jnrfalcon 1 Posted January 17, 2018 Posted January 17, 2018 I am having trouble accessing via https... http is fine, but when I try https, chrome told me the server unexpectedly closed the connection. I have 8920 forward set in my router, have entered my personal domain in the server settings and the domain is signed by Let's Encrypt with DSM. What else am I missing?
Luke 42241 Posted January 17, 2018 Posted January 17, 2018 First you need to determine if it's an actual connection failure due to router configuration, or if it's a problem with the SSL cert. I would check the Emby Server log to see if there's any incoming traffic over https. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks.
jnrfalcon 1 Posted January 17, 2018 Author Posted January 17, 2018 First you need to determine if it's an actual connection failure due to router configuration, or if it's a problem with the SSL cert. I would check the Emby Server log to see if there's any incoming traffic over https. You can learn how to do that here: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks. Sent you via PM
Luke 42241 Posted January 17, 2018 Posted January 17, 2018 Thanks. I don't see any https traffic in your logs so it would appear to me that the requests aren't even making it to emby server and are getting blocked somewhere along the way. This probably goes back to your port forwarding setup in your router.
