PenkethBoy 2068 Posted January 17, 2018 Posted January 17, 2018 Steve Gibson has released a small tool to check if you are vulnerable to Meltdown/Spectre on your Windows PC - works on all version apparently https://www.grc.com/inspectre.htm 1
Tur0k 148 Posted January 17, 2018 Posted January 17, 2018 Steve Gibson has released a small tool to check if you are vulnerable to Meltdown/Spectre on your Windows PC - works on all version apparently https://www.grc.com/inspectre.htm Good find. I will give it a look over. Sent from my iPhone using Tapatalk
Guest asrequested Posted January 17, 2018 Posted January 17, 2018 I wonder if the OSs will check before patching?
Guest asrequested Posted January 18, 2018 Posted January 18, 2018 After a BIOS update, I'm in the clear
