY.objects.tvshows -> Media folders: [{'id': u'767bffe4f11c93ef34b805451a696a4e', 'mediatype': 'tvshows', 'name': u'TV Shows'}] 10:31:11.616 T:140091602196224 NOTICE: EMBY.objects.tvshows -> all_koditvshows = {u'bc28bc598ab114734909996ac5ae0579': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse010', u'5b57535669962e86aee1c1c0ca3675e4': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'317355bbecbefea5c4c27191f23f78e3': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse020', u'0fe6b7ece289feebc313ee08bbad0f28': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'e7f86c9b683213653ca956df6c70e926': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'105375846eb8bbf4f50888a6f3d029f4': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse010', u'7a4493df926c131b16fd6cab5fac3b0e': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse01', u'bde1e147c9415971750aa0a348f1ace2': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'e84470b3b08325a18c7f2cf7b98b04af': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'54fc00a5e99e36dbbaee680b7adfc517': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse06', u'd5d86e65163e2fee07d37389c04f60df': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse010', u'923dc032858c586a3e413f3083946099': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse020', u'56d04a3c57c6418a7f304688f28758b3': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse010', u'49ddc41b68f347be5189de0d8c31ebb8': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse0158', u'7d66f7b30ddd2fd0eeeb69595fea7ab7': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse063', u'5661637b03a59115da23570faff6bd1d': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'd298b2519c39472a72d656458123d696': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse016', u'601702459a20236785f4afef8242bf05': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'a181d2f42decdc8a8ae4e8c49e4817ce': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'94838961e77759b268138a2c00bd290d': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'3d6532f20508319a93d291d5e8a4ef80': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse08', u'1ff7c123dbc1c8daf1d373023ea629a7': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'124c75fe7f497dcfda33e90112168bd1': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'd93c22a6ab4d0f1db82d29648990470c': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'8e0507b0e3e9cc062c5068f617661835': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse05', u'f1373ddd4911b8c6a15ff99ae912556a': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'56e5785fd195d87345d7470756b31acd': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'942f9e6f3b48750e9d7d7d7c00eef998': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse09', u'53f8d412321095e15fcdfb532aeb910e': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'fd01ac9645c0019c360e8ee061b0d178': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse01', u'9e4fd407b05b0d82a0788121222f60c3': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'0fa837189c3f6f202075faa0ecf88ab5': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse03', u'b98e106b553b8e16e49fab3420725059': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse042', u'4a3d710894b408e9a9c73eea9ddaabab': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse060', u'd07f76481a1e8134c6dcde24b1568d30': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'cb075857a48fce95daddfc50c13175bc': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse04', u'150380ee2e0c9923879767c3b0884839': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'ca08219e12e8f2578c509bced51ca0c7': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'cc9848b327c57195943c0c8878a1d135': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse018', u'447c276d06392e313d66cbfc8da098f4': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'10d903bc66e8f180de73ac0d471e9712': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse05', u'e023065df369a247aaca567003540478': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'95999f05a5eaba032c4f745fc25bde24': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'95bbcac00373bcf7fb0ddb6a4144cf64': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'bb743ae87e57e7c432c87834482494bf': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse05', u'7bd56a040ae886b9bfe99717e5a486b9': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'6c41989438a0dafb993bcf441046b5eb': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse03', u'8a2f81f17f71346960b39535264d751f': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'208079743825dcf72a718ff291448f76': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'199e27cf14697344db994f3c7cd9f8e2': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'1c77eefc12c6825268278ad36100411d': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse09', u'cbc2a3226c33caa684960a61f62556b2': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'f3294f1b3c60af64133779632f905981': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse010', u'76a511dd02b46bc132b31c5ee1024c0d': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'4c7fd9b9eed40e8c1fad758fd220a95f': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'afc8436ba2a9530238b5c8773ff40f64': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse010', u'98e05dd179c4000c483ad6d5398abe8b': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse022', u'10998ff9b746311583e5108bc556aab7': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'a1cbd495934a5da060fcabb381f44e06': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'1feee5b6f75aeccceaa873953534fba1': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'89670e2e53b5289d7b6d6eaac4d5d5b3': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse069', u'fd594e8af5dfe2671f7b6cd56c0bc034': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'8b9080132aa9a1c021b134caf3a860dd': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse08', u'cfce389db626f5ad392da88cce422d2a': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'b773de16b620943c09f6ea0c563531fb': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse015', u'd271f469fa756b5f468305aad2ea7c66': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'f22d5d3933b5dccba06939c58e2b5de0': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse011', u'0914b0acc3df5ce9510997044a830175': u'543b6ca4c9f21c87d81daf7a932499c0TrueFalse00', u'f1544ad4b18ed6bbcb94ec639a3dbd85': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse014', u'956a7bfa9de4cdd1eecd13bcb51c1356': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse0101', u'092d74c6feb57b660ae03cda0e801601': u'543b6ca4c9f21c87d81daf7a932499c0FalseFalse08'} 10:31:11.662 T:140091602196224 NOTICE: EMBY.read_embyserver -> Waiting for empty download spot: 3 10:31:12.087 T:140091602196224 NOTICE: Previous line repeats 1 times. 10:31:12.087 T:140091602196224 NOTICE: EMBY.objects.tvshows -> TVShows to update for TV Shows: [u'10d903bc66e8f180de73ac0d471e9712'] 10:31:12.166 T:140091602196224 NOTICE: EMBY.read_embyserver -> Waiting for empty download spot: 3 10:31:25.579 T:140091602196224 NOTICE: Previous line repeats 76 times. 10:31:25.579 T:140091602196224 NOTICE: EMBY.objects.tvshows -> Episodes to update for TV Shows: [u'2d5ece82ee7607f988e511f89e671aa5'] 10:31:25.613 T:140091602196224 NOTICE: EMBY.objects.tvshows -> episodeid: 2200 fileid: 2268 pathid: 62 10:31:25.619 T:140091602196224 NOTICE: EMBY.objects.tvshows -> UPDATE episode itemid: 2d5ece82ee7607f988e511f89e671aa5 - Title: Fears of a Clown 10:31:25.636 T:140091602196224 NOTICE: EMBY.objects.tvshows -> all_embytvshowsIds = set([u'f3294f1b3c60af64133779632f905981', u'bde1e147c9415971750aa0a348f1ace2', u'bc28bc598ab114734909996ac5ae0579', u'0fe6b7ece289feebc313ee08bbad0f28', u'e7f86c9b683213653ca956df6c70e926', u'105375846eb8bbf4f50888a6f3d029f4', u'10998ff9b746311583e5108bc556aab7', u'5b57535669962e86aee1c1c0ca3675e4', u'e84470b3b08325a18c7f2cf7b98b04af', u'54fc00a5e99e36dbbaee680b7adfc517', u'd5d86e65163e2fee07d37389c04f60df', u'923dc032858c586a3e413f3083946099', u'317355bbecbefea5c4c27191f23f78e3', u'1c77eefc12c6825268278ad36100411d', u'7d66f7b30ddd2fd0eeeb69595fea7ab7', u'5661637b03a59115da23570faff6bd1d', u'd298b2519c39472a72d656458123d696', u'601702459a20236785f4afef8242bf05', u'a181d2f42decdc8a8ae4e8c49e4817ce', u'94838961e77759b268138a2c00bd290d', u'3d6532f20508319a93d291d5e8a4ef80', u'1ff7c123dbc1c8daf1d373023ea629a7', u'124c75fe7f497dcfda33e90112168bd1', u'd93c22a6ab4d0f1db82d29648990470c', u'8e0507b0e3e9cc062c5068f617661835', u'f1373ddd4911b8c6a15ff99ae912556a', u'56e5785fd195d87345d7470756b31acd', u'942f9e6f3b48750e9d7d7d7c00eef998', u'fd01ac9645c0019c360e8ee061b0d178', u'9e4fd407b05b0d82a0788121222f60c3', u'0fa837189c3f6f202075faa0ecf88ab5', u'cbc2a3226c33caa684960a61f62556b2', u'b98e106b553b8e16e49fab3420725059', u'b773de16b620943c09f6ea0c563531fb', u'd07f76481a1e8134c6dcde24b1568d30', u'cb075857a48fce95daddfc50c13175bc', u'7a4493df926c131b16fd6cab5fac3b0e', u'150380ee2e0c9923879767c3b0884839', u'ca08219e12e8f2578c509bced51ca0c7', u'cc9848b327c57195943c0c8878a1d135', u'447c276d06392e313d66cbfc8da098f4', u'10d903bc66e8f180de73ac0d471e9712', u'e023065df369a247aaca567003540478', u'6c41989438a0dafb993bcf441046b5eb', u'95bbcac00373bcf7fb0ddb6a4144cf64', u'bb743ae87e57e7c432c87834482494bf', u'7bd56a040ae886b9bfe99717e5a486b9', u'95999f05a5eaba032c4f745fc25bde24', u'8a2f81f17f71346960b39535264d751f', u'208079743825dcf72a718ff291448f76', u'199e27cf14697344db994f3c7cd9f8e2', u'53f8d412321095e15fcdfb532aeb910e', u'49ddc41b68f347be5189de0d8c31ebb8', u'76a511dd02b46bc132b31c5ee1024c0d', u'4c7fd9b9eed40e8c1fad758fd220a95f', u'afc8436ba2a9530238b5c8773ff40f64', u'98e05dd179c4000c483ad6d5398abe8b', u'fd594e8af5dfe2671f7b6cd56c0bc034', u'a1cbd495934a5da060fcabb381f44e06', u'1feee5b6f75aeccceaa873953534fba1', u'89670e2e53b5289d7b6d6eaac4d5d5b3', u'8b9080132aa9a1c021b134caf3a860dd', u'cfce389db626f5ad392da88cce422d2a', u'092d74c6feb57b660ae03cda0e801601', u'd271f469fa756b5f468305aad2ea7c66', u'f22d5d3933b5dccba06939c58e2b5de0', u'0914b0acc3df5ce9510997044a830175', u'4a3d710894b408e9a9c73eea9ddaabab', u'f1544ad4b18ed6bbcb94ec639a3dbd85', u'956a7bfa9de4cdd1eecd13bcb51c1356', u'56d04a3c57c6418a7f304688f28758b3']) 10:31:25.636 T:140091602196224 NOTICE: EMBY.objects.tvshows -> TVShows compare finished. 10:31:25.638 T:140091602196224 NOTICE: EMBY.objects.tvshows -> Episodes compare finished. 10:31:25.639 T:140091602196224 NOTICE: EMBY.librarysync -> SyncDatabase (finished tvshows in: 0:00:14) 10:31:25.639 T:140091602196224 NOTICE: EMBY.database -> number of rows updated: 19 10:31:25.655 T:140091602196224 NOTICE: EMBY.database -> commit: /root/.kodi/userdata/Database/MyVideos107.db 10:31:25.659 T:140091602196224 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/MyVideos107.db - 140092169701232 10:31:25.665 T:140091602196224 NOTICE: EMBY.database -> number of rows updated: 4 10:31:25.689 T:140091602196224 NOTICE: EMBY.database -> commit: /root/.kodi/userdata/Database/emby.db 10:31:25.692 T:140091602196224 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/emby.db - 140092169701696 10:31:25.697 T:140091602196224 NOTICE: EMBY.database -> opened: /root/.kodi/userdata/Database/emby.db - 140093673915112 10:31:25.701 T:140091602196224 NOTICE: EMBY.database -> Verifying emby DB 10:31:25.703 T:140091602196224 NOTICE: EMBY.database -> number of rows updated: 2 10:31:25.715 T:140091602196224 NOTICE: EMBY.database -> commit: /root/.kodi/userdata/Database/emby.db 10:31:25.717 T:140091602196224 NOTICE: EMBY.database -> closing: /root/.kodi/userdata/Database/emby.db - 140093673915112 10:31:25.722 T:140091602196224 NOTICE: EMBY.librarysync -> New sync time: client time -2 min: 2018-05-07T08:29:25Z 10:31:25.728 T:140091602196224 NOTICE: EMBY.utils -> Toggling screensaver: screensaver.xbmc.builtin.dim {u'jsonrpc': u'2.0', u'id': 1, u'result': True} 10:31:25.732 T:140091602196224 NOTICE: EMBY.librarysync -> SyncDatabase (finished in: 0:00:16) True 10:31:25.778 T:140094193211136 NOTICE: VideoInfoScanner: Starting scan .. 10:31:25.788 T:140094193211136 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00 10:31:25.808 T:140093687183104 NOTICE: EMBY.kodimonitor -> Method: VideoLibrary.OnScanStarted Data: null 10:31:25.810 T:140093687183104 NOTICE: EMBY.kodimonitor -> Kodi library scan video finished 10:31:25.833 T:140093687183104 NOTICE: EMBY.kodimonitor -> Method: VideoLibrary.OnScanFinished Data: null @@Angelblue05, I wrote an edit in the previous message, if you can have a look (quickly) about it . Thank you. (By intel quick shift, I wanted to say: intel quick sync) Edited May 7, 2018 by theghost31
theghost31 4 Posted May 7, 2018 Posted May 7, 2018 (edited) @@Angelblue05. I found the problem. It's resolved !. A clue ? => Nginx conf THank you for your help Ah new bug, I think I will open an issue on this forum. Kodi can't play using the resume button. If Kodi told me resume from 14min 56seconds, even when I click on that, the episode start from the begin :/ Edited May 7, 2018 by theghost31 1
Angelblue05 4132 Posted May 7, 2018 Posted May 7, 2018 Try resetting your database just in case something went wrong. Otherwise, post a new thread I'll look at your log.
theghost31 4 Posted May 8, 2018 Posted May 8, 2018 Hi I already tried but nothing :/This time it's not nginx because even in local, I got this problem So I'm going to create a new thread. I don't know where to create it but I will tag you if it's not a problem for you
Angelblue05 4132 Posted May 9, 2018 Posted May 9, 2018 No problem, just ping me. Thanks. Sent from my iPhone using Tapatalk
theghost31 4 Posted May 9, 2018 Posted May 9, 2018 @@Angelblue05, to help you to find my thread, this is the link. https://emby.media/community/index.php?/topic/58775-resume-button-doesnt-work/&do=findComment&comment=575734 Thank you
